Greece, Attica, Athens
Joined May 2011
You would have been better off running the l2855-2800kv or the L2226-3000kv if you are after a low-cost motor. |
Nederland, NB, Waalwijk
Joined Sep 2006
I finally found a jet that works to my liking with this fan. My other jets have fairly restrictive ducting that did not work well with the CS fan. This straight through ducting of the Lip 20 works very nicely. It's a fairly low power setup with 2300Kv motor on 4S, but fast enough for now.
Enjoy! |
Cheers |
Joined Sep 2006
Thanks, its indeed a fun plane to fly. I stil have a lot of work to do on it. Sanding, painting, detailing etc... Check www.rbckits.com for this and other nice kits.
Joined May 2011
http://www.x-flight.com.hk/index.php...&more=&lang=en |
Joined Nov 2005
I fly that same setup on twin 5s, push's planes along nicely and doesn't heat up to bad either. I was only pulling around 38 amps max on 4s with that setup... Really nice |
Joined Sep 2006
I have to open up the thrust tube a little more because the thrust is very low at the moment. Vertical climbs don't go very high. I am painting the model now to look a lot more scale. |
Madison, MS
Joined Oct 2006
Forgive me if it's already been brought up but do y'all know anything about this fan?
http://www.x-flight.com.hk/index.php...more=&lang=en# |
| Thread Tools | |
| New Product Change Sun 12 blade 90mm | Flip Flop | Electric Ducted Fan Jet Talk | 6422 | Today 04:00 AM |
| New Product Change Sun 120mm and new 10 blade 70mm fans | Flip Flop | Electric Ducted Fan Jet Talk | 131 | Apr 27, 2012 07:07 PM |
| Sold Change Sun electric retracts | Flip Flop | Aircraft - Electric - Jets (FS/W) | 3 | May 23, 2011 06:20 AM |
| Sold Change Sun Electronic retracts w/Lander struts | hole digger | Aircraft - Electric - Jets (FS/W) | 2 | May 06, 2011 01:27 PM |
| Sold Change Sun Electric retracts NIB 75.00 | jzuniga | Aircraft - Electric - Jets (FS/W) | 2 | Sep 03, 2010 09:36 AM |
