Old Dec 12, 2011, 10:39 AM
Jetsom is offline
Find More Posts by Jetsom
Formerly "Heli Copter"
Jetsom's Avatar
United States, CA, Watsonville
Joined Apr 2009
Some new numbers!
Hey Guys,
In a 5S stock ParkZone Habu I fried the stock motor on takeoff with the CS 10/70. When it gave up I was running 134 Amps, 2300 watts and 44,400 rpm's.
The sound was great for 30 seconds, sorry I don't have any video. Figuring the kv was too high, I went to a 2700kv Ammo inrunner. Here is the video of that attempt with the numbers in the video description. It sounded great but slow!
Change Sun 70mm with 2700kv Ammo inrunner. (2 min 38 sec)
Jetsom is offline Find More Posts by Jetsom
Old Dec 12, 2011, 10:57 AM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
Originally Posted by Heli Copter View Post
Hey Guys,
http://www.youtube.com/watch?v=_97ZfNo-rQ0
Was this 4s or 5s?
Also, what was the thrust figures with the ammo motor?
erh7771 is offline Find More Posts by erh7771
Old Dec 12, 2011, 11:04 AM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
Nick
do you remember the rpm and amp draw with the 2700kv ammo motor
jcdfrd is offline Find More Posts by jcdfrd
Old Dec 12, 2011, 11:09 AM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
Originally Posted by erh7771 View Post
Was this 4s or 5s?
erh
it was 5s and did you see the take off? their was no thrust it was pitiful the thing barely took off. I will let nick come in with the rpm,amp,watts but if my memory serves me I think it was 39k,1800watts,85amps
Old Dec 12, 2011, 11:13 AM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
ok my bad, it helps to be able to read LOL
5S nanotech 4500mah, 35-70C. 85 Amps, 1450 watts, 39,000rpms.
so I got two out of three
Old Dec 12, 2011, 11:16 AM
erh7771 is offline
Joined Nov 2005
Originally Posted by jcdfrd View Post
erh
I want thrust numbers, I haven't dealt with AMMO motors but the can size is 45mm IIRC on the 2700kv. An ARC is 58mm long for the 3200kv, can size makes a difference in whether or not the motor is producing heat or RPMs at certain wattages.
I get 52oz of thrust at 67 amps on 4s with this fan using a 2839 3000kv HK motor.
Old Dec 12, 2011, 11:40 AM
g8dget is offline
Find More Posts by g8dget
RC addict
Melbourne
Joined Sep 2004
Hey guys, Anyone tried a Het 2W-20 setup with this fan? I tried one in a Dynam Meteor, Stock fan with CS blades. Motor got hot, melted the motor mount a bit which caused the blades to rub a hole in the side of the fan. This added resistance probably killed the motor.
Using the Stock motor from the Dynam Meteor with the CS fan and it works really well now.
However, i would like to try this on the HET 2w-20 motor in a HET fan housing but with the Change Sun blades. Anyone can give me a heads up on what to expect?
Thanks guys.
g8dget is offline Find More Posts by g8dget
Old Dec 12, 2011, 11:44 AM
Steph280 is offline
Find More Posts by Steph280
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
2w-20 is probably good for 3S with this fan. 4s will be too hot.
Steph280 is offline Find More Posts by Steph280
Old Dec 12, 2011, 11:45 AM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
sorry no thrust numbers, just what you see on the video take off. about 50% less than stock setup on same power 5s
Old Dec 12, 2011, 11:49 AM
alexandermh is offline
Find More Posts by alexandermh
alexandermh's Avatar
Fairborn, OH
Joined Nov 2009
Originally Posted by rfodor View Post
The ARC is 3180 KV, I think a 2900 - 3000 kv motor on 4S (with a battery that can supply all the power the motor wants) would be about right you should get about 35000 RPM at around 80 -90 amps. Around 1300 watts. Don't even think about 5S with the 2900 kv motor in this fan. In a SAPAC, WEMO, HET fan 5S would be fine but not the CS10.
Thanks for the input. I'll put this setup together and give it a try.
alexandermh is offline Find More Posts by alexandermh
Old Dec 12, 2011, 11:50 AM
Flazo is offline
Find More Posts by Flazo
JUNK RADIO
Flazo's Avatar
USA, NY, Queens
Joined Dec 2006
The JS-1400 can run a 5cells lipo on a HET 6904...
Anybody running the JS-1400 on this fan?
red
Flazo is offline Find More Posts by Flazo
Old Dec 12, 2011, 11:59 AM
Fairborn, OH
Joined Nov 2009
red
But that's a 4000KV motor, right? Way too hot for this fan.
Old Dec 12, 2011, 12:35 PM
capt soap is offline
Find More Posts by capt soap
capt soap's Avatar
dallas tx
Joined Jun 2003
Im starting to wonder is this fan worth it???? Sounds great, but smoke, and poor performance???
capt soap is offline Find More Posts by capt soap
Old Dec 12, 2011, 12:51 PM
bamaguy is offline
Find More Posts by bamaguy
Don't Move I've Dropped My Nut
bamaguy's Avatar
United States, AL, Huntsville
Joined Feb 2009
[QUOTE=Heli Copter;20118851]Hey Guys,
At those high readings, it's no wonder the motor burnt up!!! That motor (unless it is the BL-32) is rated at 55amps/850watts.
bamaguy is offline Find More Posts by bamaguy
Old Dec 12, 2011, 12:53 PM
Fairborn, OH
Joined Nov 2009
[Im starting to wonder is this fan worth it???? Sounds great, but smoke, and poor performance???]
That's probably too much of a generalization. I think guys are just trying to find the "sweet" spot for a 4S, 5S, etc. set-up. We've never had to deal with a 10 blade 70mm before. Extreme RC is getting some good results with their modified version.
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7232 Jun 06, 2016 02:40 AM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
