Old Jan 11, 2013, 04:56 PM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
Huh? IR goes up... volts over the battery go up, so volts on motor should drop... thus Amps/Watts would fall too.... not go up.
It would be handy to see a logger, so it charts them all.
I have never encountered that case....... but maybe the motor gets HOT, its impedance goes DOWN for some reason, thus Amps increase (even for the same volts) and it burns more and more power for nothing (because it all goes in heat).
As a possible explanation if the battery is known to be fine to cope (eg that 65C rating).
The IR500 motor might be "pretty good" but not truly "good enough" for its application.
PeterVRC is offline Find More Posts by PeterVRC
Old Jan 11, 2013, 06:09 PM
supercollider is online now
Find More Posts by supercollider
C.E.R.N. field tester
supercollider's Avatar
United States, NE
Joined Sep 2012
"but maybe the motor gets HOT, its impedance goes DOWN for some reason, thus Amps increase (even for the same volts) and it burns more and more power for nothing (because it all goes in heat"
I don't believe the impedance will go DOWN on any motor that is getting hot. The impedance will rise with temp. I do agree that it is running inefficiently at WOT on 5s. Will test again with a 4s lipo tomorrow. At this point I still plan on using this setup in the habu on 5s, just limiting wot to short bursts. I knew it was going to be a "hot" setup when I ordered it, looks like 1/2 to 3/4 throttle for safe flying.
supercollider is online now Find More Posts by supercollider
Old Jan 11, 2013, 06:25 PM
chas650r is offline
Find More Posts by chas650r
chuck
santa barbara, CA
Joined May 2009
ya , known fact, ir rises in copper w/ heat . if u can find something to wind these things w/ that works the other way let us know
chuck.
chas650r is offline Find More Posts by chas650r
Old Jan 11, 2013, 07:24 PM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
The IR of the battery goes *down* as it heats up. The resistance of the copper goes up, but the reactivity of the chemistry goes up by a higher amount. Hence the total voltage goes up.
Ever found your batteries are weak as p!ss in winter for the first lap or two? That's why.
Odysis is offline Find More Posts by Odysis
Old Jan 11, 2013, 07:37 PM
PikeStaff is online now
Find More Posts by PikeStaff
Gorilla Glue Expert
PikeStaff's Avatar
United States, PA, Doylestown
Joined Sep 2010
chuck.
Gold. All you gotta do is get some 20 ga. solid gold wire. Be the best motor you ever had.
PikeStaff is online now Find More Posts by PikeStaff
Old Jan 11, 2013, 08:19 PM
chas650r is offline
chuck
santa barbara, CA
Joined May 2009
i knew that was coming
Old Jan 11, 2013, 08:50 PM
United States, NE
Joined Sep 2012
Ha! You want to go havsies on a spool?
Old Jan 11, 2013, 09:22 PM
C_reyner is offline
Find More Posts by C_reyner
Joined Jan 2013
Hello friends,
I want to use Turnigy sk3 3300kv on this blade w/ turnigy A spec 1300mAh 45C/90C and i'm going to use it around 10 seconds only
my question is, how much thrust will i get ? And will the battery stand for 10 seconds at full thrust ?
And, is there any recomendation to maximize its power ? Because i need maximum thrust for only 10 seconds.
Thank you
C_reyner is offline Find More Posts by C_reyner
Old Jan 11, 2013, 09:25 PM
91-ZULU is offline
Find More Posts by 91-ZULU
Joined Aug 2009
Question..Has any one used HK Rhino packs , say a 2350 @30C for a 6s set up. CP 2200 motor.
91-ZULU is offline Find More Posts by 91-ZULU
Old Jan 11, 2013, 10:52 PM
chas650r is offline
chuck
santa barbara, CA
Joined May 2009
all of the rhino's i have ever owned have proven to be some of the best i have had. no experience w/ the 6 cells though.
chuck.
Old Jan 11, 2013, 11:39 PM
clive45 is online now
Find More Posts by clive45
It should fly at least once
clive45's Avatar
Australia, NSW, Grenfell
Joined Mar 2006
+1 on the Rhino's
clive45 is online now Find More Posts by clive45
Old Jan 11, 2013, 11:56 PM
anlucas is offline
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
Rhino packs are pretty good but 2350mah is a touch small.
It will not be able to deliver the 70+ amps required.
anlucas is offline Find More Posts by anlucas
Old Jan 12, 2013, 02:37 AM
91-ZULU is offline
Joined Aug 2009
Ok so 4k it will be.
Old Jan 12, 2013, 02:47 AM
anlucas is offline
anlucas's Avatar
Joined May 2011
4000mah?
If you can fit it in your plane and achieve a proper cg then yes. Otherwise 2700-3000mah as a minimum.
Old Jan 12, 2013, 10:20 AM
scunna is offline
Find More Posts by scunna
scunna
scunna's Avatar
United Kingdom, England, South Shields
Joined May 2007
Hi guys, been extending my loft so i have more room. Most of them have 70 and 90 mm changesun fans fitted
My jets (1 min 6 sec)
scunna is offline Find More Posts by scunna
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7232 Jun 06, 2016 02:40 AM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
