Old Aug 21, 2012, 07:14 AM
ozzieparky is offline
Find More Posts by ozzieparky
UK
Joined Sep 2010
Originally Posted by ronwc View Post
You can get the Futaba R2006GS SFHSS 6 channel rx for the 8J for $35 from helidirect.
Cheers - sadly out of stock at the mo!
ozzieparky is offline Find More Posts by ozzieparky
Old Aug 21, 2012, 09:35 AM
ronwc is offline
Find More Posts by ronwc
Ron - AMA 1025
ronwc's Avatar
USA, FL, Largo
Joined Aug 2005
rx
I ordered 6 from them in the last week or so, must have run out.
Can also get them here for $39 with free shipping - http://www.ebay.com/itm/Futaba-R2006...item5ae8fa2511
ronwc is offline Find More Posts by ronwc
Old Aug 23, 2012, 01:58 AM
SONICX is offline
Find More Posts by SONICX
SONICX's Avatar
South Africa, GP, Krugersdorp
Joined Jul 2012
T8J Battery
Hi all,
Here is the battery I'm using.Its a 7.4V Li-Po 2600mha.
It was just plug and play, TX pick it up right away and on
the display was showing the battery sign with 7.4V inside.
As I have been using it ,it just counts down as battery voltage
are dropping.After many hours now it has droped to 6.9V.
Not sure what the limit is.Nice about the Li-Po is I use same
charger as for flight packs.
One thing i liked was how easy and quickly it is to pair with a RX.
Just hold in switch for a few seconds till green light comes on and
your done.
SONICX is offline Find More Posts by SONICX
Old Aug 23, 2012, 03:39 AM
SimonChambers is offline
Find More Posts by SimonChambers
Radio? Screwdriver!
United Kingdom, England, Bristol
Joined Aug 2011
7v I'd charge if I was going flying for the day, 6.6v is probably the lowest I'd go for a 2S lipo. Don't go below 6v.
Si.
SimonChambers is offline Find More Posts by SimonChambers
Old Aug 23, 2012, 06:34 AM
SamNo3D is offline
Find More Posts by SamNo3D
Joined Jul 2012
Originally Posted by SONICX View Post
Hi all,
your done.
What is that second Pic of? I see front of prop on top and control surfaces?
SamNo3D is offline Find More Posts by SamNo3D
Old Aug 23, 2012, 06:57 AM
Radio? Screwdriver!
Joined Aug 2011
your done.
I really don't like how Futaba do their bind mode at all. I dislike the fact that it'll lock onto any Futaba S-FHSS transmitter nearby - not necessarily yours!
I'd love to see what would happen and how easy it is to try to bind in a busy, close environment such as indoors flying.
Si.
Old Aug 23, 2012, 08:03 AM
ronwc is offline
Ron - AMA 1025
ronwc's Avatar
USA, FL, Largo
Joined Aug 2005
Si.
Tx has to be close, within 20" or less to bind.
Old Aug 23, 2012, 08:23 AM
Felix the kat is offline
Find More Posts by Felix the kat
Joined May 2012
Hi all,
your done.
How many hours are you getting out of it ? Where did you get and for how much?
I have Futaba's HTF1700B 1700mAh which doesn't last very long. My other TX
packs, 2600 (8 pack replacement) will last for days, but obviously
don't fit on the 4 pack slot.
Felix the kat is offline Find More Posts by Felix the kat
Old Aug 24, 2012, 04:08 AM
UK
Joined Sep 2010
Sorry guys but apart from being able to charge the tx battery on your normal field charger I don't understand the benefit of using lipo's in the tx. Surely it means you can't charge the battery in the tx and you have to be careful about charging / storing / transporting etc, etc.
Do you get longer from them than you would from say eneloops which have just been mentioned by Si?
Sam
Old Aug 24, 2012, 04:38 AM
Radio? Screwdriver!
Joined Aug 2011
Sam
Couple of advantages:
  • LiPo's have a higher power density than NiMh (i.e. for the same size, it has a greater capacity).
  • A lot of the new LiPo's can be charged at a much faster rate than NiMh - some as much as 5C capacity
  • Very, very low self discharge. Lower than eneloop.
Obviously there are disadvantages such as a volatile chemistry (very dangerous to leave a pack in a unattended car), require balance charging, minimum battery voltage (i.e. leave the transmitter on till its flat and you'll kill a LiPo), etc.
For the most part eneloops are sufficient for transmitters. Also, as transmitters are usually designed with NiMh packs in mind, they tend to balance better with a heavier pack.
Personally, in my Aurora 9 (my main transmitter), I use a LiPo because it gives around 22-24 hours run time which means I only really have to charge my transmitter every couple of months. If I forget to charge it and its getting a bit low, I can charge it at a 2 to 4C charge rate and its full and ready again in 20-30minutes. Useful if your forgetful like me! Also the Aurora 9 has a LiPo mode for a minimum voltage - so if you leave the transmitter on and flatten the battery, it'll cut the power before it kills the battery. I don't think the T8J has this.
However on a LiPo you can't just plug it in the day before and leave it to charge overnight, like you can with a NiMh.
So its up to you and whatever you prefer - nothing wrong in using a NiMh or Lipo - or even a LiFe pack. There does tend to be obsession over using LiPo's in transmitters. If they're needed or not is a bit of a contentious matter.
Si.
Old Aug 24, 2012, 07:59 AM
Joined May 2012
8J and Gyro
Hi everyone, I have two identical 450's with my 8j and R2008 Rx's.
The situation is, one of them the Gyro is set to sw A at 65% AVCS /35% normal and works like a charm. Detrum GY48V and Emax 9257 servo.
The other one doesn't work properly with the A sw. and must do it through the VR knob at VERY little rotation from dead center. The only difference is the servo on this one is a GOTECH, digital, coreless, ball bearing servo. (cheapo) If it's set to sw A it goes berzerk, wagging, jitters........the works.
Have tried swapping servos, new GY48V, zero delay, have played with the TX to the same settings, no binding on travel, limits are fine, both servos are "digital" but they must be operated under normal to prevent overheating.
I always standarize all my birds in order to avoid confussions and different checklists when flying.
Does anybody knows what in the world is going on here? Running out of options. ANY sugestion will be appreciated. Hope is not the RX as they are NOT cheap and less than 2 months old each.
Old Aug 25, 2012, 02:23 AM
numnutchris is offline
Find More Posts by numnutchris
numnutchris
Joined Sep 2009
Have you also swapped Rx:es between the helis?
numnutchris is offline Find More Posts by numnutchris
Old Aug 27, 2012, 08:53 AM
Joined May 2012
Thanks for the suggestion, didn't quite got that far. Turned out to be the switch was assigned in two functions on the TX. Guess this threw it off.
Old Aug 28, 2012, 03:25 AM
SONICX is offline
SONICX's Avatar
Joined Jul 2012
I'm not sure howlong the 7.4v 2600mha will last ,I have only charged it once
so far and it is not flat yet.I use the TX currently for Flight Simulation on PC
and testing and setting up of models.
The second photo is of my R2106GF RX for park flyers using S-FHSS.
It was fearly cheap at R395-00 SA.Sure I can get even cheaper if I shop
around abit.
I'm still networking Gauteng for the best prices and suppliers.
Only been back in RC for a few months now.
Old Sep 04, 2012, 08:25 AM
ncsky is offline
Find More Posts by ncsky
Maggie is in charge
ncsky's Avatar
United States, NC, Raleigh
Joined Nov 2011
Well, fairly new to the hobby (7 months) after 2 mail in repairs in 2 1/2 months on current transmitter (which was purchased new) I decided I'm not that deep into models yet and could move to a another brand that I think will be more reliable.
Took the plunge and ordered the 8J today. Really looking forward to this transmitter. It had a great feel for me whenI held it at a local shop.
ncsky is offline Find More Posts by ncsky
Question Airtronics FHSS-1 FHSS-2 FHSS-3 aeajr Radios 3 Mar 02, 2012 04:21 PM
Discussion Why are there no FHSS or Spektrum style vtx's? randall1959 FPV Talk 14 Sep 04, 2011 04:34 PM
For Sale Like new Futaba 6J 6-Channel 2.4GHz S-FHSS Tx/Rx(SOLD) thundercl58 Aircraft - General - Radio Equipment (FS/W) 1 May 21, 2011 05:04 PM
Discussion 2.4GHz FHSS Futaba 4YF JJ OROŅO Radios 7 Jan 28, 2010 04:08 PM
Discussion Futaba SS, is it FHSS or DSSS d_wheel Radios 36 Jan 12, 2008 09:11 AM
