Old Oct 16, 2011, 09:30 AM
Steve85 is offline
Find More Posts by Steve85
The "pro" in procrastination
Steve85's Avatar
Canada, ON, Kingston
Joined Mar 2004
Fun Build 5 (?) Design - 51" Span Lancaster in Pink Foam or (gasp!) Depron
Hey Everyone,
I've been pretty scarce on these pages lately, mostly because we moved from Ottawa to Kingston this summer, and there's been a buttload of stuff to do. We're finally settling in, and although setting up my workshop hasn't yet floated to the top of the priority list, I think I finally have time for a little bit of hobbying.
John (jofrost) mentioned in the context of last year's Fun Build 4 that this year's theme might be multi-engined birds, so with that as inspiration, I've started thinking about what my entry might eventually be. I've wanted to try some of the foam-building techniques in Sparky's "Building with Foam" book for a while now, and foam seems like a lightweight way to build a smallish multi with a low enough wing loading so that it doesn't have to fly around a fighter speeds just to stay airborne. I don't know if John will allow foam in the next FB, but I'm going to give it a try.
In anticipation of FB 5 launching, and it having a multi-engined theme, I'm going to try designing and building a 1/24 scale foamie Lancaster for IPS motors. This scale puts the model at 51" wingspan, with 2.25 square feet of wing area, so I think that if I can keep the AUW to 22-23 ounces, I'll end up with a bird that should have scale flying characteristics, ie. slow and majestic. I honestly don't know if this can be done, but it'll sure be fun trying!
I Googled around to see if there were any plans available that might be useful, and as luck would have it, someone was selling a copy of the June 1987 Model Aviation article and plan of Dennis Norman's amazing 51" span rubber-powered Lancaster, so I snapped it up. Dennis' design is an engineering marvel, and the plan has a large number of formers for the fuselage, inner and outer nacelles. I'll be using them as cross-sections for my foam version. The wing uses cracked rib construction, however, so I'm going to be on my own in terms of finding a suitable airfoil.
So, on to the first of what I'm sure will be a million questions as I work up the design: can anyone suggest an airfoil for this model? I'm looking for a relatively thick airfoil (for scale appearance) that has good low speed lift and a gentle stall. Thanks in advance!
Steve
Steve85 is offline Find More Posts by Steve85
Old Oct 16, 2011, 10:33 AM
Martin Irvine is offline
Find More Posts by Martin Irvine
Martin Irvine's Avatar
Joined Aug 2000
Hi Steve:
A Clark Y or a NACA 2400 or 23000 series would be my choice. You can figure out the thickness from scale drawings and plug in the percentage. Do you have Profili? It will do ribs for a tapered wing quite well.
Martin
Martin Irvine is offline Find More Posts by Martin Irvine
Old Oct 17, 2011, 04:55 AM
Richard Woods is offline
Find More Posts by Richard Woods
Joined Jul 2007
Which is about as scale as you can get; what with the bomber itself using NACA 23018 at the root going to 23012 at the tip.
Richard Woods is offline Find More Posts by Richard Woods
Old Oct 17, 2011, 02:44 PM
Steve85 is offline
Steve85's Avatar
Joined Mar 2004
Thanks, guys. I do have Profili, and I'll see if the NACA 23000 series is in its library tonight. I did a bit of Googling on the series, and as long as its characteristics scale down, it looks like the answer.
Steve
Old Oct 17, 2011, 03:10 PM
DingoII is offline
Find More Posts by DingoII
Czech Rep.
Joined Aug 2006
Steve,
If I may interfere here - I would stay away from 5-digit NACA airfoils, they have prety nasty behaviour in model scale. NACA 4-digit range is much better choice IMO, still I would prefer Eppler E205.
Looking forward to your build
Jan
DingoII is offline Find More Posts by DingoII
Old Oct 17, 2011, 10:39 PM
Joined Aug 2000
Well, I've had good luck with the 23012 airfoil in the 45-80" range.
Martin
Old Oct 18, 2011, 12:10 AM
DingoII is offline
Czech Rep.
Joined Aug 2006
No problem at all, I just happen to have a "red light" on 23xxx.
Jan
Old Oct 19, 2011, 06:35 AM
LenBFP is offline
Find More Posts by LenBFP
It's a Great Day to Fly
LenBFP's Avatar
Melbourne Beach, Florida
Joined Jan 2002
Subscribed. I hope funbuild 5 is multi engine. This could be fun.
Len
LenBFP is offline Find More Posts by LenBFP
Old Oct 19, 2011, 06:48 AM
jhspring is online now
Find More Posts by jhspring
Oh no, not again!
jhspring's Avatar
United States, LA, Carencro
Joined Dec 2005
Really looking forward to this one Steve. Subscribed. Jeff
jhspring is online now Find More Posts by jhspring
Old Oct 19, 2011, 05:50 PM
mrdj is offline
Find More Posts by mrdj
Dog is my co-pilot.
mrdj's Avatar
United States, GA, Brooks
Joined Mar 2005
Moving puts a big dent in model building. I finally have a basic desk in my new digs. Great subject, what markings will you use?
DJM
mrdj is offline Find More Posts by mrdj
Old Oct 20, 2011, 12:02 AM
Scaledown is offline
Find More Posts by Scaledown
It must have a machinegun
Scaledown's Avatar
Perth, Western Australia
Joined Sep 2004
I built a Halifax using IPS clones a few years back. Its got a reasonably low flying speed and handles flawlessly. I think I used a clark Y. Wing loading is of course the key to slow flight. Its all open framework except for the top and bottom fuselage which are curved 1/32 sheet, and a foam nose.
Scaledown is offline Find More Posts by Scaledown
Old Oct 20, 2011, 08:03 AM
Steve85 is offline
Steve85's Avatar
Joined Mar 2004
Hey guys,
Thanks for all the interest and input! It turns out that Profili has the ability to generate a NACA airfoil just by inputting its numerical designation. The NACA 23012 tip airfoil was already in Profili's library, and I was able to quickly generate the NACA 23018 root airfoil using this handy feature.
I'm still doing a lot of reading to bone up on foam wing-building techniques, and have yet to decide if I'll cut a foam core with a hot wire, or use Depron and build up a wing like eflightray did for his magnificent Sunderland. I might even try an outer wing panel using each technique to get a better idea of their relative strengths and weights. I'm leaning toward a fiber glassed skin for hangar-rash resistance, but this may be a luxury the weight budget won't be able to afford. The fuselage will be pink (or blue) rigid foam insulation, either carved and sanded or hot wired, with a skin of 3/4 oz glass.
As for markings it's still early days, but it will definitely be a Bomber Command scheme, no doubt from an RCAF squadron in No. 6 Group, and possibly Lancaster Mk X KB726, code letters VR-A, in which P/O Andrew Mynarski won the Victoria Cross.
Ah, it's good to be back...
Steve
Old Oct 20, 2011, 08:22 AM
Scaledown's Avatar
Joined Sep 2004
Its really hard to make a bomber fly like a bomber and not a fighter unless you are ruthless with the weight saving. Fibreglassing isn't ruthless.
I built a wing recently that had a 2mm depron skin. I've even put an electric planer over depron to create 1mm depron (albeit for a small plane). I think the only thing lighter would be an open structure from balsa.
Old Oct 20, 2011, 09:12 AM
Sopwith Mike is online now
Find More Posts by Sopwith Mike
Slip the surly bonds...
Sopwith Mike's Avatar
Christchurch,England
Joined Aug 2004
I'll second all that's been said about weight being the key to good performance. A 51" Lanc will never fly at scale speed, but you will have a lot of fun with the model.
I've just finished a 48" span depron BN Islander (designed to take to pieces and go in cabin baggage) which weighs 25 oz. Take off 4 or 5 oz for a one-piece model and dispense with the moulded cowls and 20 oz is a reasonable target for this size of plane.
I would strongly recommend a Clark Y or E205 over any other airfoil for this size and weight of model. In fact, have you considered using 6mm depron as a flat plate airfoil (curved over to mimic the top of Clark Y section). This gives a very light and strong wing but of course it will look non-scale from underneath.
A 3mm depron lower skin, 2 laminations of 6mm depron for the spar with a few 6mm ribs and a 3mm top surface will give you a very strong and rigid wing with enough room inside it to take aileron servos and power wires. If you can find 2mm depron, go for it.
I'm looking forward to seeing the model and hearing how it flies - best of luck!
Sopwith Mike is online now Find More Posts by Sopwith Mike
Old Oct 21, 2011, 12:52 PM
Steve85 is offline
Steve85's Avatar
Joined Mar 2004
Hmmm, looks like I'll have to sharpen my pencil for the weight budget. Mike is right, a 1/24 scale Lancaster will never fly at scale speeds, because 200 mph translates to 12.5 km/h at that scale, and that would be well below the stall speed of anything I could build! I'll do some math over the weekend and see what I can allow for airframe weight.
I've had a look at some nice Depron scale models, including Mike's Canadair Scooper and the aforementioned Sunderland by eflightray, and can feel a pull towards the Dark Side of Depron. To date, I've only used it for lamination forms, but I think I'll seriously consider building at least the wings from the stuff, and perhaps even the fuselage as well. I know this is straying further and further from the traditional confines of previous Fun Builds, but it seems like too much fun to pass up. I've been looking for tutorials or how-to's on building scale models from Depron without much luck, though. If anyone knows where to point me, especially for techniques to build compound curved fuselages, I'd be grateful.
Oh, and I changed the title of my thread...
Steve
Discussion pink foam in san diego rcthrasher Foamies (Scratchbuilt) 2 Aug 27, 2011 04:14 PM
Discussion Looking for FFF 3D design in 2S 450mah 28-33" span range learn2turn Foamies (Scratchbuilt) 5 Jul 21, 2011 03:40 PM
Contest Fun Build 4 - erweiterte Ausgabe Guillows JU-87B Stuka 1155mm Wing Span MPP Scale Kit/Scratch Built 9 Apr 04, 2011 02:57 PM
Build Log SCRATCH Avro Lancaster Design & Build RCAP Fuel Warbirds 2 Jan 25, 2009 04:44 PM
Build Log Scratch Build 24th Scale (50" Span) Lancaster sutlane Scale Kit/Scratch Built 7 Mar 18, 2007 04:00 PM
