Old Nov 06, 2012, 07:05 PM
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Originally Posted by PAPE View Post
And is it the stock plastic CS housing or an alloy housing your using?
At $20 it is plastic.
Prof100 is offline Find More Posts by Prof100
Old Nov 06, 2012, 09:02 PM
The Need4Speed
fooyukvoon's Avatar
Malaysia, Perak, Ipoh
Joined Aug 2008
How does one fit the CS-10 onto the BL-32 motor? I just found out it has a 5mm shaft.
Specifications:
Type: Brushless Inrunner
Size: 32-size for Ducted Fans
Bearings or Bushings: Bearings
Wire Gauge: 14 AWG
Voltage: 14.8V - 22.2V
RPM/Volt (Kv): 2150Kv
Resistance (Ri): 0.026Ω
Idle Current (Io): 2.6A @ 20V
Continuous Current: 62A
Maximum Burst Current: 75A
Cells: 4S-6S Li-Po or 14-18 cells NiCd/NiMH
Speed Control: 80A
Weight: 5.70 oz (162g)
Overall Diameter: 1.10 in (28.0mm)
Shaft Diameter: 0.20 in (5.0mm)
Overall Length: 2.00 in (52.0mm)
fooyukvoon is offline Find More Posts by fooyukvoon
Old Nov 06, 2012, 09:05 PM
Joined Jan 2011
I think tamjets sells adapter
stingeragents is offline Find More Posts by stingeragents
Old Nov 06, 2012, 10:17 PM
Fly now crash later
davecrash's Avatar
Canada, ON, Newmarket
Joined Nov 2006
Specifications:
Wire Gauge: 14 AWG
Speed Control: 80A
I ordered the adaptor from Tamjets, Extreme has them too.
davecrash is offline Find More Posts by davecrash
Old Nov 07, 2012, 12:52 AM
The Need4Speed
fooyukvoon's Avatar
Joined Aug 2008
I was thinking it would be more or less a PNP (balancing not included) setup.
Old Nov 07, 2012, 01:11 AM
Greece, Attica, Athens
Joined May 2011
One PNP setup that comes close is this one
http://www.hobbyking.com/hobbyking/s...0watt_6s_.html
and of course the much lighter 6S combo from ExtremeRC.
http://www.extremerc.com.au/estore/i...oducts_id=1102
anlucas is online now Find More Posts by anlucas
Old Nov 07, 2012, 01:49 AM
Joined Dec 2008
I just ordered the RC -Castle alloy 10 blade unit for my BL32 . After I ordered it I realized it only has 4 stators . The only reason I ordered it from RC-castle is because they had it without motor , which I didn't need .Is this going to be less performance than the hobbyking 7 stator unit ? Seven stators with all those extra bolts does look like it's going to weigh more though ..
pencon is offline Find More Posts by pencon
Old Nov 07, 2012, 01:53 AM
The Need4Speed
fooyukvoon's Avatar
Joined Aug 2008
Scunna,
How many watts and AUW is your 70mm setup in the FlyFly Mirage? I just got the 4S 1200W Lander 10 Blade EDF from HK. Wondering if it would it be comparable to your setup? (Besides being a bit heavier ) I have the FlyFly Mirage too (still in the box)
Thanks.
Foo
Old Nov 07, 2012, 01:56 AM
Joined May 2011
... 4S 1200W Lander 10 Blade EDF from HK.
The 4S version is not very powerful.
The 6S is similar to what Scuna is using.
Old Nov 07, 2012, 02:07 AM
The Need4Speed
fooyukvoon's Avatar
Joined Aug 2008
I was wondering about the 6S version too. Maybe time to get 1 unit of that too.
Old Nov 07, 2012, 03:11 AM
Joined Jun 2012
Somewhere on the forum, I think it was Tam from tam jets posted that he tested a 7 stator housing and saw the same thrust numbers for 100 watts less power, so the seven stators were more efficient. I don't think it was the heavy lander housing, I think it was a skyworld housing. CS10
PAPE is offline Find More Posts by PAPE
Old Nov 07, 2012, 04:32 AM
scunna
scunna's Avatar
United Kingdom, England, South Shields
Joined May 2007
Scunna,
Thanks.
Foo
Its around 1300 watts on 6s. When the same fan and motor were in my twister it was nearer 1700 watts . Ducting must play a big part in this.
scunna is offline Find More Posts by scunna
Old Nov 07, 2012, 04:33 AM
scunna
scunna's Avatar
Joined May 2007
Sorry the auw is 4pound it nearly hovers so thrust must be just under auw
Old Nov 07, 2012, 04:35 AM
scunna
scunna's Avatar
Joined May 2007
The lipos i have tried in mirage are 6s 3300 65-130c nano's and 6s 4500 45-90c nano's, i think there is a weight difference but you cant feel it.
Old Nov 07, 2012, 04:38 AM
scunna
scunna's Avatar
Joined May 2007
I have two of these to try . maybe put them in my twin70mm raptor
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 6509 Yesterday 07:39 PM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
