Old Oct 13, 2011, 12:02 PM
sam-smith is offline
Find More Posts by sam-smith
SamuelS94
UK
Joined Oct 2008
Covering a foam plane ??
I have a foam cessna, but would like to cover it to get rid of the 'foam' look, and have it so it is completely white, and looks smart.
I have never covered a plane, so what other ways of doing it are there, i was thinking solvent free spray, but would that get rid of the foam look ?
Any other opinions ?
sam-smith is offline Find More Posts by sam-smith
Old Oct 15, 2011, 06:24 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
1 - Mix light weight spackle with water till it's like heavy cream. Apply to surface filling depressions, let dry and sand smooth.
2 - Cover foam with tissue paper using Polycrylic varnish.
3 - Sand lightly and paint with any paint.
Search for 'tissue polycrylic' for details. There are 267 posts.
hoppy is offline Find More Posts by hoppy
Old Oct 15, 2011, 07:56 PM
Toysrme is offline
Find More Posts by Toysrme
Toysrme's Avatar
Birmingham, Alabama
Joined Jun 2002
exactly. not just foam, but covering jobs always look best when spackled & sanded before hand.
Toysrme is offline Find More Posts by Toysrme
Old Jan 05, 2012, 03:47 AM
RobKro is offline
Find More Posts by RobKro
Sverige, Jämtlands län, Krokom
Joined Dec 2011
Hello,
I just wrote at an other place about glassing foamies with epoxy. I always thin down the mixed epoxy with alcohol until it is as thin dope. Use 30-minute epoxy, then you have a fair workingtime. After I have glassed the foam (normaly 25gr/m2 glass) I work on with thinned epoxy with added talc. Add up to say 50% talc and there is a perfect filler, makes it easy to wetsand. Sand at the end with 600-wetpaper and now it is possible to use all kinds of paint without the risk to melt the surface or the foam.
/Rob
RobKro is offline Find More Posts by RobKro
Old Jan 07, 2012, 09:37 AM
Pinecone is offline
Find More Posts by Pinecone
Will fly for food
Maryland
Joined Sep 2004
You can also cover with a low temperature covering like Econocote.
Or you can cover with colored packing tape.
Pinecone is offline Find More Posts by Pinecone
Discussion Covering Foam vs Glassing? ForeverFlying Composites Fabrication 5 Sep 19, 2011 06:16 PM
Discussion Question about covering foam plane. Dagwood_55 Foamies (Kits) 2 Jan 19, 2010 11:34 AM
Help! covering foam plane? larry695 Beginner Training Area (Aircraft-Electric) 6 Jul 08, 2009 01:49 PM
Question Covering a foam plane? Glass it, iron-on, homebrew, silk?? _Pattern_Man Foamies (Kits) 7 Dec 22, 2006 09:16 AM
