Old Oct 28, 2012, 05:48 PM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
How to bend a motor shaft.....
I had a 2550kv RC Lander alloy fan, which has a quite nice and hefty 2960 motor in it. No name on it, but looks just like a HET. Same cooling cutouts etc.
But it has a 3.17mm shaft....
A bit of a nuisance on such a 'big' motor.
I fit the stock CS10 3.17mm adaptor, and it was a tight nice fit. I spun it up and it was 'very' true - no runout to be seen (run a steel ruler edge on it as it runs)... so to me it looked easily acceptable.
I used red loctite to lock the adaptor to the shaft, with blue loctite for the 4 grub screws.
Static balanced the CS10 rotor... fit that and low/mid RPM run it up to check vibration. It was good.
Test on 4S..... wind up to full RM and it does 600g thrust. LOL, weak thing it was....
Run it up on 5S (videoing all tests) and before I could even look at numbers, it went.... ummmm.... some strange noise anyway.... so I stopped it immediately.
Hmmm, the rotor is about 5deg, or so, off level..... something bent. Motor shaft most likely.... pull it apart.... yep.
What the.....????
With no test run up vibrations felt, it should have been balanced well enough for that to never happen! So I am not sure why it did.
It was easy enough to "straighten" the shaft by hand, on the adaptor..... so that is a very soft motor shaft!!
3.17mm...... soft shaft..... asking for trouble!!!
But it was a very nice LOOKING motor.....
PeterVRC is offline Find More Posts by PeterVRC
Old Oct 28, 2012, 05:55 PM
PeterVRC is offline
Joined Nov 2006
The current Lander 10 blade 70mm uses a 3.17mm shaft too. And it is also a 2960, but 2190kv approx. So a good chance it is the same motor, just a different kv version.
I would be worried about that!!!
$72 balanced and ready to run. 1900w capable (yeah???)
The RC-Castle CyclonePower 10-blade is $84 but has a 4mm shaft 2960 2200kv.(1500w capable - a bit more realistic a number)
But not assembled.
It is a little bit lighter too (277g total instead of 313g).
Both seem to have 29mm+ motors and housing. Though they are not the same housing unit. Both have screw off lips.
The motors look quite similar, but not exactly the same.
Both probably perform very much the same I would expect.
I would pick the CyclonePower combo!! 4mm shaft. To be safer.....
Old Oct 31, 2012, 02:27 PM
davecrash is offline
Find More Posts by davecrash
Fly now crash later
davecrash's Avatar
Canada, ON, Newmarket
Joined Nov 2006
I have the L2855 2100kv that im going to run on 6S, I have read some posts that it's failing after awhile. What timing are you guys running it on when it's failing? I'm thinking that low timing might help.
davecrash is offline Find More Posts by davecrash
Old Oct 31, 2012, 02:37 PM
anlucas is online now
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
Low timing for sure.
anlucas is online now Find More Posts by anlucas
Old Oct 31, 2012, 04:39 PM
St. Martin is offline
Find More Posts by St. Martin
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
Originally Posted by Extreme_RC View Post
My adapters are designed to work with stock rotor and spinner, or my spinner, and should work no problem with their spinner if its at least the same height as mine internally, so measure it and let me know.
Hi Mark, Tams spinner is taller than yours. Your fits directly to the rotor hub. Tams has a large washer the same dia as the hub. His spinner rides on top of the washer, in a machined lip. Your spinner will work with Tams adapter, but not his washer. Your washer is required.
Fuzz
St. Martin is offline Find More Posts by St. Martin
Old Oct 31, 2012, 05:32 PM
Fly now crash later
davecrash's Avatar
Joined Nov 2006
I ordered one of Tam's adaptor spinner combo's to try, The stock one I have is slightly off.
Old Oct 31, 2012, 06:20 PM
capt soap is offline
Find More Posts by capt soap
capt soap's Avatar
dallas tx
Joined Jun 2003
Without reading all these threads, whats the max watt's/thrust anyone has got out of this fan without blowing it up???
capt soap is offline Find More Posts by capt soap
Old Oct 31, 2012, 06:33 PM
Fly now crash later
davecrash's Avatar
Joined Nov 2006
Has anyone tried the ARC motors on 6S? I'm looking at the 28-48-2. The 28-48-3 is only 1500 kv. Probably too low for 6S
Old Oct 31, 2012, 09:56 PM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
3000 watts...7lbs of thrust...
I have a vid of the run in my YT page
erh7771 is online now Find More Posts by erh7771
Old Oct 31, 2012, 09:58 PM
Joined Nov 2005
Matters what you're looking for ...
I was thinking two 1800kv would be good for over 7lbs of thrust 6s
Joined Nov 2005
Sounds like 10 second burst on 6s is good for the 2100kvs....
Old Oct 31, 2012, 10:48 PM
Fly now crash later
davecrash's Avatar
Joined Nov 2006
The more I read the more I don't see the L2855 2100kv lasting any kind of time on 6S. Bench test today on 5S 2650mah 30C turnigy lipo gives me about 1:1 thrust in the Phase3 F-16. This will do for the maiden flight but I'm leaning towards the HET motors. most likely the 2W-30 and maybe the 3W-25. anybody want to trade for a BNIB 2W-20.
Old Nov 01, 2012, 12:16 AM
nighthawk0077 is offline
Find More Posts by nighthawk0077
Canada, ON, Vaughan
Joined Oct 2009
I hope so. Ive got one all ready to go for this weekend. Its setup on high timing right now and 1400watts.
nighthawk0077 is offline Find More Posts by nighthawk0077
Old Nov 01, 2012, 06:44 AM
Flazo is offline
Find More Posts by Flazo
JUNK RADIO
Flazo's Avatar
USA, NY, Queens
Joined Dec 2006
I think is the
28-48-1 on 6 cells.
Flazo is offline Find More Posts by Flazo
Old Nov 01, 2012, 10:57 AM
Fly now crash later
davecrash's Avatar
Joined Nov 2006
Originally Posted by flazo View Post
28-48-1 on 6 cells.
That's 4250kv, I don't think so.
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7224 Apr 21, 2016 02:53 AM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
