santa barbara, CA
Joined May 2009
well it looks like it would be in the 90 amp range on 4's . imo it takes a lot of battery to support that kind of current draw. i guess it depends on what u put it in and what u want it to do. in the upper end of the wattage range higher cell count and less current is always better, but in this case that would take lower kv.
chuck. |
Australia, VIC, Melbourne
Joined Nov 2006
I assume you had that motor in a 4,5,6 blade fan before. 3300kv, and the Amps it will run, mean a costly battery needed. But when you have a motor, and want to make use of that, you can often end up needing BIG compromise - in this case costly battery, and lower efficiency of huge currents.
It is a nice motor, but just not greatly suited to a CS10. A shame. 3000kv would have been nicer. By the time you hit these power levels due to KV at 4S, you really would have wanted to plan a 6S system (or at least 5S), so you can use far more economical battery solutions (much lower C only required). But an $80 nice motor...... makes it hard to 'waste' it...... but add up what OTHER waste that using it will cause too! |
Australia, WA, Perth
Joined May 2007
Higher voltage doesn't mean you need a lower C rating at all.
If the battery pack remains the same weight, there is no difference in the capacity / current ratio Example: A 6s 4000mAh battery, and a setup that pulls 80A. That's 20C. A 4s 6000mAh battery (same weight), a motor with 1.5x the kv, so the same power output, but a current of 120A. That's still 20C... Using a 6s 6000mAh battery is not a level playing field - that's when the C can be reduced, but that's not a fair comparison. |
Joined Nov 2006
But.....
1330W 4S 90A 5000mAH to get 3.3mins WOT, 65C costs $71 1330W 6S 60A 3300mAH to get 3.3mins WOT, 65C costs $66 So for a start that was cheaper.... $5 of waste (same brand batteries for comparison - same total 'current leeway above what was needed)) Even though mathematically you 'need' the same C to get the same 'current leeway', the 6S could use 45C fine but the 4S with such huge current numbers would be less impressed supplying that at 45C. The larger the currents the less they 'like' doing it. Then the ESC.... needing 100A instead of 70A..... more cost, for no benefit in outcome = waste. 90A instead of 60A... more current 'dangers'/heats and issues. (not a great deal, but still worse than lower current) Inefficiencies of higher current.... need larger wires to be equal, larger connectors, or will drop a fraction more volts.... = waste (relative to a lower current system) Had to have motor capable of 90A, not just 60A (same Watts capable... that is a different limit). So that will be choice/range limiting...and likely even cost. TONS of 28mm motors can do 60A fine, but not many can do 90A! There is no way a 4S "equal power' system is ever better, or even equal, to a 6S combo. It is just a wasteful economy of scale. I would say there is a cut off CURRENT point.... something like 60A to 70A, where you just don't do that, you move UP in VOLTS instead. (in 90mm that is more up around the 100A or so point - though pref to still move up volts instead by the 90amps or so area I think) |
The Velocity-RC 2900 kv, 4mm shaft (geniuine Velocity-RC motor) is another option for 5s
http://www.effluxrc.com/Velocity-Hig...28-60-2900.htm or MEGA 16-40-1.5RC (2270) with a 5mm shaft, for 6s http://www.effluxrc.com/Habu-32-6s-h...16-40-15RC.htm |
Joined Nov 2006
Looks nice specs on that Velocity... but I would think more for 4S for a CS10.
By 5S you would really be running huge demands.... 80A to 90A. 2500kv, or a bit more (to 2600kv?), is about 5S useful limit (already 70A area) ad big output numbers. At $84 it looks and specs much like a HET (similar price area, 2W23 but the 4mm shaft on the Velocity is a winner), or even Leopard have much the same spec/size/look motor too (with 4mm shaft). |
I corrected the MEGA motor. I meant the 2270kv version. It's similar to the E-flite BL32 motor( for the Habu 32), only 120KV higher, and 61.5mm long.
(Thx Gryphon!) Your right peter, I forgot the rotor won't take much more than 46K rpm. ....4s for the Velocity-RC motor. 6s for the MEGA. I'm used to the higher power, faster stuff. 80-90A is quite satisfactory.(even a bit low for WOT) |
Joined Nov 2006
Mine haven't exploded yet (2W30 6S CS10 twin)....
But I use 30C and probably (forget if ever measured) about 35k rpm area (more?) due to voltage drop. I would think 65C's could go more towards 38k RPM 2000kv area is more a "good power" level to use, but 2200kv should be fine as a "high power" level - not excessive and explode the fan. But it is getting up towards there. Maybe there was some other reason it (they?) failed? |
So fit the mega motor to a CS10 and post up the results, if its substantially better than the BL32 then it may be an option for some people. As it is the BL32 is 75 bucks and the mega is double.
Oh and I dont sell BL32 motors, doesnt mean I dont think they are an excellent motor... |
| Thread Tools | |
| New Product Change Sun 12 blade 90mm | Flip Flop | Electric Ducted Fan Jet Talk | 6431 | Yesterday 12:52 AM |
| New Product Change Sun 120mm and new 10 blade 70mm fans | Flip Flop | Electric Ducted Fan Jet Talk | 131 | Apr 27, 2012 07:07 PM |
| Sold Change Sun electric retracts | Flip Flop | Aircraft - Electric - Jets (FS/W) | 3 | May 23, 2011 06:20 AM |
| Sold Change Sun Electronic retracts w/Lander struts | hole digger | Aircraft - Electric - Jets (FS/W) | 2 | May 06, 2011 01:27 PM |
| Sold Change Sun Electric retracts NIB 75.00 | jzuniga | Aircraft - Electric - Jets (FS/W) | 2 | Sep 03, 2010 09:36 AM |
