Old Oct 13, 2011, 09:48 AM
knifeedge63 is offline
Find More Posts by knifeedge63
There is Victory in the Lord!
knifeedge63's Avatar
United States, GA, Locust Grove
Joined Feb 2011
Help!
Motor thrust angle on pylon racer
I cant seem to find out what the thrust angle i need on my Sokol. some people suggest about 2 degrees of down.. but do i need to put any right thrust in to counter act torque? I have a Sokol pylon racer with a MEGA 16/15/2 on an APC 4.1x4.1 prop. let me know if you ca help! thanks!
-Colin
knifeedge63 is offline Find More Posts by knifeedge63
Old Oct 13, 2011, 09:58 AM
sneu is offline
Find More Posts by sneu
sneu's Avatar
United States, CA, San Diego
Joined Dec 1999
Pylon racers are happy with 0-0 for down thrust and right thrust.
Steve
sneu is offline Find More Posts by sneu
Old Oct 13, 2011, 10:02 AM
Joined Feb 2011
i have been told that the sokol needs some down or else it will just climb.
Old Oct 13, 2011, 10:10 AM
arcticflyer is offline
Find More Posts by arcticflyer
arcticflyer's Avatar
Canada, SK, Prince Albert
Joined Jan 2006
knifeedge63 - I built (5) 400 class pylon racers (Slipso's) and have never put right thrust in any of them and they have flown like a "spear."
I have however put some down thrust on all of them. Do not go over 2 degrees and you should be fine. Actually I wouldn't start with anything less than 1.5. A little to much is better than not enough on the launch.
I am assuming that the Sokol is built similar in that it has zero degrees of incidence in the tail and the wing.
arcticflyer is offline Find More Posts by arcticflyer
Old Oct 13, 2011, 10:13 AM
Joined Feb 2011
yep zero incidence. so just a tiny bit of down should work?
Old Oct 13, 2011, 10:16 AM
Madbob9 is offline
Find More Posts by Madbob9
USA, CA, Moreno Valley
Joined Nov 2006
When I had one I used a down elevator to throttle mix to stop it from climbing.A little down thrust might cure it but it also may have had a wing-tail incidence problem that I never checked before it's demise.
Madbob9 is offline Find More Posts by Madbob9
Old Oct 13, 2011, 10:18 AM
Joined Feb 2011
aww thats sad to here it is no longer in being... lol
Old Oct 13, 2011, 10:59 AM
Joined Jan 2006
One of the Slipso's I built had an incidence problem....I rushed to get the Fuz done and built a possitive incidence into the tail and a possitive incidence into the wing...shame on me. I never could get that thing to fly right and eventually crashed it trying. I fixed the wing incidence and it flew marginally. Then in order to get the diving out of it I took to much down thrust out and the last toss was the "dying chicken" stall. Was actually glad when It was gone because the thing was so frustrating.
Remember...CG...will also affect climbing or diving... especially coming out of a shallow dive.
Old Oct 13, 2011, 11:12 AM
Joined Feb 2011
wheres a starting point for the CG?
Old Oct 13, 2011, 03:14 PM
Joined Jan 2006
Here's a thread on the Sokol CG... http://www.rcgroups.com/forums/showt...ol+pylon+racer
Here is another link: http://www.espritmodel.com/sokol-drawing.aspx
Old Oct 13, 2011, 09:18 PM
Joined Feb 2011
thanks guys iv finally got it figured out and the motor mount is glued in
Old Oct 14, 2011, 03:03 PM
Jabberwocky_ is offline
Find More Posts by Jabberwocky_
Jabberwocky_'s Avatar
Montreal
Joined Aug 2009
???? I'm confused; I thought the Sokol came with the motor mount already glued in. Is this not the case? Cuz I was considering a Sokol for next year. But if it doesn't have the mount already in, I'll probably go with something else. I despise gluing in motor mounts. One of my rc buddies said that his Sokol came with the motor mount already installed.
J
Jabberwocky_ is offline Find More Posts by Jabberwocky_
Old Oct 14, 2011, 03:08 PM
Joined Feb 2011
J
no i bought a second hand one it didnt have a motor mount because it was crashed. By all means though, get this model!!!! It flies amazingly! tracks straighter than rails lol! i just am re-gluing the mount in place. and you literally cannot put too much power in this thing. it handles everything like its nothing.
Discussion thrust angle on motor mount - a bit more scientific approach to offsets etc Ryleh Glow to Electric Conversions 23 May 07, 2014 06:44 PM
For Sale Sun racer pylon racer with mega motor cc esc etc....>>>>>>> ED3 Aircraft - Electric - Airplanes (FS/W) 1 Oct 13, 2011 09:50 AM
Mini-HowTo thrust angle on motor mount - a bit more scientific approach to offsets etc Ryleh Electric Plane Talk 15 Apr 04, 2011 08:16 AM
Discussion pylon motor thrust angle? tuootal Scale Sailplanes 7 Apr 28, 2010 03:58 PM
motor assist pylon thrust angle ? epkoncept Electric Sailplanes 5 Feb 08, 2002 01:07 PM
