Old Oct 16, 2011, 11:02 PM
Dennis Everett is offline
Find More Posts by Dennis Everett
Dennis Everett's Avatar
United States, CA, Ontario
Joined Mar 2002
Question
To extend speed control wires ? motor or battery side ?
Hi all , i have a plane that i need to extend the speed control wires on , is it better to extend the motor side (3 wires) or battery side (2 wires) And why its better ?
Note: plane has already been flown , i extended battery side (about a foot ), seams to work ok with the exception of the speed control getting pretty warm ,( 125 castle ), im going to a 200 amp hobby king "red brick " i used 10 ga wire and 6 mm bullets , depending which prop i use , im seeing between 90 and 135 amps , on 6s 6600(2x3300) 40c sky lipos ,big jet screamer edf motor , 650kv , pusher prop .
Any and all answers welcome ......note , prop on plane in pic isnt what im now using ....
Dennis Everett is offline Find More Posts by Dennis Everett
Old Oct 17, 2011, 01:43 AM
Rich in ILM is offline
Find More Posts by Rich in ILM
Retired in NC
Rich in ILM's Avatar
USA, NC, Wilmington
Joined Sep 2010
Transient spikes go up considerably when you extend the batttery side cables. Life expectancy on the ESC drops quite a bit. There is substanial discussion on this if you do a search. You will want to start over and extend the motor leads. Make sure all motor leads are all the same total length.
Rich in ILM is offline Find More Posts by Rich in ILM
Old Oct 17, 2011, 03:25 AM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
Extend motor cables good.
Extend battery cabels bad (by more than a few inches).
See http://www.rcgroups.com/forums/showthread.php?t=952523 for detailed information on why...be prepared for A LOT of reading.
Steve
slipstick is offline Find More Posts by slipstick
Old Oct 17, 2011, 09:18 AM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Originally Posted by slipstick View Post
...be prepared for A LOT of reading. Steve
I try to maintain the opening post as a compilation/digest.
Vriendelijke groeten Ron
diy motor tips Drive Calculator
diy motor group Cumulus MFC
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Oct 17, 2011, 10:50 AM
Joined Mar 2002
Thanks Guys ! When the wire gets here i will extend motor side . The only drawback will be , as it is now the speed control is mounted outside the plane to get max airflow , i will now have to mount inside , where ever i do end up mounting it i will put a air scoop to direct air directly over it .( i mold my own air scoops )
THANKS AGAIN !!! Dennis
Old Oct 17, 2011, 05:05 PM
Jocke is offline
Find More Posts by Jocke
WATTSUP.SE
Jocke's Avatar
Sweden
Joined Dec 2001
http://www.castlecreations.com/produ...-cap-pack.html
http://www.yge.de/artikel.php?search=ygecaps7
Use a CapPack and install on your ESC, then extent the battery wires you can keep that ESC in the nice airflow, and you won't make the motor work any harder.
Jocke is offline Find More Posts by Jocke
Discussion extend motor or battery wires to esc? carl rich Power Systems 1 Jan 13, 2007 10:22 PM
Cool What to extend? Motor wires or Battery wires? L0stS0ul Castle Creations 16 Sep 18, 2006 02:39 PM
Question Twin CC Phoenix 10 - lengthen battery wires or motor wires? Rich_N Castle Creations 5 Sep 20, 2005 12:22 PM
effect of battery wires on speed control??? rtront Power Systems 0 May 29, 2005 11:44 PM
help, I forgot on which side it is ok to extend the wires of an ESC BEC ? Patrick Plawner Power Systems 9 Dec 08, 2003 04:28 PM
