Old Feb 03, 2013, 07:44 PM
chas650r is offline
Find More Posts by chas650r
chuck
santa barbara, CA
Joined May 2009
Originally Posted by PeterVRC View Post
1) are all the 12blade housings the larger id in the motor mount?
There is only one housing type as far as I have seen, and it is a large diameter (29mm, or even 30mm really) so it can fit all current 28mm motor types (eg CyclonePower inrunners of 29mm)
thanks, and that is larger than the 10blade housing, correct?
chas650r is offline Find More Posts by chas650r
Old Feb 03, 2013, 08:18 PM
SKYRYDER1000 is offline
Find More Posts by SKYRYDER1000
SKYRYDER1000's Avatar
NEW JERSEY U.S.A.
Joined Mar 2010
Originally Posted by WhalleyB0Y View Post
I am waiting on a pair of these to arrive in the mail. I will be testing them in CS12's for use on 4s and 5s. If they work out I will use them in my Projet A10. It's likely that I would post my results in the CS12 forum.
If anyone else has numbers on this setup I would also like to see them.
I just ran up my 2w-23 on 4s in the ducts of a Starmax F-15.
62.2 amps / 939.5 watts (peak)
57.6 amps / 846.3 watts (setteled)
SKYRYDER1000 is offline Find More Posts by SKYRYDER1000
Old Feb 03, 2013, 09:10 PM
WhalleyB0Y is offline
Find More Posts by WhalleyB0Y
WhalleyB0Y's Avatar
Canada, BC, Fort Langley
Joined Jul 2011
I am pulling roughly 1000 watts @ 75A with 4s, 2w23, cs12-70
WhalleyB0Y is offline Find More Posts by WhalleyB0Y
Old Feb 04, 2013, 11:29 AM
NEW JERSEY U.S.A.
Joined Mar 2010
Somewhat of a difference from the 10blade to 12blade rotor using the same motor.
What size pack did you use and what c rating? I used a 4s Sky lipo 3300mah 30-60c.
Was your test a bench test or in AC?
Old Feb 04, 2013, 01:31 PM
WhalleyB0Y's Avatar
Joined Jul 2011
I used 4s 3500mAh 30C packs on the bench with the inlet lip. I just set them into the aircraft with 90% fsa tubes so I might get different numbers now. We will see.
Old Feb 04, 2013, 05:43 PM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
The 2W23 is a 1000w motor, but on 5s, so be careful of the amp draw, you dont want to cook it in warm weather. 2W25 is a better choice.
Extreme_RC is offline Find More Posts by Extreme_RC
Old Feb 04, 2013, 09:32 PM
Dirty Dee is offline
Find More Posts by Dirty Dee
Dirty Dee's Avatar
United States, IL, Northbrook
Joined Sep 2011
Those using the Turnigy L2855-2800, do you use a standoff when mounting it to the housing, or do you feed the wires through the front/dremel hole at the front?
Dirty Dee is offline Find More Posts by Dirty Dee
Old Feb 04, 2013, 10:02 PM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
Yes, modify the hole to suit the wiring of outrunners.
PeterVRC is offline Find More Posts by PeterVRC
Old Feb 05, 2013, 05:18 AM
4stripes is online now
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
I'm using the 2855 2100 and dremel one of the side slots for the motor wires.
Also using the shroud from the 12 blade as it has more motor clearance and better stators.
4stripes is online now Find More Posts by 4stripes
Old Feb 05, 2013, 05:32 AM
mopetista is offline
Find More Posts by mopetista
Vienna, Austria
Joined Apr 2007
outrunner wires: out in the direct way, down and to the front
...and then I'm drilling a hole in the shroud so I can get the wires out directly.
choose the position of the wires such that it doesn't interfere with the airflow over the vanes - they should be in-between.
put some shrink wrap over the wires to reduce drag
my2c
mopetista is offline Find More Posts by mopetista
Old Feb 05, 2013, 10:15 AM
WhalleyB0Y's Avatar
Joined Jul 2011
Do you mean 1000w on 5s, with a 10-12 blade rotor? This is partially why I reduced my setup to 4s and stuck with the 2950kv to keep with some decent rpm's.
Old Feb 05, 2013, 11:28 AM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
yes the cs70/12 housing is far superior to the cs 70/10 housing
for guys that want to upgrade there 10blade housings to the 12 blade housing you can get just the housing only here
http://www.tamjets.com/original/prod...07754808e13c8a
jcdfrd is offline Find More Posts by jcdfrd
Old Feb 05, 2013, 05:01 PM
Extreme_RC's Avatar
Australia
Joined Mar 2006
No the 2W23 was originally set up in the HET fan and rated for 30 sec WOT in their paperwork.
Point is a motor is rated to X amps, so thats what you need to work with, if you are pulling 60A on 4s then you are a little above the motors rated amps already, it will get hot if run WOT all the time and you need to be mindful of overheating it in warm weather. Certainly dont try running it on 5s!
Old Feb 05, 2013, 08:12 PM
WhalleyB0Y's Avatar
Joined Jul 2011
Thanks, I appreciate the feedback on this setup. I had a heck of a time trying to decide on which motor to use and I really hope these ones works out. From what I was hearing, 3000kv is the sweet spot for these fans on 4s and there isn't a lot of good motors in that kv range to choose from. I have been running a different lesser quality 2950kv motor in a 10 blade on 5s without any problems so I figured I would be safe with these Het's on 4s seeing how they are considered to be of excellent quality.
Description:
Old Feb 06, 2013, 08:12 AM
T-BONEZ is offline
Find More Posts by T-BONEZ
Joined Jun 2007
thanks petervrc, anlucas, odysis, 4stripes,
i loaded the intake lip and it was a world of difference!
i got my dream values of 1.3-1.4kg thrust with 63amps.
Thanks for the advice! Hard to believe that a simple piece of plastic can make so much difference!
I wasn;t expecting a high suction so i was hovering my hand at the intake to feel the suction. And zoom, my hand got stuck at the inlet....
This fan is a magnificent fan... truly a power house... thanks for all the assistance and advices!
T-BONEZ is offline Find More Posts by T-BONEZ
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7289 Sep 27, 2016 01:24 AM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
