Old Dec 29, 2011, 12:56 PM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
ill fix it give me a sec
Keenan smith is offline Find More Posts by Keenan smith
Old Dec 29, 2011, 01:03 PM
Joined Dec 2010
done just use this number 06349276348 i reprogrammed the system not to check
Old Jan 01, 2012, 07:09 PM
w747 is offline
Find More Posts by w747
747-400
alaska
Joined Mar 2007
Hey key ill put up the wing so you can see the way u can connect it, and i can help you get the front of you 777 more to scale, ill show you some tricks
w747 is offline Find More Posts by w747
Old Jan 04, 2012, 12:21 PM
Joined Dec 2010
thanks rojer ive made three attemps to date to build the nose correct but i seem to keep coming up short LOL
Old Jan 04, 2012, 12:35 PM
Joined Dec 2010
ive already built the outer wing section i might permanently join it and have the wing box disconnect for a stronger one piece wing so it'll be easier to take to the states on holiday with me
any thoughts ?
Old Jan 04, 2012, 10:21 PM
demondriver is offline
Find More Posts by demondriver
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
any thoughts ?
K try W747's removable wing section method it's probably the best for traveling around with.
demondriver is offline Find More Posts by demondriver
Latest blog entry: RC Red Dwarf Starbug!
Old Jan 05, 2012, 09:47 AM
Joined Dec 2010
I'll try disconnecting at the root instead airbuzz style
Old Jan 07, 2012, 12:33 PM
w747 is offline
747-400
alaska
Joined Mar 2007
Hey K i was trying to make a video for you but i do not have the memory on this cam i have, i lost my rc flight cam so ill just tell you what i do just go to airliner net.com look for 777 pics and get the beast side view of the 777 and trace it of of your computer with paper, o save the pic to your desk top on the computer so you can size it up to the size of your model hope i do not you lol
l
Old Jan 07, 2012, 01:32 PM
Joined Dec 2010
sorry about no recent pics i've been away at my aunt's house so ill be back to building on monday or so
Old Jan 07, 2012, 10:49 PM
Up-Out-&-Gone
Joined Mar 2007
No problem K, nobody can build 24-7,lol have a great weekend mate!
Old Jan 08, 2012, 06:41 AM
Joined Dec 2010
thanks man
Old Jan 09, 2012, 12:51 PM
Joined Dec 2010
heres a link to my landing gear thread
http://www.rcgroups.com/forums/showthread.php?t=1570916
heres the wheels im gonna use
for the Nose
http://www.hobbyking.com/hobbyking/s...5pcs_bag_.html
im struggling to choose mains
im thinking of using these
or
and this to construct the bogeys and
Main strut
http://www.hobbyking.com/hobbyking/s..._10x750mm.html
and this for the part to hols the axles
http://www.hobbyking.com/hobbyking/s...e_750x6mm.html
and this to use as the axles
http://www.hobbyking.com/hobbyking/s...1_5x750mm.html
and this epoxy to stick it all together
http://www.hobbyking.com/hobbyking/s...poxy_9_oz.html
and hopefully it'll look like this
Old Jan 09, 2012, 01:23 PM
Joined Dec 2010
and for thrust reversers
Originally Posted by EDFFanatic View Post
i suppose With some pretty creative hinging I suppose. You would need 4 doors than can open to reverse flow. And some means of preventing it from deploying mid air. Like microswitches on the landing gear mains that cut of power to the system so it can only work with wheels down! Trouble is, 70mm fan shrouds are a bit small for this kind of tinkering. 90 mm would make it easier.
Everything is possible !
i was thinking what he was thinking ^^^^^
Old Jan 09, 2012, 04:16 PM
EDFFanatic is online now
Find More Posts by EDFFanatic
EDFFanatic's Avatar
Montreal
Joined Feb 2004
K.smith459, you got your hands full with the reversers on the 777.
The technology they use is called Cold Stream Reverser, essentially, about half of the nacelle slides backwards exposing a cylindrical grid with the vanes angled towards the front and inside, a trap of sorts stops the flow.Have a looksy at the bottom of this link:
https://engineering.purdue.edu/~prop...treverse1.html
That`s some tricky stuff to do. An engineering marvel but a huge headache for us! You get this done, your name get carved in RC history!
Bypass Thrust Reversers would be easier but to my knowledge, the 777 only uses Cold Stream on all engine versions.
EDFFanatic is online now Find More Posts by EDFFanatic
Old Jan 09, 2012, 04:23 PM
Joined Dec 2010
ill fetch some thing give me a sec
For Sale Plans and Patterns for Sterling Chris Craft 63' Motor Yacht Kit B-11M iamplanecrazy2 Boats (FS/W) 13 Nov 28, 2015 05:24 PM
For Sale Fs: Mint- ko propo pds-2123 7.2-7.4v lipo compatible servo sir Cars - Accessories (FS/W) 5 Nov 09, 2011 04:11 PM
Sold ASP 7.5ccm, OSmax 2.5ccm and Supertigre 7.5ccm NEW! Cimek Aircraft - Fuel - Engines and Accessories (FS/W) 0 Sep 25, 2011 06:15 PM
For Sale Optima 7 - 7 Channel 2.4GHz Receiver mtnmnstr Aircraft - General - Radio Equipment (FS/W) 1 Sep 08, 2011 12:23 AM
Discussion Made in China 11m blimp philgib Blimps 15 Jun 24, 2007 10:13 AM
