Old Oct 14, 2011, 06:33 PM
jonathan7x70 is offline
Find More Posts by jonathan7x70
President @ Acadian RC Club
jonathan7x70's Avatar
Lafayette, Louisiana
Joined Dec 2005
Question
What is Switching Frequency?
I have the Turnigy 55Amp Delx Esc.
It has 8kHz & 16kHz.
What one should I use? 8 or 16?
Here is the ESC Link if you need it:
http://www.hobbyking.com/hobbyking/s...ontroller.html
jonathan7x70 is offline Find More Posts by jonathan7x70
Old Oct 14, 2011, 10:18 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Words of wisdom from Ron:
PWM = Pulse Width Modulation
Unless your ESC is at full power, the ESC pulses (or chops up) the voltage to the motor. The wider the pulse, the more power it gets, 100% pulse width is 100% power. The frequency of these pulses can be 8kHz, 16kHz or 32kHz. Although the voltage to the motor is pulsed, the current to/in the motor is not pulsed. The 'smoothess' of the current depends in the motors inductance (the more inductance, the smoother) and the PWM frequency (the higher the frequency, the smoother). High inductance (e.g. outrunners) motors can do with 8kHz, low inductance motors (eg. slotless or ironless motors, Kontronik Tango) need 32kHz. Driving a high inductance motor with 32kHz won't hurt, but controller losses will be higher. So in your outrunner case, use 8kHz.
Vriendelijke groeten Ron
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Oct 14, 2011, 10:47 PM
Joined Dec 2005
wow thats a lot of info.. not sure i understand but ill stick with 8kHz. the link is not working.
Old Oct 15, 2011, 08:41 AM
twest is offline
Find More Posts by twest
100% electric since 1990
twest's Avatar
United States, MA, Ware
Joined Jul 2001
Some suggestions to start with:
Outrunner motors: most likely 8 khz (unless you are turning high rpms in edf or heli)
8 pole inrunner (neu 1900, big astro brushless)- 8khz or 12 khz
6 or 4 pole inrunner (mega, neu, astro, aveox): 12 khz (or 8 if your esc won't do 12)
2 pole inrunner (slotless, hacker, kontronic, etc) 16 khz
kontronic tango: 32 khz
twest is offline Find More Posts by twest
Old Oct 15, 2011, 08:43 AM
twest is offline
twest's Avatar
Joined Jul 2001
If using helis, there is a formula I've seen in the castle creations forum on how to calculate needed frequency, and it uses motor poles, gear ratio, head speed, etc to come up with an estimate.
Discussion What is the lowest frequency that can be used for FPV? GJH FPV Talk 10 Sep 29, 2011 02:59 AM
Gallery Brushed controller switching frequency BigR DIY Electronics 24 Jul 27, 2011 06:32 AM
Best switching frequency (FUN 600-18 + Futura 18.48K) ThomasJoehnk Power Systems 6 Jul 12, 2003 04:59 PM
Switching Frequency Discussion Sloper Mario Power Systems 21 Nov 13, 2002 05:04 PM
ESC switching frequency... high or low? paulaac Power Systems 22 Feb 27, 2002 12:14 PM
