Old Oct 29, 2011, 06:01 AM
jonnyrockets is offline
Find More Posts by jonnyrockets
Joined Jul 2011
Originally Posted by Widelec View Post
Arduino bluetooth and usb serial port adapter avaible at dealextreme.
What is the Blue Tooth module used for?
jonnyrockets is offline Find More Posts by jonnyrockets
Old Oct 29, 2011, 06:11 AM
Widelec is offline
Find More Posts by Widelec
Simple is the best
Joined May 2011
Bluetooth module is Optinal.
You can configure PID setting with android phone without pc.
you can find more info this thread
MultiWii Configuration for Android over Bluetooth
Widelec is offline Find More Posts by Widelec
Old Oct 29, 2011, 05:27 PM
Widelec is offline
Simple is the best
Joined May 2011
Outdoor fly today. I will try for better video tomorrow.
BambuCopter outdoor.mp4 (1 min 31 sec)
Old Oct 31, 2011, 04:36 AM
Widelec is offline
Simple is the best
Joined May 2011
Sunday Fly
BambuCopter Fly (Çatalan) (2 min 30 sec)
Old Oct 31, 2011, 12:53 PM
Widelec is offline
Simple is the best
Joined May 2011
I received today two pack. Miniwii and allinone imu. Both realy mini.
Serial pins need to bend for spurkfun FTDI. I set "arduino pro or promini (5v 16mHz) atmega328" for board.
I set BMA 180 and itg3200 and upload multiwii 1.8_pach_2 to miniwii.
Thats all. Multiwiiconfig is work. I like the MiniWii.
Today I will solder motor and rx pins....
I will test with my frame.. would be nice MiniWii and BambuCopter Mini
multiwiiconf for Miniwii . Widelec (0 min 27 sec)
Old Oct 31, 2011, 01:33 PM
Widelec is offline
Simple is the best
Joined May 2011
Second pack allinone iMU
I use allinone imu with previously received MWC Board matt black and Flyduino Pro Mini 16Mhz 5V Matt black.
Allinone imu is 5v with LLC version no need 3v from MWC Board.
Old Nov 02, 2011, 10:03 AM
Widelec is offline
Simple is the best
Joined May 2011
BamBuCopter Frame with hobbyking simple FPV parts
Description: Name: 3.jpg
Description: Name: 4.jpg
Description:
Description: Name: 6.jpg
Description: Name: 7.jpg
Description:
Description: Name: 11.jpg
Description: Name: 12.jpg
Description:
Description: Name: 14.jpg
Description: Name: 15.jpg
Description:
Description: Name: 17.jpg
Description: Name: 18.jpg
Description:
Old Nov 09, 2011, 02:08 PM
Widelec is offline
Simple is the best
Joined May 2011
BambuCopter Building Tips
Letters must be like to be read from above and below
Description: Name: 2.jpg
Description:
Remove all the protective nylon with wooden rod
Description: Name: 31.jpg
Description:
Install all of the upper and lower screws and Cable Ties to lower base plate.
Description:
Now install motors and ESC... (use M3x6 metal screw for motor mount.)
fold-over cable under the esc
Description: Name: 8.jpg
Description:
Place upper plate and Install all of the upper screws to upper plate.
Description: Name: 9.jpg
Description:
Old Nov 13, 2011, 08:24 AM
Widelec is offline
Simple is the best
Joined May 2011
BambuCopter Frame with 3 blade propeller and reverse motor mount.
Description: Name: 2.JPG
Description: Name: 3.JPG
Description: Name: 4.JPG
Description:
Description: Name: 6.JPG
Description: Name: 7.JPG
Description: Name: 8.JPG
Description:
Old Nov 13, 2011, 12:35 PM
3rdeyepro is online now
Find More Posts by 3rdeyepro
Hovership
3rdeyepro's Avatar
United States, CA, Cupertino
Joined Aug 2010
How do you like those turnigy motors vs keda?
3rdeyepro is online now Find More Posts by 3rdeyepro
Old Nov 13, 2011, 01:13 PM
Widelec is offline
Simple is the best
Joined May 2011
turnigy better magnets, less winding.
a little more time to say how its fly, because the weather is bad here.
Old Nov 13, 2011, 01:15 PM
Hovership
3rdeyepro's Avatar
Joined Aug 2010
Does the prop saver adapter come off?
Old Nov 13, 2011, 01:18 PM
Widelec is offline
Simple is the best
Joined May 2011
Propsaver come with motor and well fit with GWS 3 blade
Old Nov 13, 2011, 02:54 PM
Hovership
3rdeyepro's Avatar
Joined Aug 2010
Yes but is it a part of the motor or can it be removed?
Old Nov 13, 2011, 03:00 PM
Widelec is offline
Simple is the best
Joined May 2011
sorry.
Down side propeller saver is part of motor,
up side propeller adapter separate.
I use up side and propeller adapter.
Propeller adapter come with motor.
Discussion Anything for all around sport fun flying better than a PIYAK tymbrewolf Foamies (Scratchbuilt) 0 Sep 20, 2011 10:52 PM
For Sale XAircraft X450P frame kit for sell terriwang Aircraft - Electric - Multirotor (FS/W) 11 Sep 12, 2011 09:46 PM
For Sale For Sale - CHIPMUNK (Vintage Model Products Kit) Ready to cover 850 sq inches Daveairway Aircraft - Fuel - Airplanes (FS/W) 8 Feb 26, 2009 04:42 PM
For Sale For Sale - CHIPMUNK (Vintage Model Products Kit) Ready to cover 850 sq inches Daveairway Aircraft - Fuel - Airplanes (FS/W) 3 Dec 14, 2008 06:53 PM
