Joined Aug 2011
Joined Aug 2011
1. wash in or Out? 2. How can make lift more backward? are them right? I think wash in is more proper in FSW. caus you know that in high Angle of attack(Aa), the wing tip should stall first in wing of this shape. then think about every section of wing in High Aa. then in washin case wing tip has more big Aa then other place. so, stall first and proper. |
Mix, got your text. My design doesn't use any forward canard wings, no fuse lex.
After experimenting with a sfw layout I finally found the angle it needed to fly as a wing, not a whole plane. I added the fuse to it all later. I use a full elevon control surface now, my first design had separate Ali and ele, my second design used the elevon mix in the radio. I happen to balance at the hinge line at the tips in my designs now because of the swept forward angle. Canards and Lex's will throw another wrench into your CG so beware. I recommend building a chuck glider(small test airframe) to test your design and finalize the CG location then proceed to the actual design and build. http://www.twitt.org/Cornelius02.gif my inspiration years ago |
Joined Aug 2011
![]() This is front view it has also anhedral I just got concept. First, this one should be fast: This is my theme of this plane. it has anhedral wing. Also, the V tail wing isn't troubled by small turbulence made by main wings and which is maximized in high velocity. (I delibratly saperated main wing and tail in front view.) Second, wing should be very strong especially twisting: in FSW wing twisting is an major problem in design. mabe I should use carbon matterials for wing rigidity. Third I should make foam test for CG. as always does. |
I like your design, look very cool. I did a FSW last year and I used a small amount of wash in, seems to work with symmetrical naca airfoils. See http://www.rcgroups.com/forums/showthread.php?t=1202354
By the way is there any chance you will share your sketch up file, I am trying to learn to use it, maybe it can will help me if I can se how you done it. |
Joined Aug 2011
wow thst's cool man! did you cut foam with yourself?
well done!~ OK this is my sketch up file and It's just sketchup NO detail save with another name! http://blogfile.paran.com/BLOG_10164...;%20Soften.skp |
deffinitely use carbon spars to alleviate twisting of the wings.
deffinitely use wash in at the root. deffinitely keep the tip at zero degrees as per the thrust line of the plane, or close to it. the whole idea of an FSW is that the tip does not stall and that the root remains flying as long as possible. when the root does stall, the tip should still remain flying becuse of its forward position and the way that lift travels down the wing towards the root. LEX's are a good addition, since they will energize the flow over the root. however, they can make the plane very pitch sensitive. you may need a close coupled canard if you go with LEX's. as suggested, make chuck gliders with and with out the LEX's and see what works best. if the LEX's work best but you find it very pitchy, add canards and see if they elliminate the pitchy behaviour. if you look at the SU above and others such as the X-29, etc, they all have canards to counteract the LEX's. I personally think you should use the LEX's, but figure out how to make them work with the airframe, instead of against you while maneuvering the plane. Rich |
| Thread Tools | |
| Discussion Clean Sweep - a 48" sportster with a swept forward wing! | tim hooper | Sport Planes | 116 | May 15, 2012 12:56 AM |
| Build Log The Frog - lifting body with canard and forward swept wing (Plans) | mardimardigras | Foamies (Scratchbuilt) | 23 | Sep 30, 2011 01:26 PM |
| Need help with airfoil design on forward swept wing... | kalare | Electric Ducted Fan Jet Talk | 2 | Dec 31, 2005 03:05 PM |
| Getting CG forward on a swept wing design | rakm | Modeling Science | 7 | Dec 23, 2002 11:03 AM |
