Old Jan 08, 2013, 09:26 PM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
Ok had a look at the new rotors, they have changed the molding and improved here and there, whether its stronger remains to be seen but as I am already getting over 2kg thrust reliably with the CS10 so I am not too worried about the CS12 strength.
I need to send in a new drawing for spinners if I go with this rotor as well, as they have changed the spinner seat, its a little bigger diameter, deeper too which is good. Hub is 1mm bigger diameter, blades look almost identical to me, pitch and size bar the 0.5mm length reduction.
I will balance one up later this week and run it on my 4s and 6s setups to see what the story is. I need to order more spinners for the CS10 so might order 2 lots and do a CS12 spinner as well. The spinners are all diamond cut no polishing needed, they come off the CNC exactly as you guys who have them can see
Extreme_RC is offline Find More Posts by Extreme_RC
Old Jan 09, 2013, 09:13 AM
T-BONEZ is offline
Find More Posts by T-BONEZ
Joined Jun 2007
Originally Posted by anlucas View Post
The 2x2300kv will pull 80amps between them.
The 2x2800kv will pull 120amps to give you 1lb or so more thrust.
It's up to you and whether your batteries can handle the load.
hello anlucas, thanks for the reply!
may i ask how much thryst does the 2300kv pair creates/?
T-BONEZ is offline Find More Posts by T-BONEZ
Old Jan 09, 2013, 09:18 AM
anlucas is offline
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
Difficult to say what they will give in the F-14 airframe but on the stand with an inlet lip, they can generate around 2.3-2.5lbs each so double that for a pair.
anlucas is offline Find More Posts by anlucas
Old Jan 09, 2013, 10:34 AM
T-BONEZ is offline
Joined Jun 2007
Thanks again..
Something just struck my mind...
Will the 2300kv motor on full throttle (let's say 40amps)
Produce the same amount of thrust as compared to:
2800kv Motor on a throttle setting which will give 40amps draw?
I'm thinking if i can cruise around nicely with the 2800kv at 40amps draw and save the 40 - 60 amps range for emergency throttles
Old Jan 09, 2013, 11:21 AM
anlucas is offline
anlucas's Avatar
Joined May 2011
Thanks again..
I haven't tried a specific test but theoretically, Yes.
If the motors are spinning at the same RPM and we are talking about almost identical motors bar the winding turns, the energy required should be similar.
Old Jan 09, 2013, 11:28 AM
mopetista is offline
Find More Posts by mopetista
Vienna, Austria
Joined Apr 2007
similar, if a bit lower (ESCs less efficient at partial throttle than WOT, higher losses in all wires and lipo (Ohms resistance rises with Amps squared), but similar.
For me, the question would rather be very mundane: Do I have ESCs which cope with 65A, if not how much bigger / heavier are they (for 40A I use cheap 33g Blue Series ESCs from HK, good 65A ESCs coping with high rpm cost a bit more and also weigh a bit more), AND will my lipos be happy at higher amps, Probably if short WOT burst are all there is, good airflow around the lipos and it will be fine.
So, what lipos you intend to use?
...my 2c...
mopetista is offline Find More Posts by mopetista
Old Jan 09, 2013, 12:36 PM
chas650r is offline
Find More Posts by chas650r
chuck
santa barbara, CA
Joined May 2009
and my 2c....... my tests were well under 40 amps on 4's for the2300 w/ good batteries , for whatever reason. not enough power on 4's for me.
and the lower resistance of the higher kv motors (less heat) may offset the losses at part throttle in the esc, fwiw.
chuck.
chas650r is offline Find More Posts by chas650r
Old Jan 09, 2013, 01:11 PM
anlucas is offline
anlucas's Avatar
Joined May 2011
I 've measured everything from 33amps to 46amps on these L2855-2300kv motors with various ESC, timing and battery combinations.
Some ESCs like the HK SS 60-70amp showed lower results than the Turnigy Plush (Hobbywing).
Old Jan 09, 2013, 03:35 PM
chas650r is offline
chuck
santa barbara, CA
Joined May 2009
any idea how the thrust compared?getting a 46 amp draw could be good if the output power is relative. my tests were all in the lower 30's w/ 2 different h/wing esc's and at different timing settings. i may have had a lower than norm kv?
chuck.
Old Jan 09, 2013, 03:56 PM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
L2855 2300kv on 65c pack
Really like the 2300kv motor
Turnigy L2855-2300kv - 5S - CS 10 Blade Test (2 min 11 sec)
erh7771 is offline Find More Posts by erh7771
Old Jan 09, 2013, 04:27 PM
DamonH is offline
Find More Posts by DamonH
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
What was the measuring unit on the scale?
DamonH is offline Find More Posts by DamonH
Old Jan 09, 2013, 04:36 PM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
That will be Kg. Just under 2Kg peak (1.9Kg area)
That fan ran very well!! A great feed from the battery - which you would hope 65C would be! hehe. And a very well balanced fan too!
I tend to use 20, 30, 40C (20C in the Vampire as the airflow restriction drops possible power anyway), but then you only see about 900W area.... not 1100W or more like the 65C there did.
Though you can see by the heats, it isn't going to be a happy camper at that power level long term! And at those power levels you really would need to pay good attention to running it down so the motor cools well before stopping.
They are an amazing value motor series! 2100, 2300, 2800. Best used for max 900W or so areas though - and not over 60A area on any of them (pref 55A or under). (push a 1000W, within the current limit range mentionend, and it can be ok if treated nicely)
PeterVRC is offline Find More Posts by PeterVRC
Old Jan 09, 2013, 04:47 PM
chas650r is offline
chuck
santa barbara, CA
Joined May 2009
http://www.youtube.com/watch?v=32i_fNzmPZk
ya , i think on 5's it would be good , the above was 4's comments,
Old Jan 09, 2013, 11:18 PM
anlucas is offline
anlucas's Avatar
Joined May 2011
chuck.
1.0 to 1.3Kg thrust. 42-46amps(different batteries) came with high timing but very little thrust improvement.
The most efficient is around 40 amps (low timing) for around 1.2Kg peak which settes to 37amps 1-1.1Kg from memory.
Old Jan 09, 2013, 11:54 PM
anlucas is offline
anlucas's Avatar
Joined May 2011
Yeah, I run that test a few months ago just to show what is possible with these low cost motors...
That motor is RIP as of a couple of weeks ago after 4 mins of WOT in my Panther....
It got very hot and slipped on the mount. The bell started rubbing on the motor housing and it ceased....
One more case for a better housing for high power setups.
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7243 Jul 18, 2016 07:09 PM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
