For the record!
LOL:
+1
Heli Copter you beat me to it, I was just going to post that our numbers were actual and have smoked two motors. guys this is why I said it doesn't look promising for this fan its load is way too high for 28mm motors, however we have not given up yet two more motors on the way to try |
Here's a quote to answer your question: (Stuart Maxwell...Stumax)
"BTW, Stone, blade count means very little in absolute performance as long as you're sensible about the fan design (ie keep blade Re within usable limits). Tam's TJ120 powered Electra is a good example, another is a test we did between an SM89-45 and DS51, same model, same power, we measured the same top speed. A lot depends on how the multi blade fan is designed. You can design it for smaller exhaust diameters and get high efflux velocity and therefore very good dynamic thrust from it, but you do need to know what you're doing as the blades begin to interfere with each other and if you don't know how to deal with that the efficiency will be poor. The Chinese rip off fans are a classic example of copying something and not knowing what you're doing, their performance is way down compared to a well designed fan." |
This fan shows efficiency up to 2g/W in the lower power set ups which makes it ideal for your typical scale jet with a genuine bonus i.e. the turbofan sound. @EricB. thanks for the guideline, I more or less came to a similair conclusion, but it is always a good thing to have someone else verify own findings. Cheers, H. |
Australia, WA, Perth
Joined May 2007
If it's lower efficiency than others of the same size, doesn't that mean it is poor?
Being a relative term, it of course implies 'compared to something else'. There is no reason a well designed fan can't perform the same as a Wemo, regardless of the number of blades (per Stu's thing above). Design however costs serious time. I spent about two weeks' a while ago doing one, and that was only a first cut. |
My findings with the CS show that at very low power levels (100-300W) the efficiency in terms of g/W is better than Wemo... Keep in mind that Wemo's were designed initially for speed480 brushed motors on max 200W. From that perspective the CS should be superior to a Wemo :-). Given the right motor to my knowledge/experience so far the thrust/W curves look like this: ![]() It shows that if you are not looking for imo insane thrust numbers the CS will do very well, even better than a Wemo... |
Joined May 2007
Efficiency can't be expressed as g/w, or any other units for that matter. That confuses the issue, just like stating thrust and power without RPM. Half information and misleading assumptions.
Do you happen to know what that graph is based on? Which motor, exaust diameter etc? If that is indeed the case, the CS looks good for a parkie! |
One thing that is very clear to me in regard of the CS fan is that finding a matching motor on a given battery pack is much harder than with a Wemo or Het. The graph is based on my own findings, hardly scientifically done. But I do know for sure that the CS fan initially puts out more thrust/W and drops off quickly if pushed further. Where the 2 curves cross, I don't know yet, but guestimated I would say somewhere around the 800W for the best optimized fan/motor combo. The only point I try to make is that the CS is a very good fan for certain applications, top speed probably not being one of them, agreed! I think Mark (Extreme_RC) tried some modifications on blade width on the CS fan in order to be able to push it further than the stock one. And without a doubt, if Wemo put some effort in this they will come up with a similar, probably better performing fan on high power set-ups. |
Joined Nov 2005
It's very close, you have to calculate the RPM correctly or you'll get not so good results. I've had almost 10 flights with my set up and have not smoked the motor and the performance is no different from SAPAC... My results have been very close, extreme_rc showed earlier on 6s his 10 blade with his shroud is nearly identical to a wemo watts to thrust Also, I don't see many people giving amps AND volts along with watts....if your setup isn't giving the thrust to watts you have to look at the volts also...if your pack is sagging that's going to affect thrust. I'll give up 100 watts or so to be able to do dual 70mm setups without them sounding like fighting bees in the air or having to by over 200 dollars in fans |
| Thread Tools | |
| New Product Change Sun 12 blade 90mm | Flip Flop | Electric Ducted Fan Jet Talk | 6509 | Jun 18, 2013 07:39 PM |
| New Product Change Sun 120mm and new 10 blade 70mm fans | Flip Flop | Electric Ducted Fan Jet Talk | 131 | Apr 27, 2012 07:07 PM |
| Sold Change Sun electric retracts | Flip Flop | Aircraft - Electric - Jets (FS/W) | 3 | May 23, 2011 06:20 AM |
| Sold Change Sun Electronic retracts w/Lander struts | hole digger | Aircraft - Electric - Jets (FS/W) | 2 | May 06, 2011 01:27 PM |
| Sold Change Sun Electric retracts NIB 75.00 | jzuniga | Aircraft - Electric - Jets (FS/W) | 2 | Sep 03, 2010 09:36 AM |
