Old Nov 11, 2012, 06:51 PM
pencon is offline
Find More Posts by pencon
Joined Dec 2008
Yeah it's like the hole isn't square with the fan so the whole thing wobbles back and forth about a 16th of an inch .Figures , ALWAYS my luck
pencon is offline Find More Posts by pencon
Old Nov 11, 2012, 06:58 PM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
I have a lot of these fans and have never had one with that sort of issue.
Are you sure it is on the 'cones' of the balancer properly?
The fans are moulded and it would be hard for them not to come out correct!
PeterVRC is offline Find More Posts by PeterVRC
Old Nov 11, 2012, 07:02 PM
PAPE is online now
Find More Posts by PAPE
Joined Jun 2012
Originally Posted by petervrc View Post
i have a lot of these fans and have never had one with that sort of issue.
+ 1
PAPE is online now Find More Posts by PAPE
Old Nov 11, 2012, 07:19 PM
pencon is offline
Joined Dec 2008
this is an RC-castle version , not sure if that's just a copy or the same manufacturers ? It was also quite out of balance. I just sent them an email .
http://rc-castle.com/shop/product_in...oducts_id=2861
Old Nov 11, 2012, 07:52 PM
chas650r is offline
Find More Posts by chas650r
chuck
santa barbara, CA
Joined May 2009
as i noted when they first came available , they appear different in the hub area, at least compared to the c/s rotors i have, even though some here who obviously know more than i shot me down and said they were the same.
fwiw , the c/s rotors i received were also fairly close balance wise .
chuck.
chas650r is offline Find More Posts by chas650r
Old Nov 11, 2012, 07:59 PM
pencon is offline
Joined Dec 2008
You know what ? After balancing it's not too bad . The runout even seems not so bad . It could have been sitting funny on the tapers like you said Peter . It was really out of balance though .
Old Nov 11, 2012, 08:29 PM
nighthawk0077 is offline
Find More Posts by nighthawk0077
Canada, ON, Vaughan
Joined Oct 2009
Short clip of my HET F20 (camcorder battery died):
F20 10 Blade EDF on 6S (1 min 19 sec)
The L2855 2100kv smoked on me, so I put in the HET 2W-30 setup out of my old Panther.
Now she's starting to come alive
nighthawk0077 is offline Find More Posts by nighthawk0077
Old Nov 11, 2012, 08:44 PM
chas650r is offline
chuck
santa barbara, CA
Joined May 2009
another success story w/ the < 100 gram L2855.
Old Nov 11, 2012, 08:59 PM
PeterVRC is offline
Joined Nov 2006
another success story w/ the < 100 gram l2855.
lol
Old Nov 11, 2012, 09:18 PM
tracknoob is offline
Find More Posts by tracknoob
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Yeah, the ones I had all needed some weight to balance them but the raw fan itself was always very true and blades even on the CS version.
That's what was maddening for me -- more and more care taken on the static and dynamic balance attempts with same issue, finally traced to adapter run-out, which I believe is due to oversized shaft hole dia, in my case.
Yours definitely sounds different. Sorry for jumping to conclusion.
tracknoob is offline Find More Posts by tracknoob
Old Nov 11, 2012, 10:39 PM
chas650r is offline
chuck
santa barbara, CA
Joined May 2009
[QUOTE=tracknoob;23245307]
agreed, it's hard to make a palace out of pig s*it.
chuck.
Old Nov 11, 2012, 10:44 PM
Aerobatman is offline
Find More Posts by Aerobatman
Aerobatman's Avatar
Akron, Ohio
Joined Nov 2005
FMS F-16 with CS10
Here's a short video of my first EDF running the CS10 fan. All in all I like it! Just wish it were slightly louder
L2855 2300kv, 5s 3000 Sky Lipo 40c, 1000 watts, 52 amps.
I'm getting about 3:30 flight time with mixed throttle usage.
FMS F-16 CS10 (2 min 53 sec)
Aerobatman is offline Find More Posts by Aerobatman
Old Nov 12, 2012, 12:07 AM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
chuck.
it was plainly obvious to anyone who has worked a lot with these rotors that they were not from the same molds but also it is a copy so is it better or worse? that was my only question. I did not see anyone shoot you down or I would have backed you up. they are not the same!! but they could be better........or worse....lol!!!
the cs 70/10 rotor is actually a very good rotor and come with very good consistency from cs I know this from balancing over 200 of them from when they first hit the market........I just wish all the products from china had the same quality and consistency of the cs 70/10........just dont turn them over 46k rpm this is their failing point.
jcdfrd is offline Find More Posts by jcdfrd
Old Nov 12, 2012, 12:51 AM
anlucas is online now
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
Guys,
I don't mean to be uptight but the CS10 rotor is made by ChangeSun. This is what is getting discussed here. Everything else, no matter how similar, if discussed here, can only lead to confusion to the newcomer.
In the end we have to be able to have a clear picture in order to try this, that or another product.
It could probably be useful if owners of the cyclone power opened a separate thread.
anlucas is online now Find More Posts by anlucas
Old Nov 12, 2012, 04:23 AM
genghiskt is offline
Find More Posts by genghiskt
genghiskt's Avatar
Joined Sep 2011
the cs 70/10 rotor is actually a very good rotor and come with very good consistency from cs I know this from balancing over 200 of them from when they first hit the market........I just wish all the products from china had the same quality and consistency of the cs 70/10........just dont turn them over 36k rpm this is their failing point.
Is 46k rpm or 36k rpm ??
genghiskt is offline Find More Posts by genghiskt
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7232 Jun 06, 2016 02:40 AM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
