Old Oct 15, 2011, 06:10 AM
pecamuzicar is offline
Find More Posts by pecamuzicar
Joined Oct 2011
The basics of building RC aircraft motor where rotor is permanent magnet?
Hi to all,
I have strong (probably NEO) cylindrical magnets radially magnetized, but something coated outside with some hard material heavy to remove: long 40mm, diameter 15mm. It looking to me good to use like rotor for making RC aircraft motor.
What kind of RC aircraft motor I can build with it?
Please tell me about construction, windings, what kind of stator controller I need ...
Peter
pecamuzicar is offline Find More Posts by pecamuzicar
Old Oct 16, 2011, 07:33 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
I saw your question but I can't really visualize the size and shape of the magnets you are asking about. Maybe some photos of the magnets or something would help.
Many of us are rewinding motors that were sold as running motors. That does not normally involve building from scratch. Go through all the links on the sticky post about CD-ROM motors and look at some of the threads and you can see some of the mechanics of the motors.
Here is a manual for a motor that was sold as a kit, you can see all the parts involved and how they are assembled:
http://www.micronradiocontrol.co.uk/.../KH-257D-1.pdf
Good luck with it!
Jack
jackerbes is offline Find More Posts by jackerbes
Old Oct 16, 2011, 11:12 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Maybe I don't understand at all.......but I can't imagine a single pole inrunner.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Oct 16, 2011, 01:47 PM
modisc is offline
Find More Posts by modisc
Inspiration
modisc's Avatar
United States, MI, Ann Arbor
Joined Aug 2011
I assume it is just a 2 pole magnet.
an inrunner with that magnet would not be so good.
modisc is offline Find More Posts by modisc
Old Oct 19, 2011, 02:47 AM
Joined Oct 2011
I am sorry, like a newbie I did not understand even yours terminology here, so title of this my thread should be just: "Basic of brushless inrunner motor?" (with two pole permanent magnet).
But what would problem with two pole magnet? Low speed, or something?
What you think about idea to put two pieces of these magnets in serial (on same shaft), than turn one of them for 90 degrees by axis.
It would be long 4 pole piece rotor, than half of stator windings should be organized around first magnet, and half around second.
Such brushless inrunner motor would be long, but because of half number of stator windings around each of magnets there is less space required for stator windings, so motor can be thin. :-))
Sorry if I boring with this but I have many of these magnet I would like to use, so please what you think?
Old Oct 19, 2011, 07:24 PM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Peter, read this sticky, manuals, tips, tricks, checks tests. Whether inrunners or outrunners, the same physics and rules apply, notably winding diagrams and controllers:
http://www.rcgroups.com/forums/showthread.php?t=240993
Specifally inrunner building
http://www.rcgroups.com/forums/showthread.php?t=1514232, notably post #10
http://www.rcgroups.com/forums/showthread.php?t=665032
http://www.rcgroups.com/forums/showthread.php?t=473418
If you want more just search this subforum for discussions with inrunner or inrunners in the title.
Prettig weekend Ron
diy motor tipsDrive Calculator
diy motor groupCumulus MFC
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Oct 21, 2011, 09:40 AM
Joined Oct 2011
Oh finally, thanks Ron I see you care!
Help! Need help on building a rc aircraft WildMaster Fuel Plane Talk 17 Sep 11, 2011 07:07 AM
Discussion Permanent magnet motors effective winding? mir_as82 Electric Motor Design and Construction 8 Jul 30, 2011 08:06 AM
Question Where to Buy Magnet Wire? BoomStriker Electric Motor Design and Construction 4 Jul 13, 2011 03:15 PM
Help! Permanent magnet DC/Brushless formulae dogshome Electric Motor Design and Construction 15 Jun 07, 2007 04:07 PM
MS tiny Yaw Rate gyro Himax Magnet rotor new 2025 size and century BL motor 2015 size littlepiston Aircraft - Electric - Helis (FS/W) 6 May 13, 2005 12:18 AM
