Joined Aug 2011
My new PBF with full symetrical airfoil
I built a 24"x24" Pizza box Flyer to evaluate the efectivness of a full airfoil on this type of plane. I had hoped that a blunt edge would help with the pitchiness of this type of wing. However I managed to break the foam while bending it whitch resulted in a sharpish leading edge. I used 1/4 pink foam with a max thickness of 2.5". On my next one I will use a heat gun to mold the foam over some PVC. I decided to use wingletts to help the elevons work better at high AoA. It came out to weigh 20 oz.
I used a 200 watt motor witha 12x3.8 prop http://www.youtube.com/watch?v=8eftSfAjA_E |
How about that high speed pitch problem? Did your airfoil have any effect?
Once you get it all sorted out, give this a try................http://www.rcgroups.com/forums/showthread.php?t=1515094 |
Joined Aug 2011
I made some changes to the PBF.
I built a new one with a more rounded leading edge. I also used a foam box spar and a longer nose. This lightened it up quite a bit without sacraficing strength. I also decided to have the rudder hang past the elevons. This allowed me to not have to notch the elevons and allows it to be more effective in high AoA. The pitch stability is very good. Top speed is pretty slow (~40mph). It is more of a 3d plane than a speed demon with its current set up. I am confident that it would be good at higher speed with a hotter motor. It is super floaty for its 20oz weight. Here is a video shot by my 8yo son. (you have been warned) http://www.youtube.com/watch?v=4OUXfCCazbI |
Airfoil Design for PBF
| Thread Tools | |
| Discussion Built-Up 40" Full Fuse Sbach 342 with Airfoil -- 6mm Depron | PinkYakRC | Foamies (Scratchbuilt) | 8 | Jun 21, 2011 12:33 PM |
| Discussion First Full Body, Full Airfoil Foamie | DLC | Foamies (Scratchbuilt) | 5 | Mar 10, 2011 06:55 PM |
| My new full fuse/full airfoil 3der | wyflyer_55 | 3D Flying | 5 | Jun 11, 2005 03:45 AM |
| Fully symetrical airfoil selections for a 300MPH 90" Turbine??? | Admiral_Red | Modeling Science | 16 | Jan 08, 2004 08:08 AM |
| Symetrical airfoil for a e-fun fly - Which one ? | Kevin Murray | Power Systems | 7 | Sep 13, 2001 12:33 AM |
