Old Oct 18, 2011, 08:40 PM
samc99us is online now
Find More Posts by samc99us
Aurora Builder
United States, MD, Lusby
Joined Nov 2003
I'm with Jun, make a hatch. Sorry, the structural integrity is not really an issue. Look at the Helios method, lightweight, easy to install, easy to replace etc. Still, the servo pretty much must be glued to the wing, as my launches have gotten harder, it is clear that gluing to the hatch isn't the best solution. Maybe adding hard points to the wing for mounting servos? Of course the servo design needs to be modified by rotating the mounting tabs 90 degrees.
samc99us is online now Find More Posts by samc99us
Old Oct 18, 2011, 08:50 PM
Maki is offline
Find More Posts by Maki
Maki's Avatar
Joined Aug 2007
Hi, well one of my enemies are time, I need my Steig competitive for this weekend, so I decided to change the servo for a digital Hitec, the only one with the same thickness was the HS 5045, and one of the few I cant get quick in Chile.
I think the wing is well, I did my best :
due Hitec servo is faster I reduced speed of it with Auroras Speed function.
Tomorrow I need to do my first trainigs, let see how it works.
Good luck to them who bought the same wing, the servo worked good the first minutes, but after about 5 or 6 minutes of moving the stick the servo started to fail, and it was increasing, now if I put the servo in a channel it never stops to move..
It is very sad to have to do this, for me it was not a 1000 dollar model, I paid fedex, and Chilean custom for a lot of dolars more, therefore I understand Rainer, it is not easy trying to do something.
By the way the service of Stratair is very good, tomorrow I can say if the model is the same
regards
Mario
Maki is offline Find More Posts by Maki
Old Oct 19, 2011, 07:10 AM
Kenny Sharp is offline
Find More Posts by Kenny Sharp
turn, turn, turn.
Athol, Massachusetts
Joined Oct 2005
Servos in the wing... You guys got what you asked for.
Kenny Sharp is offline Find More Posts by Kenny Sharp
Old Oct 19, 2011, 07:13 AM
turn, turn, turn.
Joined Oct 2005
Maybe you should have asked for Voltz wing max.
Old Oct 24, 2011, 01:54 PM
1900 Driver is offline
Find More Posts by 1900 Driver
1900 Driver's Avatar
United States, CA, Santa Barbara
Joined Mar 2009
Yeah Kenny we sure did! just not defective ones!
1900 Driver is offline Find More Posts by 1900 Driver
Old Oct 24, 2011, 02:43 PM
KevinSharbonda is online now
Find More Posts by KevinSharbonda
Make Flying Fun
United States, CO, Castle Rock
Joined May 2003
As a side note, I recall you should take care handling the Hyperions as they can damage if you squish' em!
KevinSharbonda is online now Find More Posts by KevinSharbonda
Old Oct 24, 2011, 06:13 PM
turn, turn, turn.
Joined Oct 2005
Either way, you'd be changing them eventually... as the plane will last much longer than 2 or 3 sets of servos.
Old Oct 24, 2011, 08:11 PM
Joined Mar 2009
I understand that eventually you'd be changing them, it would just be nice to fly the model for a while before having to cut into such a sweet wing!)
B
Old Oct 24, 2011, 10:19 PM
MaddSkillz is offline
Find More Posts by MaddSkillz
Intergalctic Coffee Enthusiast
MaddSkillz's Avatar
United States, OK, Tulsa
Joined Jun 2011
I'm looking to invest in my next DLG since I bought this used Taboo XL and found that I love DLG. I've only been considering DLG's that can accommodate all servos in the pod. I can't imagine cutting on a wing to do maintenance anyway. I'd screw it up.
MaddSkillz is offline Find More Posts by MaddSkillz
Old Oct 25, 2011, 12:48 AM
davidjensen is offline
Find More Posts by davidjensen
Will fly for food
davidjensen's Avatar
Bellevue WA,
Joined Dec 2003
Blaster 3
davidjensen is offline Find More Posts by davidjensen
Old Oct 25, 2011, 05:15 AM
turn, turn, turn.
Joined Oct 2005
B
You can't see the repair at 50 feet anyway.
Should've ordered 2.
Old Oct 25, 2011, 09:09 AM
MaddSkillz's Avatar
Joined Jun 2011
Originally Posted by davidjensen View Post
Blaster 3
Yeah, that's the way I'm leaning. I wish they had a disser version between the bagged and the spread tow.
Old Oct 25, 2011, 04:53 PM
Joined Mar 2009
I have a steig with servos in the fuse and once i get my new fresh wing im planning on cutting into the old wing(full carbon) installing top drive and cutting off the unreliable internal system. I've had my day cut short on a couple occasions due to the carbon rods pulling out of the shaft. (thats what she said!!) The previous owner had the same issues and had delamed the main and drag spars. Needless to say, I got a good deal!)
Brandon
Old Oct 26, 2011, 10:37 AM
Maki is offline
Maki's Avatar
Joined Aug 2007
Thank you for you comments, by the way, the Steig flow, and flow impresive good..
Now I can't get out of mi mind this fixed wing, and that any bad tendence is fault of the wing repair....so I'm thinking in my next DLG.
Due your experience, which schould be my next DLG after Steig?
any recomendation woud be very nice.
Thank you and regards,
Mario
Old Oct 26, 2011, 09:51 PM
Joined Mar 2009
Im glad it flew well!!!you already have an awesome dlg, so topping it would be tough, you could get a stobel, or any of the top moulded planes out there. What I would do is get another dlg to compliment the steig, something for really light to moderate conditions! The steig is great for moderate to heavy! My light planes are a vandall that comes in at 9oz. and I just bought a used stobel v2 for the moderate conditions. Most importantly get out and have fun no matter what you get!
Cheers,
Brandon
Link Servo Arms & Horns - Big selection! ServoCity ServoCity.com 0 Sep 13, 2011 09:05 AM
For Sale Steigeisen with Top Drive Wing NCDLG Aircraft - Sailplanes (FS/W) 0 Sep 12, 2011 12:48 PM
Help! Blade 400 servo issue PirateBlenny Electric Heli Talk 6 Sep 10, 2011 02:28 PM
Discussion Issue with Champ servo tamiyafan1975 Micro Ready-to-Fly 4 May 07, 2011 04:50 PM
Discussion Servo Reversers, Still bad, or old issue? mikes68charger Radios 5 Mar 04, 2011 10:23 PM
