Old Nov 02, 2012, 01:05 AM
PeterVRC is online now
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
My test stand is a frame, with no moving parts at all - it just sits right on top of the scales. Just zero it before a test, and off it goes..... zero friction or error possible.
And to check scale accuracy, we have two other digital scales around. (up to 10Kg types). So I just throw some batteries on them all to compare a few weight areas.
All three a DEAD EQUAL... not close.... exact.
Which makes me think modern digital scales must be very easy for them to get right... accurate. Some form of digital sensor (IC??) that means it is easy to replicate that accuracy.
I am not sure how they make them...... (I should bust one apart and see!! LOL)
PeterVRC is online now Find More Posts by PeterVRC
Old Nov 02, 2012, 01:27 AM
anlucas is offline
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
Originally Posted by PeterVRC View Post
You would HOPE that if everyone used vertical stands they would have to be the same??
Even vertical stands have variances. I 've seen the efforts of a guy in this thread who had the fan mounted too close to the "bottom" and the airflow was getting disrupted.
anlucas is offline Find More Posts by anlucas
Old Nov 02, 2012, 02:29 AM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
Just for due diligence, is there a stock 70mm fan\motor you can test with?
tia
erh7771 is online now Find More Posts by erh7771
Old Nov 02, 2012, 02:55 AM
anlucas is offline
anlucas's Avatar
Joined May 2011
My sled is too problematic to mainain it in a reliable state. I want to go to a vertical one as well.
Can you post a picture please.
Old Nov 02, 2012, 03:13 AM
Joined Nov 2006
I will go out later and take a pic. I think I had it in here somewhere once before.
VERY simple to do with some bits of wood, LOL. Much easier than a sled.
It can take 70mm and 90mm fans, of any design, housing etc.
It is mounted onto the scale "permanently" using double sided tape.
Old Nov 02, 2012, 04:54 AM
Joined Nov 2006
EDF test stand:
1) Made from 19mm MDF panel wood and some bits of pine (35x90 and 90x19)
Though you can use all sorts of wood types really.
2) The EDF 'blocks' have multiple hole positions, so it can open out to suit numerous fan sizes - and you can just drill some more if you ever need more!
3) A $20 digital kitchen scale attached underneath with double sided tape. One with a slide-out display so it could come forwards into better view, So start any project with an idea of what scales you will use, and to be sure you will be able to read them still.
4) The power meter, kv meter, and scale readout all group out at the front for easy reading - even if the "blast shield" is up. LOL
5) The ESC uses velcro to mount onto a side panel, so that it gets some ariflow for cooling. (not much but enough)
6) Two screws for mounting a "blast shield" to shield you from any exploding fan!! LOL. Well, it is only lousy 3mm plywood - but ply is quite a strong construction, and very energy absorbing too. So I expect it will stop any fan blade parts fine. Errr, fine enough....
7) Capability to be used for 'other' measuring tasks.....
The camera makes some pics 'fish eyed' and make straight lines look askew. Rest assured it is all 'square', hehe.
Old Nov 02, 2012, 04:58 AM
Joined Nov 2006
Aircraft thrust test stand:
Same EDF test stand with the patented "Aircraft clamperer and balancer assembly". LOL
This "addon" just bolts onto the EDF Test Stand and can hold an EDF aircraft of almost any design while you thrust test it. Vertical instead of 'friction adding horizonatal".
Old Nov 02, 2012, 05:48 AM
anlucas is offline
anlucas's Avatar
Joined May 2011
Peter,
very informative. Thanks!
Old Nov 02, 2012, 07:12 AM
beamen is offline
Find More Posts by beamen
Joined Sep 2011
My thrust tester is MUCH less advanced but would probably do for most:
Get a kitchen weight. Set the plane on it's nose, hold the plane so it doesn't fall over. Hit full throttle
beamen is offline Find More Posts by beamen
Old Nov 02, 2012, 08:21 AM
Joined Nov 2006
I do that for 'simpler' aircraft. Not worth setting up for those.
Prop aircraft I do with a sash and digital fishing scale, pull mode.
Old Nov 02, 2012, 01:03 PM
tracknoob is offline
Find More Posts by tracknoob
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Bingo -- esp when usually all I need to do is answer the question "Do I have greater than 1:1 thrust for this plane's weight?" (a weight, btw, that was measured on exact same stand just prior to hitting tare)
tracknoob is offline Find More Posts by tracknoob
Old Nov 02, 2012, 01:39 PM
TheCure is offline
Find More Posts by TheCure
Wats the worst that can happen
TheCure's Avatar
Canada, BC, Surrey
Joined Jan 2009
How much typically will the in-plane thrust differ from the open-air thrust as you read using your testing apparatus? Of course it depends on the restriction of the air channels in the plane, but a guesstimation would be welcome.
I'm looking to replace a 70mm 5 blade fan w/3300kv motor that generates 1.2kg thrust in -plane. I see HK has RC lander-ish allor fans that report a 1.7kg figure (not sure how accurate this is). Trying to figure if it is worth taking the chance to buy them.
TheCure is offline Find More Posts by TheCure
Old Nov 02, 2012, 03:07 PM
chas650r is offline
Find More Posts by chas650r
chuck
santa barbara, CA
Joined May 2009
Originally Posted by erh7771 View Post
Not if it's an outrunner, plenty people running the 2100kv on 6s...don't use 65c packs...extra .25 - .50 volt hurts stuff...a lot of stuff.
really ? didn't hear to many pipe right up. i guess all the people that are using motors twice that heavy just need the dead weight . an extra 1/2 volt at 22v is not going to make or brake it unless you are already in the efficiency pit.
chuck.
chas650r is offline Find More Posts by chas650r
Old Nov 02, 2012, 04:26 PM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
Sometimes it can be exactly the same if the ducting flows well enough, I have had quite a few models that produce the same thrust as the fan did on the bench. Often though the intakes are messy or restricted and will cause the fan to starve and drop in thrust. This is all based on static measurements mind you.
The 1.7kg they quote looks like a peak value only, if you watch the videos of the fan, 1.5 or so is the stable thrust, and you have to consider the weight of their fans too, as a German made Wemo Minifan and an HET 2W18 will produce 1.5kg thrust at 800w and weighs a lot less, better engineered and better quality, will run flat out all day long.
Extreme_RC is offline Find More Posts by Extreme_RC
Old Nov 02, 2012, 07:32 PM
Joined Nov 2005
chuck.
Nah, it's like a 4 banger that's been turbo charged and is putting out 300hp...you know there's little room before internals on the motor has to be changed so you''re pretty much pushing the motor to it's limit which I like....
I would hate to think I have 3/4lbs of thrust left on the bench when I'm flying a 70mm
With other motors you have what I call head room, they'll absorb the extra .14 - .25 volts per cell that a good 65c packs puts out and does it without whining....where the 12usd motors from HK wont do such for long...going back to ICE analogy the HETs are 6 cylinder engines and will put out more RPMs for same octane gase and even more with higher octane gas...where the other internal combustion engines will just burn up but for budget reasons they're good for what they cost.
The HETs also put out more RPMs with change of timing or pwm that doesn't heat up the ESC etc...
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7289 Yesterday 01:24 AM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
