Old Nov 07, 2012, 04:40 AM
scunna is offline
Find More Posts by scunna
scunna
scunna's Avatar
United Kingdom, England, South Shields
Joined May 2007
I have just noticed in that pic you can see where i modded mirage at rear to fit fan. I sliced the bottom of the rear duct to gain access.
scunna is offline Find More Posts by scunna
Old Nov 07, 2012, 04:48 AM
fooyukvoon is offline
Find More Posts by fooyukvoon
The Need4Speed
fooyukvoon's Avatar
Malaysia, Perak, Ipoh
Joined Aug 2008
Looks like it is possible to emulate your setup with the RCL 4S EDF that I have since it'll only have to carry 4S.
fooyukvoon is offline Find More Posts by fooyukvoon
Old Nov 07, 2012, 09:21 AM
ncflyer79 is offline
Find More Posts by ncflyer79
ncflyer79's Avatar
United States, NC, Marion
Joined Jun 2011
guys im needing some help. I have a 70mm sabre by venom and id like to use this fan but im having a hard time finding a decent setup. I dont want peel the wings off top speed but would like to have some vertical for loops and rolls. I have a 14.8v 3300 65C lipo id like to use along with a 100amp ESC with it as well. Any ideas?
ncflyer79 is offline Find More Posts by ncflyer79
Old Nov 07, 2012, 10:47 AM
anlucas is online now
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
Check Dionysus' setup using a Turnigy L2855-2800kv motor....
http://www.rcgroups.com/forums/showt...9#post21301240
http://www.rcgroups.com/forums/showt...0#post20196005
If you want more speed and stay with 4S(Your battery will be able to handle the 90amps) then you need a motor of 3000-3300kv like the Cyclone Power 3300kv.
Altenatively, one of the new RC Lander 10blade fans will also do....
From HK
http://www.hobbyking.com/hobbyking/s..._1200watt.html
Same from ParkRCmodels...
http://parkrcmodels.com/product_info...oducts_id=1407
anlucas is online now Find More Posts by anlucas
Old Nov 07, 2012, 10:57 AM
stingeragents is online now
Find More Posts by stingeragents
Joined Jan 2011
Could someone tell me how to get this plane to go faster. Running it on 40c 2200 4s. It just seems much slower than all the other cs 70mm planes i have seen. Id say it doesnt go faster than 60. Its comparable to the pusher version of that plane. I dont have the edges beveled, will that make a huge difference?
Edit. Whoops. It has the exceed 2700kv motor and my thrust tube is 61mm. I also tried the tube at 56mm and it was about the same
stingeragents is online now Find More Posts by stingeragents
Old Nov 07, 2012, 11:02 AM
anlucas's Avatar
Joined May 2011
If your 2200 40C batteries are like my Zippies, then they could be part of the problem.
Can't see from the photos... Do you have a thrust tube installed?
Old Nov 07, 2012, 11:03 AM
Joined Jan 2011
Just edited my above post with more info. Also the fan is balanced. Auw is like 25oz. Granted i could just buy a foamy kit but i like scratch building. They are so much easier to repair. If u cant tell i already had to replace the whole front end of that plane
Old Nov 07, 2012, 11:47 AM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
Can you post a better photo of your ducting or lack of it.
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Nov 07, 2012, 11:50 AM
Joined Jan 2011
Well the fan sits in the middle. Both sides of it are open and free flowing out the back of the plane. The receiver is on one side and esc on the sidewall of the other side. The pic below is how i had it setup on the dynam fan. When i switched to the cs it wouldnt fly so i took out those diverters as well as the 2 pieces in the middle that join right in front of fan
Edit. Pic on the left is how i had it previously. The other 2 is how it is now
Old Nov 07, 2012, 12:04 PM
4stripes is online now
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
If you can get 60 out of that plane, you can't expect much more. Any faster and I doubt the plane would hold together. Number one, the flight control rods are too long to be unsupported. Enjoy what you have and think about a new airframe like the Phase 3 F-16 if you want fast 70mm performance. It is a very nice flier even with the stock fan. My 55mm stock setup (old style) would do 75mph on decent 3S batteries yet many upgrade to larger fans.
Cheers
4stripes is online now Find More Posts by 4stripes
Old Nov 07, 2012, 12:12 PM
Joined Jan 2011
I dont think because of long control rods the plane wouldnt hold together. Do you mean just cause the design style of the plane or what? In the scratchbuild edf forum there have been numerous people get scratch builds over 100mph.
Old Nov 07, 2012, 12:29 PM
anlucas's Avatar
Joined May 2011
How wide is the exit of your thrust tube?
Anything less that 60mm is too small.
Old Nov 07, 2012, 12:39 PM
Joined Jan 2011
61mm
Old Nov 07, 2012, 12:43 PM
4stripes's Avatar
Joined Jan 2009
I think you will be hard pressed to find flat board foam used at 100mph. The structure is too flimsy unless you plan to add a fair bit of reinforcing. The large square intakes, and exposed servos will not be pushed very fast without a lot of thrust.
It is kind of like trying to make snoopy's doghouse into a "jet".
No offence...
Old Nov 07, 2012, 12:45 PM
Joined Jan 2011
So would reducing the size of the intakes help ?
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7224 Apr 21, 2016 02:53 AM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
