I have a Kamdax M2000 which came with this plastic card. I had no idea what it was for then finally read a few threads which pointed out what it did and where it went. Because the M200 has a twin intake setup it was a fence to assist with the air flow going into the fan. Your F-16 must be pretty hard core to need carbon spars from wingtip to wingtip. Very nice..... |
I would try the 2300kv on 5S and I think you'll be much happier. I ran a 2800kv on 4S which hit that sweet spot for me....I have sacrificed speed for sound, but was the trade off I wanted ![]() We also have to remember that this is not an extensively developed EDF which will produce a great amount of thrust like a Stumax (for example). Trying to spin this fan too fast and some serious precautions need to be taken. ![]() Not sure whether I read it in his thread or the CS 90mm thread, but someone has already had a blade break off at high rpm. Luckily no-one was injured...
http://www.windrider.com.hk/products...161456spec.jpg |
Guess we`ll just have to find the specs ourselves as usual.
Latest blog entry: EDF, My First Six Years, mostly Pictures
Thanks. Looked at Post 649. The Turnigy L2855 2800KV motor referenced in that post is an outrunner, rated only for 4S and 630W. The Velocity 2900KV motor is rated up to 24v, and 1900 watts burst on 6s lipo. So it sounds like the Velocity motor would have some "headroom" at 5S, and maybe give me closer to 1000W, at below 100A (just wagging here).
Atlanta, GA
Joined Feb 2009
Joined Feb 2006
EDF Motors: Application Versus Specification
Gentlemen:
I am impressed with the expertise and significant contributions of the RC Group in the advancement of the hobby. Just one concern - I have noted many EDF Motor applications that go beyond manufacturers' specifications. Example: Turnigy XK2860-B-2200KV rated for 45A Max, 11.1V Max, 500W Max set up (application) on a ChangeSun 70mm 10 blades fan on 6S 3000 mAh at 73A. Apparently, this is a successful system (for how long?). Yet, when I operated a combo/factory balanced ChangeSun 90/5 blades at 6s 5000 mAh, the motor smoked. Same battery/ESC (Hobbywing 100A Opto) system worked very well on WM Midi/ARC 3665-1 (balanced by Extreme RC). Is this a case of "You get what you pay for" or did I happen to get a lemon from a good bunch? I am for spending less, but I believe successful operation is paramount. One other question: How do you remove the motor from a CS90 fan. I tried debonder, so far unsuccessfully. I am considering applying heat but it may distort the fan. Any tips? |
Joined Nov 2005
You can go beyond specs if you can keep things cool, that's why my testing always includes a heat test after 45 seconds of WOT to see if the motor is holding heat. Quote:
HK sells some medium can 1800kv motors that will replace the one burnt out and should run cool. |
Joined Feb 2006
Motor Removal
I was not very clear in my motor removal problem from a CS90mm EDF combo. What I feel to be a logical start is to unscrew the spinner - does not budge even after applying a debonder.
I am thinking of a tool that will give me a good leverage. The rods I have used bent like spaghetti. The tool will be a "U" with an opening slightly larger than the spinner diameter. The "U" ....... now, I see many options. I am sure, you guys have done this with better results. |
They use thread lock on the spinner/nut. If you have a soldering iron on 100W or more, just use it a short time on the spinner and you should be able to unscrew it. I did ruin a perfectly good screwdriver on my first try, (without heat..
) used a CDrom rail shaft grinded to perfect fit on second try and that worked.
| Thread Tools | |
| New Product Change Sun 12 blade 90mm | Flip Flop | Electric Ducted Fan Jet Talk | 6422 | Today 04:00 AM |
| New Product Change Sun 120mm and new 10 blade 70mm fans | Flip Flop | Electric Ducted Fan Jet Talk | 131 | Apr 27, 2012 07:07 PM |
| Sold Change Sun electric retracts | Flip Flop | Aircraft - Electric - Jets (FS/W) | 3 | May 23, 2011 06:20 AM |
| Sold Change Sun Electronic retracts w/Lander struts | hole digger | Aircraft - Electric - Jets (FS/W) | 2 | May 06, 2011 01:27 PM |
| Sold Change Sun Electric retracts NIB 75.00 | jzuniga | Aircraft - Electric - Jets (FS/W) | 2 | Sep 03, 2010 09:36 AM |
