Old Dec 12, 2011, 12:54 PM
Steph280 is offline
Find More Posts by Steph280
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
Can't blame the fan for motor burning when it's ran past the max spec. Remember you need to find a lower KV motor. Just because the motor worked in Wemo/HET/EFlite fan doesn't mean it will work here. The load is higher so you need to select motor/battery accordingly.
Steph280 is offline Find More Posts by Steph280
Old Dec 12, 2011, 01:00 PM
Thomas Nelson is offline
Find More Posts by Thomas Nelson
Thomas Nelson's Avatar
Calgary, Alberta, Canada
Joined Sep 2002
Hey erh7771
Is this the motor you are using? HK advertises it as 2800kv in one place and 3800kv in another! I'm wondering if you've tested it and found that it's actually 3000kv?
I'm thinking it might be a good replacement for my uberlight Twister on 3S, with a Mega 16-15-2 and Minifan combo; aiming for 45 amps or so on the CS 10 fan.
Thoughts?
tn
Originally Posted by erh7771 View Post
I get 52oz of thrust at 67 amps on 4s with this fan using a 2839 3000kv HK motor.
Thomas Nelson is offline Find More Posts by Thomas Nelson
Old Dec 12, 2011, 01:12 PM
Flazo is offline
Find More Posts by Flazo
JUNK RADIO
Flazo's Avatar
USA, NY, Queens
Joined Dec 2006
alexman
Originally Posted by alexandermh View Post
[Im starting to wonder is this fan worth it???? Sounds great, but smoke, and poor performance???]
That's probably too much of a generalization. I think guys are just trying to find the "sweet" spot for a 4S, 5S, etc. set-up. We've never had to deal with a 10 blade 70mm before. Extreme RC is getting some good results with their modified version.
This is wonderful we are all working to get the best performance and some are using this blades already...
Js-1400, is about 4000kv...
Fred
Flazo is offline Find More Posts by Flazo
Old Dec 12, 2011, 01:15 PM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
Originally Posted by Thomas Nelson View Post
Hey erh7771
Thoughts?
tn
Here's the motor I'm using (link), great middle of the road motor IMHO.
For > 4.5lbs of thrust on this rotor you have to spin it around 47000 calculated rpms (KV x volts). For 5s the KV should be 2700kv (2700kv x 18volts) with a stronger battery for the uptick in amps but I wouldn't do anything less than a long can motor.
HK has a 2900kv 2858 motor (here) that is 18usd and worth trying out if they every get it back in stock.
Hobby Partz sells a 2618kv motor that is 58mm long also for 21usd
Any shorter than 58mm (the can length of an ARC) might just be wasted WANTED energy in the form of heat and lower thrust
erh7771 is online now Find More Posts by erh7771
Old Dec 12, 2011, 02:10 PM
Joined Sep 2002
Thanks!
Is there any chance you have a 3S pack you could use on your 3000kv motor to determine amps drawn at WOT? To keep my Twister light I'm flying 3S ...
Sorry to be a pest, and no harm, no foul if it's not convenient to run another test.
tn
Old Dec 12, 2011, 02:13 PM
Joined Sep 2002
Kevin!
Nice F4 and nice skillz!
tn
Originally Posted by Kevin Cox View Post
I just test flew my old scratch-built F-4E on the CS 70mm 10. I used the HobbyKing/Turnigy XK-2860-B (2200kV) on 6S 3000mAh packs. The bench test yielded about 73 amps on a 6S 3700mAh pack. I wanted to try 5S but I don't have a pack in that configuration that would fit in my F-4.
The model had the whoosh sound and flew very well the airframe is noisy anyway but it sounded much better. I could not get a camera man on this trip and the weather was perfect, for this time of year, so I just flew it. I will post installed amp readings tomorrow.
Old Dec 12, 2011, 04:49 PM
delperena is offline
Find More Posts by delperena
Joined Feb 2006
Originally Posted by MagnusEl View Post
They use thread lock on the spinner/nut. If you have a soldering iron on 100W or more, just use it a short time on the spinner and you should be able to unscrew it. I did ruin a perfectly good screwdriver on my first try, (without heat..) used a CDrom rail shaft grinded to perfect fit on second try and that worked.
Thanks, MagnusEl. It works perfectly.
delperena is offline Find More Posts by delperena
Old Dec 13, 2011, 01:34 PM
420flyboy is offline
Find More Posts by 420flyboy
Mile High EDF
420flyboy's Avatar
United States, CO, Denver
Joined Jul 2011
Just got the HK Turnigy L2855-2800 EDF Outrunner (630w)
Just ran it in a sapac 70mm shroud with a 4s 3000 mah, sounded great and made a lot of thrust, now I'll have to hook it up to the watt meter to really see what it does. Then maybe it's into a foam habu to see and hear it in flight.
This is the motor I'm using
http://www.hobbyking.com/hobbyking/s...dProduct=18543
420flyboy is offline Find More Posts by 420flyboy
Old Dec 13, 2011, 02:20 PM
alexandermh is offline
Find More Posts by alexandermh
alexandermh's Avatar
Fairborn, OH
Joined Nov 2009
I'll be interested to see what the watts and amps are. It seems a number of guys are pushing their motors beyond their rate with this fan (with the expected shortened life).
alexandermh is offline Find More Posts by alexandermh
Old Dec 13, 2011, 02:21 PM
Michael Paxton is offline
Find More Posts by Michael Paxton
Hey Ya'll!! Watch THIS!!
Michael Paxton's Avatar
Nashville TN.
Joined Mar 2006
Not me!! I'm pushing my batteries! LOL
Michael Paxton is offline Find More Posts by Michael Paxton
Old Dec 13, 2011, 02:33 PM
hommel is offline
Find More Posts by hommel
hommel's Avatar
Netherlands, Zwolle
Joined Jul 2005
Well, not all of us...
I'd be quite happy ending up with a sub 1kW set up pushing 1.5 kg :-)
hommel is offline Find More Posts by hommel
Old Dec 13, 2011, 03:18 PM
Nashville TN.
Joined Mar 2006
Surely someone has an ARC 28-48-1.5!! That would probably be the ticket.
(Altho....for some reason...My Eflite 3600K and 25C GensAce 2500's are seeming to be very happy! And I can't ask for a nicer, faster setup)
Old Dec 13, 2011, 03:45 PM
Dave Grife is offline
Find More Posts by Dave Grife
Dave Grife's Avatar
Coldwater, Mi. USA
Joined Jul 2000
Hey Guys,
I have a few of these fans being shipped to me now.
I'm running an Arc 28-58-1, on a 5 cell 3300mah 40 C lipos now.
It's in a wemotec 480 fan pro driving my retract equip. foam habu.
This combo gives me about 1200 watts.
I'd like to keep using my 5 cell packs and just change the motor for the new Change-Sun 70mm fan.
I'd like to keep the max current below 80 amps.
Any suggestions for a motor that will not drop performance ???
-DG
p.s. I have a habu32 stock motor that I plan on trying first.
Dave Grife is offline Find More Posts by Dave Grife
Old Dec 13, 2011, 04:04 PM
Nashville TN.
Joined Mar 2006
The Habu motor will be between 55 to 65 amps and around 1k watts if you have better batteries than what I tested with. (Cheap 3300 30C from Hobby Lobby)
On 6S I got 68 amps and 1400 watts. No thrust measuring equipment.
The problem is that this fan will almost certainly take more watts to make the same power (Thrust/speed) as your Minifan. This fan is about the sound. There is not enough design to the blades to be a mini Stu fan. But it will sound good.
Old Dec 13, 2011, 06:58 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
Hommel,
Go with a 2500 kv motor of your choice on 4s, just make sure that the motor mass is ~140-150gr to handle heat issues.
Et al the byproduct of heavier motor is that it is either larger diameter or it is longer providing a stinger magnetic field to handle the fans load making it more efficient. There is no getting more from a motor that is too small even if the kv is right.
I really wonder how many people here in this thread measure the rpm the fan turns or just calculating it because they do themselves and others a disservice by giving misleading information. Basically there is no way the average short can 28mm motor could turn this fan 40000 rpm much less 35000rpm without smoking. I think this is what ERH7771 is trying to say in some of his posts.
Cheers,
Eric B.
AirX is offline Find More Posts by AirX
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7224 Apr 21, 2016 02:53 AM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
