I've ordered a Cameo to do a head to head comparison with the Zing. I'm not really happy about spending the money or having to design a test protocol. Thinking about ways a cutter or its software might suck is kind of interesting.
The conclusion I've come to is that to proper offset handeling is the critical thing. This means that cutting something like a square requires a non-square cut path. The plotter head has to make some arcs, the radius of the offset, at the corners to re-orient the blade parallel to the next edge. If it fails to do this it will round off the corners. If it over compensates you should see some additional "bumps" at the corners. This was just a theory until I found this video which illustrates exactly the problem:
That demonstrates how the cutter is moving the head to re-orient the blade to cut the next edge. This means that the software must track the blade's orientation and compute the correct arc path between line segments. I've devised a simple test to see what the software on a cutter is doing: Put a pen in it and crank up the offset. This should make it easy to see how the cutter/software makes its corrections. I'm also designing a simple test pattern to run on each machine. The pattern will stress angular performance, offset correction and small circle performance. Then I'll run that pattern through several materials; pen on paper, vinyl, monokote and ultracoat. Each machine will get its offset tweaked for the blade/material to maximize the quality of its results. Then I'll take some nice macro shots and we can compare the output head-to-head. |
Wow, great stuff you posted here. Thanks for all the effort, and especially thanks for comparing two machines!
I'm inclined to buy a Cameo myself now. I've been trying to find this information on the "other" forum. I'm glad we can cross-link 'em! http://www.rcuniverse.com/forum/m_10..._1/key_/tm.htm |
Just ordered mine!
http://www.signwarehouse.com/c-EQ-VC-CRFT-CUT-SIL.html I'll let you know how it works out. |
Amazon has them: http://www.amazon.com/Silhouette-Cam...3083705&sr=8-1
| Thread Tools | |
| Sold Roland Stika 15" Vinyl Cutter | FASTALJR | Aircraft - General - Miscellaneous (FS/W) | 5 | Sep 12, 2011 04:25 PM |
| Discussion Vinyl cutter for decals etc.. | The End | Painting and Finishing Tips | 3 | Jan 16, 2009 05:47 PM |
| Vinyl cutter for making airbrush masks? | mluniewicz | The Builders Workshop | 6 | Mar 21, 2005 03:13 PM |
| Is there an economical radial mount for the AXI 2808 series? | papasmurf | Power Systems | 1 | Jan 24, 2005 07:05 PM |
| Need software for a stika vinyl cutter scp85 | tbstep | Aircraft - Electric - Airplanes (FS/W) | 2 | Jan 27, 2003 11:43 AM |
