Old Oct 19, 2012, 11:46 AM
alex_blais is offline
Find More Posts by alex_blais
Montreal, Canada
Canada, QC, Montreal
Joined Mar 2010
balancing problem
Hi there,
I got 2 x 70mm 10 blades from HK. Both shafts were out of true from inner dia to outer dia.
I ballanced the fan, bought 4 extra shafts from HK but they are all out of wack.
I would say the runnout on the shafts is at least .010''
I tried with a few HET and Mega motors that run super smooth with other fan setups.
Does anyone know where I could get shafts that are very acurate for this fan?
alex_blais is offline Find More Posts by alex_blais
Old Oct 19, 2012, 11:56 AM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
Originally Posted by alex_blais View Post
Hi there,
There are two companies that sell shaft adapters that are true, Tamjets and Extreme RC. Tam offers 4mm and 5mm shafts and Extreme RC offers 3.17mm,4mm, and 5mm shafts adapters.
Check them out.
Eric B.
BTW I am running Tams equipment but i know Mark at Extreme and he puts out good equipment so its up to your needs.
AirX is offline Find More Posts by AirX
Old Oct 19, 2012, 12:13 PM
anlucas is online now
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
Hi there,
I use these
http://www.extremerc.com.au/estore/i...th=146_266_319
Install and forget...
anlucas is online now Find More Posts by anlucas
Old Oct 19, 2012, 12:20 PM
manuel v is offline
Find More Posts by manuel v
manuel v's Avatar
Mexico, BC, Mexicali
Joined Aug 2004
Trying to get a better picture of this fan, gather the data that is in this forum and graph data from RPM, Thrust, Watts.
The result is somewhat bizarre that the data is not accurate and some comp RPM was calculated.
This graph can be improved with clearer information on the actual RPM.
But still gives us an idea.
Serie 1, Blue is RPM vs Watts in.
Serie 2, Magenta is RPM vs Thrust in grams.
Manuel V.
manuel v is offline Find More Posts by manuel v
Old Oct 19, 2012, 04:45 PM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
manuel v,
Can you show us how you calculated some of the RPM?
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Oct 19, 2012, 07:02 PM
manuel v is offline
manuel v's Avatar
Joined Aug 2004
Im use this criterion.
Post 372.
http://www.rcgroups.com/forums/showt...v#post18901297
Example
When using Excel, combined with EDF Changesun graph, we can obtain the following information:
If we want to 28.000 RPM,
It requires:
An engine 90 to 150 grams,
With Kv:
A 4slipo = 2.328.
A 5s lipo = 1863.
A 6slipo = 1552.
Consume 850-900 watts,
And we give a thrust of 1400 grams.
All these data are approximate.
If we want to 32.500 RPM,
It requires:
A motor 110 to 180 grams,
With Kv:
A 4slipo = 2.660.
A 5s lipo = 2.129.
A 6slipo = 1.174.
1000-1100 watts consumed,
And we give a thrust of 1700 grams.
If we want 40,000 rpm,
It requires:
A motor 160 to 260 grams,
With Kv:
A 4slipo = 3.326.
A 5s lipo = 2.661.
A 6slipo = 2.217.
1550-1650 watts consumed,
And give us a boost of 2000-2200 grams.
Just consider that what we seek is 1800-1900 grams and that will push with 8slipo.
For this the Excel and the chart will tell us that we occupy:
As 37.500 rpm,
An engine of 1560 Kv.
With a weight of 140-230 grams.
And consume about 1400 watts.
Now if we have an motor of 3000 Kv and weighs 90 grams.
That would result in EDF Changesun 70mm 10 blades.
This work 4slipo engine in the range of 35 to 36.000 rpm and in the range of 1250 watts.
Therefore it would not be viable.
To 3sLipo work in the range of 27,000 RPM in the range of 700-750 watts.
Therefore it would be the only thing that could work.
Produce as 1400 grams of Thrust.
Manuel V.
Old Oct 21, 2012, 04:42 AM
GryphonRCU's Avatar
Joined Mar 2008
Hi Manuel V.,
I was looking for %KV. You have it in there.
Nice job.
Thank you,
Gryphon
Old Oct 21, 2012, 06:32 AM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
Hi there,
Try twisting the shaft adapter onto the shaft while pushing down to get the adapter to bottom out on the shaft....works like a charm for me every time...no run out on the shafts even the old ones.
erh7771 is online now Find More Posts by erh7771
Old Oct 21, 2012, 06:34 AM
Joined Nov 2005
Manuel V.
I look at wemo data and subtract around 3%....I've been on the mark every time...watts\thrust
The wemo data shows volts\amps\thrust\efflux speeds etc....very thorough data
Old Oct 21, 2012, 09:18 AM
Galand is offline
Find More Posts by Galand
Galand's Avatar
Long Island, NY
Joined May 2010
Do you have a link for that data?
Galand is offline Find More Posts by Galand
Old Oct 21, 2012, 10:22 AM
chas650r is offline
Find More Posts by chas650r
chuck
santa barbara, CA
Joined May 2009
+1
chas650r is offline Find More Posts by chas650r
Old Oct 21, 2012, 10:28 AM
Joined Nov 2005
http://www.rcgroups.com/forums/showthread.php?t=1167099
Interesting....
It was the eflight housing, wemo rotor
An altogether different set up I tried is...
E-flite housing, Medusa 2800kv motor, Wemo mini rotor on 6s. I have no idea if the motor will survive the high current.
6S Wemo rotor
25.09v-21.69v, 97.7A, 95.6ozT, 2151W, 59,350rpm 224mph efflux, 2714kv underload. Initial no load testing showed kv closer to 3200.
anyone try the CS rotor in the eflight housing?
Regards
Old Oct 21, 2012, 12:16 PM
Jetsom is online now
Find More Posts by Jetsom
Formerly "Heli Copter"
Jetsom's Avatar
United States, CA, Watsonville
Joined Apr 2009
Interesting....
Regards
Here is the CS rotor in an E-flite V-15!
StokHabu 3300 Passes (1 min 35 sec)
Jetsom is online now Find More Posts by Jetsom
Old Oct 21, 2012, 12:19 PM
Jetsom's Avatar
Joined Apr 2009
Interesting....
Regards
Here is two CS rotors in two V-15 housings!
Nicks A10 (7 min 48 sec)
Old Oct 21, 2012, 12:40 PM
Joined Nov 2005
http://www.youtube.com/watch?v=a3L7D...e_gdata_player
lol...did that a 10 go vertical after 20 feet?
nice...
any watts\thrust numbers on the set up?
was it the 3300kv eflite motor?
regards
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7243 Jul 18, 2016 07:09 PM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
