Old May 08, 2012, 06:32 PM
Kent55 is offline
Find More Posts by Kent55
Ohio
Joined Jan 2010
All -In- All do you guys recommend this boat for Zip-Around Fun? (The water form of Bashing) or is there better ones out there in the same price range? Price range is what I'm looking at.
May be the Traxxas Blast?
Size is not a concern.
Kent55 is offline Find More Posts by Kent55
Old May 12, 2012, 07:38 AM
scorpion1 is offline
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Kent, my sons Mini is a blast for him, its basically a small DF style boat..................corners unbelievably, is hard to flip, and is pretty darn fast.............although a small hull looks faster on the water, but its still probably 25-30 mph. The ONLY thing i will give an "opinion" on as far as the overall experience, is that it is a bit small. Get to the other side of a large pond and its hard to see, plus its just more fun seeing a 25" + boat screaming around, the size comes into play a bit.
scorpion1 is offline Find More Posts by scorpion1
Old May 14, 2012, 08:15 AM
Kent55 is offline
Ohio
Joined Jan 2010
Thank you for your opinion. And yes, I think (FOR ME) and my usage, a bit larger boat will be more useful at this point. Maybe to grow my fleet in the future I will look back at this one.
FOR SPARE PARTS : http://kintecracing.com/Mini_Mono.html
Old May 22, 2012, 10:12 AM
SGecko is offline
Find More Posts by SGecko
SGecko's Avatar
United States, OH, Miamisburg
Joined Apr 2004
Originally Posted by dantt99 View Post
I can't seem to find the drain plug, where is it? Thanks!
The drain plug on my sons is on the back left side
SGecko is offline Find More Posts by SGecko
Old May 22, 2012, 10:17 AM
SGecko is offline
SGecko's Avatar
Joined Apr 2004
Tuning questions
My son and I are new to boats so I am not sure if there is an actual problem or not.
1. At full throttle the boat leans way to the right side. Is this just torque? Is there a way to correct?
2. We have to have the rudder trimmed to the right to make the boat go straight. Would the turn fins affect the trim?
Old May 22, 2012, 12:23 PM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Turn fins shouldn't effect it, unless they got bent. If you look at the boat from above, are the rudders turning left with the trim centered?
For it leaning, you can put the battery more to the left if there's room, or get a sharpened propeller for it. The sharper the prop is, the less it'll roll from torque.
wparsons is offline Find More Posts by wparsons
Old May 22, 2012, 12:51 PM
SGecko is offline
SGecko's Avatar
Joined Apr 2004
It has a single rudder and it is turning right to make the boat go straight. When the rudder is centered the boat goes left pretty aggressively.
There is no room to move the battery around.
Thanks for the help
Old May 22, 2012, 03:22 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
If you look at the rudder, is it actually straight, or is it pointing left with the trim centered?
I would look to see if the rudder is straight, and also check the turn fins to see if they were bent. Also check the trim tabs to see if one side is bent further down or not.
It makes sense that if you're having to give it right rudder to go straight that the boat would be leaning to the right, but it should run straight without right rudder input.
Old May 22, 2012, 07:10 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
I found a way to cram a 3s 2200 lipo in my son's mini.............kinda sittin diagonal inside....................gives crazy long runtimes and comes in with about 1/3 left still!
Old May 22, 2012, 07:39 PM
Alex Schauer is offline
Find More Posts by Alex Schauer
Alex Schauer's Avatar
United States, MN, North Mankato
Joined Feb 2011
How does it perform?
Alex Schauer is offline Find More Posts by Alex Schauer
Old May 22, 2012, 07:41 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Great, it likes the extra bit of weight.
Old May 22, 2012, 07:43 PM
Joined Feb 2011
Thats pretty neat!!
Does it handle...better?!
Old May 22, 2012, 07:45 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Here's a vid of my son driving it................it runs over its own wake a bunch of times and it doesnt even faze it. Its very stable and truns on a dime...............he doesnt even gun it til about halfway thru.
Watch the whole vid to see the turning ability
Aquacraft Minimono first run (1 min 6 sec)
Old May 22, 2012, 07:49 PM
Joined Feb 2011
Wow nice!!! It seems like its running a bit wet....
Also be sure to check motor temps when running that long plus it has more weight to push around. If the outside is too hot to touch then youre running too long.
This motor is An outrunner, not an inrunner, so if the outside is hot thats really not good.
Old Jun 23, 2012, 05:13 PM
Hemlock is offline
Find More Posts by Hemlock
Spring, Texas
Joined Mar 2010
Minimono
Does this boat have a revrese?
Hemlock is offline Find More Posts by Hemlock
Sold AquaCraft UL-1 Superior FE Hydro 2.4GHz RTR (Orange) MailOrderGuy Boats (FS/W) 18 Nov 02, 2011 02:02 AM
Sold Aquacraft Supervee27r brushless boat RTR reddyrightnow Boats (FS/W) 8 Sep 20, 2011 09:08 PM
Article AquaCraft Motley Crew Brushless Catamaran 2.4GHz RTR Bajora Racing Boats - Electric 4 Sep 07, 2011 09:30 PM
Cool Aquacraft's MiniMono HYDROJERRY Racing Boats - Electric 0 Aug 22, 2011 07:40 AM
Article AquaCraft SuperVee 27R Brushless RTR Boat Review Michael Heer Racing Boats - Electric 12 Dec 02, 2010 01:30 PM
