Old Nov 01, 2012, 12:36 PM
Flazo is offline
Find More Posts by Flazo
JUNK RADIO
Flazo's Avatar
USA, NY, Queens
Joined Dec 2006
you are right
Originally Posted by davecrash View Post
That's 4250kv, I don't think so.
what about the ARC-28-58-1?
fred
Recomended Output: 1+ kW
KV: 3180
Weight: 153g
Shaft: 3.2 mm
Poles: 4
This is Dave's answer to the ultimate EDF motor. Built for 70mm EDF fans such as the WeMo 480 and the HET 6904. 5S is safe, anything higher is considered "experimental." Even at 5S, extreme care should be taken; balancing the rotor is vital to your health and safety (as well as the health and safety of the motor and your plane). Please keep all fingers and body parts clear of the fan when this motor is running. If a blade breaks, bad things can happen - BE WARNED! These motors are only recommended for experienced RC enthusiasts who are safety conscious.
Flazo is offline Find More Posts by Flazo
Old Nov 01, 2012, 12:55 PM
davecrash is offline
Find More Posts by davecrash
Fly now crash later
davecrash's Avatar
Canada, ON, Newmarket
Joined Nov 2006
fred
KV: 3180
Weight: 153g
Shaft: 3.2 mm
Poles: 4
Even that is some serious amp draw on the CS at 6S. A friend of mine just messaged me that he has the BL32 motor BNIB. Looks like I'm going to use that one in my Viper build.
davecrash is offline Find More Posts by davecrash
Old Nov 01, 2012, 01:28 PM
420flyboy is offline
Find More Posts by 420flyboy
Mile High EDF
420flyboy's Avatar
United States, CO, Denver
Joined Jul 2011
I used that motor with Tams 5mm adaptor and spinner , that eflite motor is a good motor , on 6s I got around 70amps on the bench.
I'm putting that HK 70mm 10 blade alloy unit on 6s in my HK viperjet that's being delivered today.
420flyboy is offline Find More Posts by 420flyboy
Old Nov 01, 2012, 01:52 PM
TheCure is offline
Find More Posts by TheCure
Wats the worst that can happen
TheCure's Avatar
Canada, BC, Surrey
Joined Jan 2009
Are there yet available reverse-rotation CS 70mm fans?
TheCure is offline Find More Posts by TheCure
Old Nov 01, 2012, 05:43 PM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
This would be a 4 cell motor, maybe 5 if you didnt care about amp draw
The HET 1W40 is imho a better choice though, in back to back 6s tests with the Wemo fan the 1W40 is pushing 2.8kg thrust at 2060w, the 2858 does 2.5kg at 1880w.
In the CS fan the 1W40 would be a great 4s motor, maybe even 5s for the adventurous
Extreme_RC is offline Find More Posts by Extreme_RC
Old Nov 01, 2012, 06:16 PM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
The BL32 is 'almost' a nice 6S motor for the CS10....
Great specs.... 5mm shaft.... good quality and price for that.
But at 2150kv it won't quite get used to its maximum capability. If it was 2300kv it would.
It will be "under utilised" (eg more strength and build capability, that it won't reach in a CS10), which I guess will give you a longer life-span at least.
The HET 2W30 at 2200kv, is running a pretty good out put level, but it also would do that bit better if it was 2300kv. But at 2200kv it is marginally more output that a BL32 - because of its bit higher KV and that it is much the same build and capability motor, so it will drive the CS10 effectively at 2200kv.
Both those motors could drive a CS10 at 2300kv effectively. (due to their build/strength)
Ideally there would be some good level of build 2300kv motor, and the 2200kv's can be left for 'high power', and 2300kv for 'very high power', choices.
At the other end of the scale is the L2855-2100kv.... it can NOT drive a CS10 'effectively', because it is not a strong enough build to cope wit that task properly. It is well over-stressed by then.
And if you want a 2300kv to try..... hehe.... use a L2855-2300kv on 6S. For the 2 seconds that will last....
I am pretty sure that Leopard does have a 2300kv motor, of that HET and BL32 build level.
2860 size.... so it is really even a bit more capable than those (or at least equal).
The problem with a lot of the Leopards that are useful for CS10/CS12, is that they MAKE them, but no one SELLS them! They only sell Boat/Car suited KV levels, and don't stock the rest. It is like trying to find hens teeth!!
Here:
Leopard have a 2860-2260kv... but try finding where to buy one!! At 2260kv it is another bit of a step above the HET 2200kv.
http://www.leopardhobby.com/product/...ionID=01020204
PeterVRC is offline Find More Posts by PeterVRC
Old Nov 01, 2012, 06:21 PM
Fly now crash later
davecrash's Avatar
Joined Nov 2006
I have every intention of going 7S at some point with this setup.
Old Nov 01, 2012, 06:27 PM
PeterVRC is offline
Joined Nov 2006
Well if you plan on that, then lower KV is more useful for when you do move up.
And the 5mm shaft is a nice bonus.
Old Nov 01, 2012, 07:00 PM
PeterVRC is offline
Joined Nov 2006
This was almost a good source....
http://www.offshoreelectrics.com/pro...?prod=leo-2860
They don't sell the 2260kv, sheesh
$59 is a good price.
Or....
2040kv (6S mild) and 2260kv (6s wilder).... but in the version that has the motor lead 'block' on the end side - at least in his pics. (there are 'wire out the end' versions)
http://shop.rcboatbitz.com.au/index....ex&cPath=47_24
Old Nov 01, 2012, 07:23 PM
Fly now crash later
davecrash's Avatar
Joined Nov 2006
The HET 2W-30 was my first choice, but a friend just happened to have the BL32.
Old Nov 01, 2012, 09:14 PM
chas650r is offline
Find More Posts by chas650r
chuck
santa barbara, CA
Joined May 2009
The more I read the more I don't see the L2855 2100kv lasting any kind of time on 6S. Bench test today on 5S 2650mah 30C turnigy lipo gives me about 1:1 thrust in the Phase3 F-16. This will do for the maiden flight but I'm leaning towards the HET motors. most likely the 2W-30 and maybe the 3W-25. anybody want to trade for a BNIB 2W-20.
ya , a < 100 gram motor at 1600 watts = smoke. most likely wont even make a very good heater
chas650r is offline Find More Posts by chas650r
Old Nov 02, 2012, 01:40 AM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
Not if it's an outrunner, plenty people running the 2100kv on 6s...don't use 65c packs...extra .25 - .50 volt hurts stuff...a lot of stuff.
erh7771 is offline Find More Posts by erh7771
Old Nov 02, 2012, 01:51 AM
PeterVRC is offline
Joined Nov 2006
But my two (in a row) 2100kv's blew up on 30C even....
And at 55A-56A area you need 30C to get to that Amp level. (need that level of IR for it all to balance out to that volt/current level). It would have been about 21v x 55A = 1150W area.
20C might do something like 52A (20.4v x 52A = 1060W, safe)..... 40C towards 60A (21.3v x 55A = 1278W, ouch..... 65C, hmmmm, 66A+ ?? (21.6v x 66A = 1420W, instant smoke!)
Just guesstimated V/A numbers, in the ballpark.
So it would seem to me that 30C is the max to be safe with... if even that.
I just wouldn't even use them on 6S..... (again)
Old Nov 02, 2012, 01:56 AM
anlucas is offline
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
I think Peter's electrical numbers are on the ballpark.
Thrust figures may be different due to the different test stands. I don't think it's likely that we will ever get to get comparable results between all the different test stands.
anlucas is offline Find More Posts by anlucas
Old Nov 02, 2012, 02:03 AM
PeterVRC is offline
Joined Nov 2006
You would HOPE that if everyone used vertical stands they would have to be the same??
Digital 'quite good accuracy' - even from any kitchen variety digital scale unit
No friction losses
Nothing left for people to mess up accuracy with! LOL
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7194 Dec 14, 2015 04:03 PM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 08:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 07:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 02:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 10:36 AM
