Old Jan 22, 2013, 03:59 AM
sikky is offline
Find More Posts by sikky
speedin n da weeds :)
sikky's Avatar
USA, AZ, Glendale
Joined Feb 2008
erh7771 | 27/11/2011
5lbs of bench thrust SETTLED, 80 amps, 4s 25c 3700mah Rhinos. 6.5lbs of bench thrus SETTLE the peak stuff), 100amps on 5s usin 30c 5000m pack...did not hold heat on 10- 20 sec runs. Fan starmax fan, well balance with metal spinner W REALLY nice about th motor is it's weight or la with the starmax fan its 10oz total, it's also an outrunner...keeps magnets a little cooler IMHO
Try this one yet? I know you know you hav the parts...
sikky is offline Find More Posts by sikky
Old Jan 22, 2013, 10:49 AM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
Originally Posted by sikky View Post
That 2100kv will smoke on 6s... Edfhobbies 90mm 5s 2400kv 32mm 5mm shaft outrunner looks good for 6s... tams shaft adapters in a het fan shroud "stand off" wood spacer with a added 5mm bear 450 heli 5mm main shaft $70 I have the shrouds ... standoff knive liddle style...
which 2100kv motor are you referring to?
jcdfrd is offline Find More Posts by jcdfrd
Old Jan 22, 2013, 12:44 PM
sikky is offline
sikky's Avatar
USA, AZ, Glendale
Joined Feb 2008
Posted in wrong thread then copy pasted
Old Jan 22, 2013, 12:58 PM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
Old Jan 22, 2013, 05:47 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
Just got two new CS70-10 with the collet adapters. The rotor is unchanged and the washers are there to capture the rotor in between.
Eric B.
AirX is offline Find More Posts by AirX
Old Jan 23, 2013, 04:44 AM
sikky is offline
sikky's Avatar
USA, AZ, Glendale
Joined Feb 2008
Pics?
Old Jan 23, 2013, 06:25 AM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
My set looks just like the parts that X-flight shows on thier website.
Maybe tonight when I return home from work I will snap a pic or two.
Eric B.
Old Jan 23, 2013, 07:34 PM
sikky is offline
sikky's Avatar
USA, AZ, Glendale
Joined Feb 2008
Thanks, I like that setup better than the grub screws..
Old Jan 23, 2013, 11:17 PM
Ispintechno is offline
Find More Posts by Ispintechno
Defender of the park sky
Ispintechno's Avatar
London, ON Canada
Joined Nov 2009
Eric B.
Where did you get those? I'm having an issue with the grub screws slipping. I hate it.
Ispintechno is offline Find More Posts by Ispintechno
Old Jan 24, 2013, 06:22 AM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
The new adapters come with the new fans from X-Flight. I have not put it together yet so I cant comment on how well it works.
Eric B.
Old Jan 24, 2013, 09:24 AM
v8truckin is offline
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
So what was the problem with old adapters? I have an early version CS10 that I never did use and plan on using, should I order a new adapter? Tried searching the thread but didn't find any indication of a problem...
v8truckin is offline Find More Posts by v8truckin
Old Jan 24, 2013, 09:33 AM
anlucas is offline
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
May be tricky to center properly on some undersize motor shafts - some later batches were also not drilled and cleaned properly.
Out of the 15 or so of mine, only 3 had a problem.
anlucas is offline Find More Posts by anlucas
Old Jan 24, 2013, 09:53 AM
chas650r is offline
Find More Posts by chas650r
chuck
santa barbara, CA
Joined May 2009
imo , the collet style adapters have there own set of issues also. although they may clamp tightly around the shaft close to the motor , if the shaft is undersized or the collet oversize , the area near the end of the shaft can move independent of the rear, as they do not clamp down fully except in the area near the motor. this can make for some inconsistent balancing to say the least.
with a small flat on the shaft i have had no issues w/ the set screw type slipping, centering can be a whole other deal though.
chuck.
chas650r is offline Find More Posts by chas650r
Old Jan 24, 2013, 03:53 PM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
Screw adaptors would be the best.... and you should have ones that are a snug fit, or fractionally too tight (heat them to fit then).
Well, I guess then you better also have decent made ones.... hole centred.... straight... etc.
Which probably not too much Chinese stuff is highly accurate at all.....
So that means to be sure, you almost have to buy a decent made after-market one. (ExtremeRC or Tamjets).
But if you have the ability, first try the stock one and assess that statically, and then test it dynamically, and it could be fine (or fine enough).
Motor flats....no flats..... I have never had one come loose anyway. If you do them up correctly, and use loctite, they seem totally fine long term.
PeterVRC is offline Find More Posts by PeterVRC
Old Jan 24, 2013, 04:00 PM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
nothing like having True Precision parts
http://www.tamjets.com/original/prod...roducts_id=708
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7243 Jul 18, 2016 07:09 PM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
