Old Oct 17, 2011, 04:54 PM
kerwin50 is online now
Find More Posts by kerwin50
kerwin50's Avatar
winston mo
Joined Oct 2006
A30/28 squealing
I have an A30/28 on a 3DHS Edge 41 that squeals under burst of power and at WOT if I don't move the throttle stick real slow.
I'm using a hobbywing pentium ESC with the timing set on high. My prop is an APC 11/5.5
kerwin50 is online now Find More Posts by kerwin50
Old Oct 18, 2011, 09:32 AM
GWRIGHT is offline
Find More Posts by GWRIGHT
Product Manager at Hobbico
GWRIGHT's Avatar
United States
Joined May 2000
There are a few ways to correct this but I'm not sure if that particular ESC allows some of them. The ESC is losing sync with the motor. You can increase timing which is what I normally do, up to the 20 to 30 degree range, but I would assume that ESC doesn't allow you to go that high which is creating the issue. You can also put a delay in the throttle channel on the radio which electronically does what you're doing when you move the stick slowly, assuming your radio has that feature,.. or use a setting in the speed control to slow down the throttle travel, or, use a smaller prop.
GWRIGHT is offline Find More Posts by GWRIGHT
Site Sponsor
Discussion Hacker A30/28 squealing kerwin50 Power Systems 1 Oct 03, 2011 06:30 AM
Found Hacker A30-14L, A30-12L or A30-16M dawhale Aircraft - Electric - Power Systems (FS/W) 1 Mar 12, 2011 04:07 PM
Question Highly Aerobatic Plane for an A30-28? Gregg28 3D Flying 22 Aug 02, 2006 08:22 PM
Discussion Hacker A30-28 shaft set screw Tommy D Power Systems 3 May 24, 2006 07:28 AM
Sold Fs: Hacker A30-28 NIP AggieFlyer Aircraft - Electric - Airplanes (FS/W) 3 Sep 21, 2005 09:31 PM
