Old Jan 21, 2013, 02:11 PM
sikky is offline
Find More Posts by sikky
speedin n da weeds :)
sikky's Avatar
USA, AZ, Glendale
Joined Feb 2008
Would the ARC-28-48-2 2170kv be a good bl32 replacement? ARC-28-37-3 2500kv looks like a 5s , maybe a ARC-28-37-2.5 2800... anyone test any of these?
sikky is offline Find More Posts by sikky
Old Jan 21, 2013, 04:55 PM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
The 2848-2 should work fine up to 6s, but the HET 2W30 is likely a better choice, its been well tested and its a tough long can motor.
Extreme_RC is offline Find More Posts by Extreme_RC
Old Jan 21, 2013, 06:33 PM
sikky is offline
sikky's Avatar
USA, AZ, Glendale
Joined Feb 2008
i'd be better off with a bl-32 price is a factor.... Arc motors are strong motors ,eazy to find also used...bl32 go fast!!
Old Jan 21, 2013, 07:14 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
Sikky
not sure if you know this but it is a critical factor to consider
one diff between these motors your talking about is the shaft size, the het and arc motors your discussing are 3.17mm, the bl32 is 5mm............larger is better especially on 5 or 6s setups.........dont use any 3.17mm shaft motor if your are going to run 6s IMO!!
are you going to balance the fan yourself or are you planning on buying a prebuilt and balanced edf unit? what pieces do you have already? how much is your time worth? it can take hours to assemble and balance an edf unit properly even if you know how to do it. buying the right parts can make this easy, buying the wrong parts can make it impossible.
jcdfrd is offline Find More Posts by jcdfrd
Old Jan 21, 2013, 07:17 PM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
The HET2W30 have 4mm now.
But 5mm is even better!!
Except, you will need to buy an aftermarket 5mm shaft adaptor then.
The smaller the shaft the better you better balance the rotor! 3.17mm is painful... weak.
PeterVRC is offline Find More Posts by PeterVRC
Old Jan 21, 2013, 07:27 PM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
thanks Peter thats good to know, 4mm is much better
Old Jan 21, 2013, 07:30 PM
Extreme_RC's Avatar
Australia
Joined Mar 2006
Yup the 2W30 are all 4mm shaft now, and the new shaft adapters coming with the CS fans seem to be much better than the old ones, they are now collet style, I will try one out this week as I have the CS12 rotors and spinners on hand to test as well.
Price, well I can ship a 2W30 to the USA for AUD$83.00, and it will run with the stock 4mm collet adapter, the BL32 is around 72 bucks right? plus an adapter at 12+ and shipping, gonna be 90 bucks or more, then you gotta compare the figures too, doesnt the BL32 pull a few more amps than the 2W30 on 6s?
Old Jan 21, 2013, 07:31 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
I am sure he mean't "Thelarger the shaft the better..."
Eric B.
AirX is offline Find More Posts by AirX
Old Jan 21, 2013, 07:37 PM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
"better you better"
read it again Eric lol!!! I think I read it three times before comprehension set in
Old Jan 21, 2013, 07:38 PM
PeterVRC is offline
Joined Nov 2006
oops yes.... terrible grammar!! LOL
The smaller the shaft then the better you had better have balanced it all.
Even better (sheesh) would have been..... The smaller the shaft the more accurate you better have balanced the rotor.
Because imbalance could flex and then bend the shaft!
4mm are quite strong really. 5mm would be "unbendable"?
3.17mm definitely in far more danger of bending!
Old Jan 21, 2013, 07:52 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Not unbendable but it changes the frequency of vibration that the shaft might encounter on a marginally balanced rotor. It also raises the force required to make it bend or break.
Eric B.
Old Jan 21, 2013, 07:55 PM
Michael Paxton is offline
Find More Posts by Michael Paxton
Hey Ya'll!! Watch THIS!!
Michael Paxton's Avatar
Nashville TN.
Joined Mar 2006
Another possibility ...
"The smaller the shaft, the more it becomes necessary to balance the fan and motor as perfectly as possible."
<---Dealing with 64mm fans on 3mm shafts at the moment! OH the pain and annoyance!! Grrrr....
Michael Paxton is offline Find More Posts by Michael Paxton
Old Jan 21, 2013, 07:56 PM
Extreme_RC's Avatar
Australia
Joined Mar 2006
4mm makes a huge difference in a 28mm motor, 5mm even more so, 5mm is like having an 8mm shaft on a 700 series motor, its very easy to get things dynamically balanced. I can do 4mm builds pretty quick, dynamic final balancing of spinner is very simple and repeatable, 3.17 is much more tricky.
Old Jan 22, 2013, 03:55 AM
sikky is offline
sikky's Avatar
USA, AZ, Glendale
Joined Feb 2008
That 2100kv will smoke on 6s... Edfhobbies 90mm 5s 2400kv 32mm 5mm shaft outrunner looks good for 6s... tams shaft adapters in a het fan shroud "stand off" wood spacer with a added 5mm bear 450 heli 5mm main shaft $70 I have the shrouds ... standoff knive liddle style...
Old Jan 22, 2013, 03:57 AM
sikky is offline
sikky's Avatar
USA, AZ, Glendale
Joined Feb 2008
Big block ooooyeah!
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7232 Jun 06, 2016 02:40 AM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
