Old Nov 18, 2012, 09:21 AM
pardus is offline
Find More Posts by pardus
Graham Dyer
pardus's Avatar
Johannesburg, South Africa
Joined Jul 2003
Are spare blades/rotors available anywhere for the CS10?
pardus is offline Find More Posts by pardus
Old Nov 18, 2012, 10:29 AM
anlucas is offline
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
Here you go...
http://www.hobbyking.com/hobbyking/s...dProduct=26043
anlucas is offline Find More Posts by anlucas
Old Nov 18, 2012, 12:09 PM
pardus is offline
Graham Dyer
pardus's Avatar
Joined Jul 2003
Originally Posted by anlucas View Post
No stock
Old Nov 18, 2012, 01:01 PM
pencon is offline
Find More Posts by pencon
Joined Dec 2008
Just ordered the 12 blade Changesun myself ,10 blade is so last week (kidding I also have a 10 blade )
pencon is offline Find More Posts by pencon
Old Nov 18, 2012, 09:27 PM
pencon is offline
Joined Dec 2008
Deleted
Old Nov 24, 2012, 03:51 PM
GooberRC is offline
Find More Posts by GooberRC
United States, AZ, Gilbert
Joined Sep 2012
Calling all EDF experts, I need some assistance I am pretty much a complete noob when it comes to EDF setups and I need to decide on a configuration for an A-10 with an AUW of approx 6lbs (plus or minus, depending on the input received here of course). Here is the kit I need to power: http://www.nitroplanes.com/projet-004-a10-kit.html
I have been reading much of this thread and I would like to get the great sound provided by the CS10 units if they are a good match for my plane. I already have some 4S-3300 35C packs which I would prefer to re-use if possible. Would a couple of HET 2W-25 motors driving the CS10 fans be a good match for the A-10? If so, what kind of ESC would you recommend? Could I run two of my 3300 packs in parallel or would that get way too heavy?
I'd really appreciate your input as getting this wrong would be expensive! Btw, I would have a preference for speed vs thrust on this ship, but obviously it will need a decent amount of thrust to fly well. Thanks for the help!
GooberRC is offline Find More Posts by GooberRC
Old Nov 24, 2012, 04:24 PM
mopetista is online now
Find More Posts by mopetista
Vienna, Austria
Joined Apr 2007
cheater holes: not always good for "woosh"
My Multiplex Twister was a bit too quiet with a low-power CS70. Cut some cheater openings in the EDF hatch, and it makes more noise now, but not much woosh gained, rather you get to hear the motor whine more through the openings.
But it's still a change for the better, and I think the performance is slightly better because the fan is getting more air. Mind you, that is only a <400W setup...
Twister MPX looping 1 dec 2012 (3 min 1 sec)
cheers
Clemens
mopetista is online now Find More Posts by mopetista
Last edited by mopetista; Dec 02, 2012 at 03:26 PM. Reason: swapped video for one in better light conditions
Old Nov 24, 2012, 09:18 PM
sikky is offline
Find More Posts by sikky
speedin n da weeds :)
sikky's Avatar
USA, AZ, Glendale
Joined Feb 2008
What's your setup? Flys good.
sikky is offline Find More Posts by sikky
Old Nov 24, 2012, 11:07 PM
stingeragents is offline
Find More Posts by stingeragents
Joined Jan 2011
mopetista. My 2 CS setups have always not had the whoosh sound that I wanted. I watched all the youtube vids before I got my first one, and mine sounded nowhere near as good as the ones I saw, with several different airplanes. Anyways, had just got a watt meter like a week ago. Ran up my watt meter on a 4s batt and was getting 780 watts. I hooked up a 5s batt (just ran it for a sec as it way overspecced my motor). The sound with that 5s on was incredible. 1400watts. I think the RPM/ Watts effects the sound to some extend as with 5s it was MUCH better than the 4s I have been running.
stingeragents is offline Find More Posts by stingeragents
Old Nov 25, 2012, 02:15 AM
Vienna, Austria
Joined Apr 2007
Many small cheaters do the trick
@ sikky: thx! Setup is just the Turnigy L-2855 2800kV which is usually run on 4s, here only on a 2200mA 3s 35C Nanotech, some 37A on full battery, translating into 3.5 min WOT.
The Twister is kept very light, that's why it climbs nicely.
@ stingeragents: I am sure you are right, with more power, maybe already with 700W, there would be much more woosh. But there ARE some airframes like the HK Vampire which produce the woosh out of the turbulent air, and NOT the power (and thererfore speed of the air getting in and out). It would be nice to get the Vampire sound in other airframes as well. Might be those small numerous cheaters. Got a Freewing 64mm Panther which sounds awesome due to many thin cheater strips (and a 7-blade fan which does not howl). In this video you also see good examples of "control surface blanketing" on a Panther at high alpha when the horizontal stab is ineffective because the wing blocks all airflow...
F9F Panther 64mm 7-blade stall crash tree & high alpha starts (2 min 20 sec)
Surely you know lots of Vampire videos and the great sound of that airframe...
So in search of good sound at low Watts, cheater strips may work
cheers
Clemens
Old Nov 25, 2012, 12:42 PM
pencon is offline
Joined Dec 2008
That was a cool looking tailslide launch ..
Old Nov 26, 2012, 04:50 PM
scunna is offline
Find More Posts by scunna
scunna
scunna's Avatar
United Kingdom, England, South Shields
Joined May 2007
LX A-10 Changesun 70mm fans Bl-32 motors 5S 8000ma 20-50 c lipo AUW 8.5 pounds (0 min 0 sec)
scunna is offline Find More Posts by scunna
Old Nov 26, 2012, 05:25 PM
GooberRC is offline
Joined Sep 2012
^Thanks scunna. Seemed a little slow but that's a useful comparison for other potential powertrains.
Old Nov 27, 2012, 12:34 AM
anlucas is offline
anlucas's Avatar
Joined May 2011
All out speed is dictated by the airframe in many cases.
Scunna is running the BL-32s on the A-10 on 5S. On 6S it would be much faster.
The Dynam ME-262 is surprisingly fast for example.
I run mine with the low-cost Turnigy L2855-2300kv motors on a 5S 4400mah 65-130C nano-tech. Lower C batteries result in less speed.
RC Speedo showed a 112mph for a couple of passes.
Not much whoosh due to the clean airflow around the nacelles.
Dynam ME-262 with ChangeSun 10Blade on 5S (1 min 41 sec)
Old Nov 27, 2012, 12:56 AM
Vienna, Austria
Joined Apr 2007
still a pretty nice sound (I think), and great speed!
curious how the Freewing 262 will compare to the Dynam...
cheers
Clemens
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7224 Apr 21, 2016 02:53 AM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
