Old Dec 14, 2011, 07:38 AM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
Originally Posted by hommel View Post
To be honest, I don't think this is a poor design... I think Extreme_RC showed us that...
I agree He got wemo numbers on 6s here (link)...
I get the same amount of thrust to watts on calculated (not actual) RPMs than my wemo and SAPAC fans
It doesn't matter if he was running 12s to get the number the numbers the point is it can be done and CALCULATED rpms and amp estimates can be take from there.
The motor I'm using is slightly shorter can than an MB1 but give same thrust on 4s but comes down pretty warm...knowing that I know NOT to go to 5s on that motor with this 10 blade fan.
erh7771 is offline Find More Posts by erh7771
Old Dec 14, 2011, 08:36 AM
erh7771 is offline
Joined Nov 2005
This is exactly what I see, the thrust to watts is not as proportional as a wemo...you can't go to 6.5lbs of thrust on this fan without specially made KV motors for instance a 2250kv but for 4.5lbs of thrust (which will push a good 90mm foamie) it's good for that on 4, 5 and 6 cell motors.
Old Dec 14, 2011, 08:59 AM
JimDrew is offline
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
I think some are confusing efficiency of a fan (rotor) with efficiency of a fan system (fan/motor). If the motor is too small or Kv incorrect for the load, the efficiency of the fan (rotor) can look to be poor. So, your graph curves only represent the results with the given motor, not the efficiency of the fan (rotor) itself. To compare fan efficiencies, you would need to spin the rotors at the exact same RPMs and compare load vs. RPMs vs. thrust.
JimDrew is offline Find More Posts by JimDrew
Old Dec 14, 2011, 11:23 AM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
so how is it that mark at extremerc can run this fan on 2720kv on 6s and be fine and say its as good as a minifan and our 2700kv motor on 5s cooked, there is so much contradicting info around this fan its unbelievable
isn't this fun
jcdfrd is offline Find More Posts by jcdfrd
Old Dec 14, 2011, 12:11 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
isn't this fun
Can you point out the post where Extreme stated the motor kv he was using?
Eric B.
AirX is offline Find More Posts by AirX
Old Dec 14, 2011, 12:21 PM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
ya its in post #766, ah your right I misread his post he said on par with 2w-25 / minifan
my bad.....does anyone know what motor and kv he's using for 6s
Old Dec 14, 2011, 12:35 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
I dont know what he is running, I just did not remmember it mentioned in any post, thought I might have missed it.
Eric B.
Old Dec 14, 2011, 12:39 PM
hommel is offline
Find More Posts by hommel
hommel's Avatar
Netherlands, Zwolle
Joined Jul 2005
I would guess a made-to-order long can 1950kv HET.
The 3W25 should work well with a 6s pack, if you look back some 5 pages (stevekott) there are some results with this motor and the stock Habu 32.
@Eric, Marc kept this his secret... :-)
hommel is offline Find More Posts by hommel
Old Dec 14, 2011, 12:48 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Hi Hommel,
He is a shrewd devil eh!!!
Eric B.
Old Dec 14, 2011, 01:21 PM
erh7771 is offline
Joined Nov 2005
I did similar numbers on 2150kv
Also, what sized can did you used on the 2700kv?
Thx
Old Dec 14, 2011, 02:11 PM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
it was the ammo 28-45, not long enough. we are going to try a couple of cyclone power outrunners next, going for additional power handling, cooling and torq. just waiting on them to arrive
Old Dec 14, 2011, 04:55 PM
hommel is offline
hommel's Avatar
Netherlands, Zwolle
Joined Jul 2005
Originally Posted by AirX View Post
Hi Hommel,
Eric B.
Well, he's no dummy, that's for sure :-)
Old Dec 15, 2011, 03:48 AM
Burdo is offline
Find More Posts by Burdo
Guarantee at least one landing
Burdo's Avatar
Australia, QLD, Mooloolaba
Joined Aug 2007
Originally Posted by bamaguy View Post
I have the same concern.....This alloy Lander shroud will solve the heat problem
http://www.pw-rc.com/product_info.ph...oducts_id/2135
Does anybody know what's happened to this shroud. When I first went on the site it was there, went back and now the Product is not found?
Burdo is offline Find More Posts by Burdo
Old Dec 15, 2011, 07:10 AM
ApexAero is offline
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
http://www.hobbypartz.com/alaleldufan6.html
ApexAero is offline Find More Posts by ApexAero
Old Dec 15, 2011, 08:28 AM
alexandermh is offline
Find More Posts by alexandermh
alexandermh's Avatar
Fairborn, OH
Joined Nov 2009
Those RC Lander shrouds are real heavy.
alexandermh is offline Find More Posts by alexandermh
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7224 Apr 21, 2016 02:53 AM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
