Old Oct 25, 2012, 10:15 AM
Jetnfast is offline
Find More Posts by Jetnfast
Jetnfast's Avatar
United States, CA, Temecula
Joined Feb 2008
Anyone run the CS70mm rotor, eflite 3200kv, and the Delta V-15 shroud on 5s? I know its a proven combo on 4s for around 1000w, but I was curious what type of numbers come out on 5s?
Jetnfast is offline Find More Posts by Jetnfast
Old Oct 25, 2012, 10:37 AM
anlucas is offline
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
It would draw too much current on 5S. Probably more then 120amps.
I 've had 3300kv motors pull 90-105amps on 4S with this rotor so 5S is prohibitive on anything more than 2800kv and even then, it has to be a well engineered motor for high current. Also, the motor can/bell has to be in the air stream and be able to handle the generated by 80+amps.
anlucas is offline Find More Posts by anlucas
Old Oct 25, 2012, 10:46 AM
chas650r is offline
Find More Posts by chas650r
chuck
santa barbara, CA
Joined May 2009
agreed, 5's w/ the eflight rotor is shown to be doable , but a bit of a heater at that. more rotor load will release the magic smoke.
chuck.
chas650r is offline Find More Posts by chas650r
Old Oct 25, 2012, 09:34 PM
Jetnfast is offline
Jetnfast's Avatar
Joined Feb 2008
chuck.
Good feedback thanks. I will plan on running 4s for now. I will be running tam's heatsink and tail cone with an ice 100 stuffed in there so I think the motor will be cool regardless if I run on 4s or "experiment" with 5s.
Old Oct 26, 2012, 12:09 AM
imyohero is offline
Find More Posts by imyohero
F-OFF
imyohero's Avatar
Joined Mar 2007
Hi guys this might sound stupid but what is the dia of the rotor hub ?
imyohero is offline Find More Posts by imyohero
Old Oct 26, 2012, 03:58 AM
MagnusEl is offline
Find More Posts by MagnusEl
MagnusEl's Avatar
Sweden, Gävleborg County
Joined Jan 2004
It`s 30mm.
MagnusEl is offline Find More Posts by MagnusEl
Old Oct 27, 2012, 10:36 AM
mopetista is offline
Find More Posts by mopetista
Vienna, Austria
Joined Apr 2007
CS70 with soft shroud - different type of plastic
Just found out that one of my CS70 shrouds is substantially softer than the usual
ones. I THINK (not 100% sure) that this is the last one I bought, on Aug 10th.
Don't know if the rotor is also softer, but the shroud definitely is, it bends a lot
in the front part (unsupported by vanes like the rear part), there it is also a bit
thinner. It's a different, more supple plastic, I usually sand away the imperfections,
this plastic is not easy to smoothen, typical for soft plastic.
Anybody else with similar experience?
thx
Clemens
mopetista is offline Find More Posts by mopetista
Old Oct 27, 2012, 11:18 AM
4stripes is online now
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
I hope they didn't cheap out on the plastic like what happened on the 90mm 12 blade earlier this year! Caused me many failures and I didn't want to build up any more till the quality was improved. Thankfully the 90mm fans are produced with much stiffer plastic than ever.
4stripes is online now Find More Posts by 4stripes
Old Oct 27, 2012, 03:00 PM
Jetnfast is offline
Jetnfast's Avatar
Joined Feb 2008
Uh oh! I just ordered some rotors from HK, hopefully their good!
Old Oct 27, 2012, 07:27 PM
pencon is offline
Find More Posts by pencon
Joined Dec 2008
I just put an order in for one of these units to go with my BL32 and 6s http://rc-castle.com/shop/product_in...oducts_id=2861 .I was wondering if you can just bore the adapter out to 5 mm on a lathe ? One more question - Is RC-Castle an ok retailer? This is my first order from them .
pencon is offline Find More Posts by pencon
Old Oct 27, 2012, 08:00 PM
bamaguy is offline
Find More Posts by bamaguy
Don't Move I've Dropped My Nut
bamaguy's Avatar
United States, AL, Huntsville
Joined Feb 2009
They are very well regarded! You could order a 5mm adapter for the CS-10 fan from Tam Jets...or Extreme RC as scunna indicated!
http://www.tamjets.com/original/prod...roducts_id=689
bamaguy is offline Find More Posts by bamaguy
Old Oct 27, 2012, 08:24 PM
Jetnfast is offline
Jetnfast's Avatar
Joined Feb 2008
That would probably be your best bet, to order one from Tam. Plus his are precision balanced. You can even get the nice spinner nut to go with it. I just ordered all that I mentioned to go with my eflite Delta V 15.
Old Oct 28, 2012, 06:00 AM
scunna is offline
Find More Posts by scunna
scunna
scunna's Avatar
United Kingdom, England, South Shields
Joined May 2007
Order the adapters from Exremerc there perfect for bl-32
scunna is offline Find More Posts by scunna
Old Oct 28, 2012, 12:30 PM
pencon is offline
Joined Dec 2008
The RC-Castle fan already has an aluminum spinner , I wonder if the Tam or the Extreme would fit with it ?
Old Oct 28, 2012, 05:36 PM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
My adapters are designed to work with stock rotor and spinner, or my spinner, and should work no problem with their spinner if its at least the same height as mine internally, so measure it and let me know.
Extreme_RC is offline Find More Posts by Extreme_RC
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7232 Jun 06, 2016 02:40 AM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
