Old Feb 16, 2012, 11:15 PM
3d flippin
The_MonsterMash's Avatar
United States, CA, Ontario
Joined Jan 2012
http://epbuddy.com/index.php?main_pa...roducts_id=187
i was wondering if any of you have tried this motor and will it be good for an extream flight 48" extra 300?
The_MonsterMash is offline Find More Posts by The_MonsterMash
Old Feb 21, 2012, 08:14 AM
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Which one of these greenies will make me most happy on this?
I hope it is this one
SunnySky/EP Buddy X2212-6 (~2030Kv).
[http://www.rcgroups.com/forums/showp...16&postcount=9
as I have two ordered.
These motor would be replacements for the discontinued Turnegy 2826-1900 Kv ones and perhaps be of better quality , efficiency and even a bit more powerful.
http://www.rcgroups.com/forums/showp...4&postcount=65
Charles
Old Feb 21, 2012, 06:52 PM
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Well Charles... I reckon it should do well... can you squeeze an Eagle Tree in there and get us some in-flight amp-draw/RPM data... to see how close static measurements and calculator computations come to reality?
Cheers, Phil
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Feb 21, 2012, 08:16 PM
Southern Pride
Perhaps Phil if I can remember to add a tach lead to the ESC when I finish building(?) the next one. I really should go ahead and put the air speed unit on this one and see how close the projected / calculated speed is. I know that it is over 60 MPH .
Charles
Old Feb 24, 2012, 01:25 PM
United States, NV, Las Vegas
Joined Nov 2010
Now running my SunnySky 2820-950 on 4s w/ a 13x6 Xoar electric prop. Ground tests yesterday saw max amps at 56-58, and max watts at 870. After 2-3 min of ground testing, motor was very hot to the touch, and temp readings show 140 degrees F.
These numbers are in line with factory test numbers publishd on the EP Buddy website.
Like C/F above, I've installed this motor into an Extreme Flight 48" 3D airplane.
Has anyone else out there got any experience with this motor and running it close to max capabilities? I haven't been able to find any max amps or max watts data out there anywhere.
-= GYRO =- is offline Find More Posts by -= GYRO =-
Reply With Quote  (Disabled)
Old Feb 24, 2012, 08:59 PM
Dr Kiwi's Avatar
Joined May 2003
That 2820-950 is 140g.... rule of thumb suggests 3W/g... thus max is about 420W... on 4s (let's say 13.5v under load)... that is 31A... 'nuff said!
870W through a 140g motor (6.2W/g) is close to suicide.
Old Feb 24, 2012, 09:24 PM
Joined Nov 2010
I appreciate the reply, but respectfully disagree. completely. Have you ever heard of Motrolfly? (subsonic planes)
I've got their 2820-950 (152g motor) that pulls almost 1000w on 4s... and comes down at 100F. You really outta check out their motors: http://www.subsonicplanes.com/Motrolfly_Motors.html
but seriously, the manufacturer posted test data for this motor at these watts/amps: http://epbuddy.com/index.php?main_pa...roducts_id=188
Old Feb 25, 2012, 07:27 AM
Dr Kiwi's Avatar
Joined May 2003
I have tested a lot of Motrolfly motors and found that they are very good [and the Sunnysky motors I tested were good too]... but the crucial observation in your case is that at 870W your motor got far to hot for comfort... so whatever the posted data sheets suggest (and they don't include running temperature)... your motor is not able to cope with that much power without over-heating... unless you can get plenty of airflow for cooling (and 3D is not conducive to that...in a pylon racer at 100mph you might be okay) you face the real risk of frying your motor.
Old Feb 25, 2012, 08:50 AM
Joined Nov 2010
Those are some valid points about observed temps and cooling.
I'm going to fly the plane today with this setup and will check the temp after landing. Like you said, I need to see what cooling air does.
What temp would you suggest as a "threshold"?
Old Feb 25, 2012, 12:06 PM
Dr Kiwi's Avatar
Joined May 2003
Anything approaching 60C = ~140F is really too hot... but with 3D, you won't be at WOT for extended periods so you might be okay.
Old Feb 25, 2012, 02:11 PM
Joined Nov 2010
I did my flights today to test, and was relatively agressive on the throttle. The hottest I could get the motor was 106 F on landing. So I think this motor can handle the 55a / 875w just fine.
Great motor for the price!
Old Feb 27, 2012, 01:54 PM
Southern Pride
Aircraft here
http://www.rcgroups.com/forums/showp...3&postcount=32
No in-flight loging but 2212-6 with APC E 6 X 5.5 TP Pro Power 45 3S 850.
Static 16,600 RPMs / 22.46 A / 243 watts . Eagle Tree Air Speed V3 67 MPH in level flight.
TP Pro Power 45 3S 1250 / 76 MPH in level flight but I did not take static RPMs / Amps or watts reading.
Charles
Old Mar 19, 2012, 10:48 AM
Southern Pride
I now have 36 flights, average time of 4-1/2 min. on this SunnySky/EP Buddy X2212-6 (~2030Kv) and it is doing great.. Stays very cool, screams right along with a APCE6X4 prop most flights.
Thanks for the testing Phil as I would not have found these most likely otherwise .
Charles
Old Mar 19, 2012, 02:53 PM
Dr Kiwi's Avatar
Joined May 2003
Hi Charles,
Sometimes static testing turns out to be useful!
Glad it is working out well.
Cheers, Phil
Old May 22, 2012, 09:08 PM
Ignint McNugget
Rumple's Avatar
behind Jaggi lines
Joined Jan 2004
Seems like the kv's can be quite a bit off from the manufacturer's specs on these SunnySky motors.
A while back I bought a SunnySky 2216-10 KV880, and recorded the following data:
GWS 10x6HD
11.9V 16.0A 191W 8600 rpm
11.9V 16.2A 193W 8600 rpm
GWS 9x5HD
11.3V 12.4A 140W 8900 rpm
Can anyone estimate true kv from this minimal data? It seems a bit higher than 880, but how much? Did I get a mislabeled SunnySky 2216 KV1100?
Rumple is offline Find More Posts by Rumple
Question HK F-14 fan,motor,esc question. Plus a GREAT buddy code for motors posted HydroPilot Electric Ducted Fan Jet Talk 6 Sep 10, 2011 11:25 AM
Alert HK Buddy codes -- Multicopter ESC's and Motors. Plush 18A ESC @ $8.66 ea. KKUSA Hot Online Deals 0 Sep 05, 2011 05:29 PM
Sold EP Buddy 6-pack parallel charge board split_s Aircraft - Electric - Batteries & Chargers (FS/W) 1 Sep 05, 2011 01:51 PM
Sold EP Buddy ParaBoard-XH 30A ZackJones Aircraft - Electric - Batteries & Chargers (FS/W) 2 Aug 23, 2011 10:32 AM
Discussion EP Buddy ParaBoard (Parallel Charging Board) RCFlyer43 Batteries and Chargers 10 May 22, 2011 09:50 AM
