Old Oct 21, 2012, 01:04 PM
manuel v is online now
Find More Posts by manuel v
manuel v's Avatar
Mexico, BC, Mexicali
Joined Aug 2004
A plot of EDF Wemotec 68mm and another Changesun 70mm 10 blades.
Consider that for the same power and thrust in the EDF Changesun requires a lot less Kv motor.
Manuel V.
manuel v is online now Find More Posts by manuel v
Old Oct 21, 2012, 01:14 PM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
Manuel V.
Yeap, more blades & less RPM = less rotor whine but turbine like balanced wemo can be just as quite at high RPMs
erh7771 is offline Find More Posts by erh7771
Old Oct 21, 2012, 01:27 PM
manuel v's Avatar
Joined Aug 2004
Originally Posted by GryphonRCU View Post
Hi Manuel V.,
I was looking for %KV. You have it in there.
Nice job.
Thank you,
Gryphon
Yes.
%Kv is same to %NLS
To calculate your fan rpm’s:
This is wrong.
Take the voltaje of the battery and multiply the Kv of the motor = fan RPM.
11.1V x 3600= 39,960.
A reality more about:
3 cell lipo, have a voltage of approximately 12.6Volts.
The new batteries 30 and 20 C 40C sustain discharge voltage 11V average. (Use the voltage rating is very rough and correct)
A very important factor that is missing from this equation is the NLS% (percentage of No Load Speed.)
In EDF is very important that the engine is not charged too much for this factor does not drop below 80%. Possibly in some applications where the motor is much torture can be used up to 75%. But it is highly not recommended.
Also consider the actual motor Kv can vary the die post for the manufacturer.
Take the voltaje of the battery and multiply the Kv of the motor and multiply for %NLS factor = fan RPM.
11.1V x 3600 x 80%= 31,968 RPM.
To Calculate what Kv motor you need:
Take the desired fan RPM, divide it by the battery voltaje = Need ed motor Kv.
45,000 / 14.8 = 3,040 kv.
As in the example above to factor% NLS,
45,000/14.8=3040*100/80= 3800 Kv.
Manuel V.
Old Oct 21, 2012, 02:05 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
Manuel,
Your calling motor efficiency %kv?
Eric B.
AirX is offline Find More Posts by AirX
Old Oct 21, 2012, 02:27 PM
mopetista is offline
Find More Posts by mopetista
Vienna, Austria
Joined Apr 2007
upper limit on motor efficiency at certain load
%kV, %NLS - I understand that to mean that under load the motor is revving at
lower RPM than at idle (no load).
Now there is a connection with motor efficieny, just don't know where I read that,
I think in a post by Juergen Heilig:
An electric motor can never have a higher efficiency (eta, in %) than exactly that
ratio, no load speed vs. speed under load (at the very same voltage, that is
important, and I think that is what Manuel V just pointed out).
While that is only putting an upper bound (cap) on the otherwise unknown motor
efficiency, it is still useful because by measuring RPM we can avoid a typical
mistake, i.e., overloading the motor (resulting in bad efficiency, lots of heat etc.)
That is happening very often because of the much higher load of high-blade fans
compared to the old-style 5- or 6-bladers. But this is known to readers of this
thread :-)
So the 80% rule is not bad in practice: Choose a setup so that your motor is
still having 80% of no load RPM under load.
However that requires that you measure no load RPM and record voltage
with precision (published kV figures cannot be trusted) and do the same under
load, then linearly approximate no load speed for the actual voltage under load.
OR use common sense: A cheap 100g outrunner with kV lower than 3000 will
be pretty efficient up to 40A, at 50A not so much anymore, and everything above
that will turn it into a good heating device...
Did my best and wrote a lot about simple facts, but I hope that it is at least
clear enough...
mopetista is offline Find More Posts by mopetista
Old Oct 21, 2012, 05:57 PM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
Manual,
Any chance of rearranging the graphs to be grams v watts, with both fans plotted against each other?
Ideally, with a line of best fit to smooth out the noise?
Odysis is offline Find More Posts by Odysis
Old Oct 21, 2012, 06:34 PM
manuel v's Avatar
Joined Aug 2004
Originally Posted by AirX View Post
Manuel,
Eric B.
No.
Efficiency is the percentage obtained from the input power vs. power converted into work.
% NLS, Kv is the percentage of an motor resulting loading vs unloaded Kv.
I will always be greater than% efficiency.
In an EDF is very difficult to measure efficiency.
But you can easily measure the% NLS.
If a motor of 1000 Kv, is feed with 10volts, instead turn rotates to 10,000 rpm, rotate a 7,000 rpm, then the% NLS is 70%.
Manuel V.
Old Oct 21, 2012, 06:51 PM
Jetsom is offline
Find More Posts by Jetsom
Formerly "Heli Copter"
Jetsom's Avatar
United States, CA, Watsonville
Joined Apr 2009
Originally Posted by erh7771 View Post
lol...did that a 10 go vertical after 20 feet?
nice...
any watts\thrust numbers on the set up?
was it the 3300kv eflite motor?
regards
Motors are E-flite BL32, 2150kv both running on one 6S nanotech 5000mah 65-130C. Each motor is running peak 75 amps and 1600 watts. I haven't measured thrust, but the Jet weighs 7lbs. 11oz. and the thrust is better than 1:1. Most flying is done around half throttle, but full throttle verticals are excillerating.
Jetsom is offline Find More Posts by Jetsom
Old Oct 21, 2012, 09:51 PM
chas650r is offline
Find More Posts by chas650r
chuck
santa barbara, CA
Joined May 2009
the 75 to 85% of no load rule is exactly what i use on all prop driven planes also. seems to work well from a heating / efficiency standpoint. in the prop driven world, i find lots of people who love to over prop and then brag how their 100 gram motor is drawing 850 watts, funny
chuck.
chas650r is offline Find More Posts by chas650r
Old Oct 22, 2012, 05:41 AM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Originally Posted by mopetista View Post
snip>So the 80% rule is not bad in practice: Choose a setup so that your motor is
that will turn it into a good heating device...<snip
And here I thought that the wire size/quality had everything to do with how much internal resistance cuased a percentage of power to be consumed into waste heat.
Which I was of the understanding was the cause for less rpm as load rises. The rotor load demands stronger magnetic feild which causes the amperage rise which causes the wire to heat up, while amperage rises voltage drops to hold power, voltage drops and rpms with it. Where is the mystical aspect coming from?
Eric B.
Old Oct 22, 2012, 11:39 PM
manuel v's Avatar
Joined Aug 2004
Originally Posted by Odysis View Post
Manual,
Thrust is calculated at 3% unless Wemo a certain power.
according to the opinion of erh7771.
The data were adjusted slightly to seat Watts RPM and linearity performance curve. (This would be like if all engines tested were of the same brand, efficiency and capacity.)
EDF Wemotec data are taken from the website:
http://www.extremerc.com.au/estore/i...ex&cPath=14_62
Manuel V.
Old Oct 23, 2012, 12:10 AM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
Wouldn't you also want to plot Power versus Thrust?
That would be a handy curve too.
PeterVRC is offline Find More Posts by PeterVRC
Old Oct 23, 2012, 12:37 AM
manuel v's Avatar
Joined Aug 2004
If you select a blue dot, find power and RPM.
If upright extensions that point to find the thrust that power in magenta points.
Manuel V.
Old Oct 23, 2012, 03:58 AM
PeterVRC is offline
Joined Nov 2006
No, but you don't see a curve then. You only get single point values. And have to do it manually too.
The curve is to compare one fan to another in terms of power needs for thrust.
Old Oct 23, 2012, 04:27 AM
sjw985 is offline
Find More Posts by sjw985
It's watts for dinner
United States, GA, Marietta
Joined Oct 2011
Which A-10 is that? I haven't been tempted up to this point but your vid made me want one...
sjw985 is offline Find More Posts by sjw985
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7232 Jun 06, 2016 02:40 AM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
