Old Dec 11, 2012, 11:06 PM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
Yep, RPM and thrust (pretty well hand in hand) are the only true 'output'
The inputs have many various reasons for being different, or 'hmm, doesn't SEEM to add up'.
PeterVRC is offline Find More Posts by PeterVRC
Old Dec 12, 2012, 04:25 AM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
so how long before people start quoting "shaft power" instead of input power?
Odysis is offline Find More Posts by Odysis
Old Dec 12, 2012, 06:32 AM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
Originally Posted by WhalleyB0Y View Post
Excellent explanation! I would even go as far as to say the watts seen in a wattmeter could mean nothing if the the energy is being wasted in the form of heat or other electrical losses. The true measurement in this case would be the thrust.
The watts shown on the watt meter is a good indication of efficiency when the thrust/rpm is comparable. Where as watts/thrust conversion is dependant on how close the kv is matched to the work that the rotor is expected to perform.
Eric B.
AirX is offline Find More Posts by AirX
Old Dec 12, 2012, 06:36 AM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Originally Posted by anlucas View Post
If we had the ideal motor with super strong magnets/magnetic field, rpm/thrust would be directly proportional to amps/watts.
But, this is not the case with some of these outrunners. At some point they reach a point where the surplass energy just becomes heat rather than rotational energy. The thrust differences can be below 100gr.
+1, this is usually the case where the winding of the motor is not correct to produce a strong enough magnetic field to efficiently turn the rotor to the rpm the kv is asking for.
Eric B.
Old Dec 12, 2012, 06:37 AM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
When Peter learns how to calculate it?
Eric B.
Maybe i should have used an emoticon such as .
Old Dec 12, 2012, 06:41 AM
Odysis is offline
Joined May 2007
(V - I * Rm) * (I - Io)...
Old Dec 12, 2012, 06:26 PM
PeterVRC is offline
Joined Nov 2006
We don't really care about 'shaft input power' at all....
What matters is how much you put in.... and what true power, which as to be the measurement of thrust/RPM, comes out.
Efficiency is irrelevant as you are stuck with what you have anyway. And all you really need to care about is what output you got in that system, versus any other comparison of what other systems got (via posts, or your own tests etc), for what input power... so if you got a better output, or lower input, your setup was more efficient. There are tons of references to compare against, so that you have reasonable guides as to what to aim for (what to buy or try etc).
Old Dec 12, 2012, 07:41 PM
St. Martin is offline
Find More Posts by St. Martin
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
So, what you are saying is, you were just wasting input power initially with excess heat. And by reducing the timing, you were just reducing the heat and gaining efficiency? Thats understandable. esp, since I don't use outrunners for EDF applications. I can see where their(out-runner) natural in-efficiencies over an in-runner, may show increased differences in timing, over the in-runner.
But like Isaid, I was not trying to be critical of your statement. I'm just not used to the use of out-runners in EDF. Thanx.
Fuzz
St. Martin is offline Find More Posts by St. Martin
Old Dec 13, 2012, 03:04 AM
Odysis is offline
Joined May 2007
You're not stuck with it. Change motors... If motor A is 70% efficient, and motor B is 85% efficient, motor A will need to weigh twice as much to do the same job.
Well, not actually weigh, but have twice the surface area. Close enough approximation though.
Point is, trying to lump motor and fan together and ignoring the differences between motors is just as bad as ignoring differences between fans.
Old Dec 13, 2012, 03:21 AM
anlucas is offline
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
+1. A really great motor for one fan could be a poor choice for another fan and vice versa.
anlucas is offline Find More Posts by anlucas
Old Dec 13, 2012, 07:32 AM
PeterVRC is offline
Joined Nov 2006
It is not worth buying yet another motor just to get a few % better efficiency - if you can even work that out in advance before buying another one that is hardly better, or not at all..
Any setup you put together should at least be in the ballpark, unless you don't even know what you are doing and should never have tried yourself anyway.
The CS10 & 12 are so close to identical that the same motors will work totally fine in both.
All we are trying to do is compare the fans, not motors. It would be different if it was CS10 versus Wemo etc... but it isn't.
Old Dec 13, 2012, 04:47 PM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
Just got a new order of rotors in and I got some 12 blade to test out, but if they are presenting a similar load to each other I will just pull the 10 blade off the test fan and stick a 12 on to start the test runs off!
Extreme_RC is offline Find More Posts by Extreme_RC
Old Dec 13, 2012, 05:23 PM
PAPE is offline
Find More Posts by PAPE
Joined Jun 2012
i already did that with your alloy unit the numbers are almost the same.
Change sun 70mm 12 blade fan on 4s Het 2W25 2720KV (1 min 9 sec)
PAPE is offline Find More Posts by PAPE
Old Dec 13, 2012, 06:37 PM
PeterVRC is offline
Joined Nov 2006
I suspect Mark will test on much higher power setups. 6S.... 1200W and higher...
So the fan MIGHT have a different curve that then shows a separation in their results at higher powers.
It is interesting that the 12 blade fits the ERC housing, and then that smaller gap should make it a higher thrust.... but then should also draw a bit more power (Amps) too.
Old Dec 13, 2012, 07:45 PM
Extreme_RC's Avatar
Australia
Joined Mar 2006
It may also cause issues with stretch at higher power, likely I will have to machine down the rotors a little if I build fans with the 12b, we will see!
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7194 Dec 14, 2015 04:03 PM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 08:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 07:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 02:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 10:36 AM
