Yup, 3.17 four screw adapters are crap, and you will be lucky if you can make 'em run true. The idea there is some super secret offset drill process that purposely moves the bore off the centerline is just laughable on it's face, both on technical grounds, and also since this is obviously such a cheapo Chinese mass produced piece anyway. |
Australia, VIC, Melbourne
Joined Nov 2006
You obviously don't know much at all about CNC machinery if you don't know how SIMPLE a click of a value(s) can offset drilling in all angles and/or positions.
Then there is the possible mounting/aligning of bits etc, that can be done amiss. But if they do that then EVERY piece of the run will be altered... and that is why EVERY one of my adaptors has an offset alignment - whether they did it on purpose or not. It is also why they are all the exact same angled offset.... because the machine rotates the piece perfectly 90deg and then the exact same drill/tap occurs again. In that same 'rotational offset' direction. And seeing mine were bought over a many many months period, it is not likely it was all the same run they all came from. It is actually no issue at all even if they are offset, as long as it is minor, and an offset will actually work a fraction better than dead straight (at worst equal use) because of the way grub screws are designed/finished. Plus the fact the machinery will do all four of them dead equal offset in that 'rotational direction' anyway. |
Hi all
I spent some time reading (some of) the posts in this and other threads about the CS10. I've flown some EDFs, but the most I meddled with them was to upgrade a motor on a cheap 64mm fan (which worked great for such a small change!). I'm in love with the sound of this CS10 fan and I'd like to start a new project, probably a 70mm T-45 from HK (Heard you can stuff this in the 64mm version from HK too). Suggestions for a somewhat cheap 1st project plane are more than welcome too. I have 3 nanotechs 4S 2200mAH 35C that if possible I'd like to use, even if it's for a 3min flight tops. So because of that and my lack of experience, maybe I should start at the low end, low amp setups, so I can try to use the lipos I have. From the test thread I got this: Quote:
I'm more interested in the sound than in top performance/speed. Will these low amp setups give me the woossh I'm after? Should I just forget the lipos I already have and go for a 5S setup? Or stay at 4S and get bigger lipos and the 2800kV turnigy motor? Any other suggested realiable setups besides the turnigy 2100 to 2800kV for a first project using stuff from HK? (I live in spain, so stores in europe would be good too). I read about so many different setups here that it's easy to get carried away.... specially without the experience. Sorry about the long post and the inumerous questions... (actually this is my 1st post here at rcgroups). It's just so hard to make up my mind... I'd really appreciate any thoughts and suggestions. Thanks a lot ** this is my calculation: 2.2Ah*0.8*60min/h / 43A=2.5min |
Joined Nov 2006
You can ALMOST work out the power by the V and A listed... but those sets of numbers only list Vm which means volts minimum seen. I would guesstimate the volts to use are a bit higher... so make up something a bit higher. LOL.
Multiply out the VxA and the second set are wrong. That V and A look correct, but the Watts should be 500W or so area. Not 800W area. Note it is Wp listed which means the PEAK ever seen on that run.... but 800+ would still be asking a bit much, or would last only for the very initial 1.0 secs!! LOL Both would not give 1.3Kg thrust.... the top could. The lower set would prob be 1.0Kg area, or a bit under. I would not use the 2100kv, unless it is a LIGHT plane! Your maths look fine, so 2.5mins at WOT...... maybe 3.0mins with care. |
The 2855-2300 and the 2800-2100 tests were misquoted in the early posts and Anlucas has written a post showing the correct numbers.
Here is another post that shows a test of the 2100 is as posted here: http://www.rcgroups.com/forums/showp...5&postcount=10 My 2300s run pretty much as tested by Anlucas. Cheers, Eric B. Quote:
Latest blog entry: T/A 37 Tweet/Dragonfly
LOL no I know nothing about machining
I close my eyes when I am milling or turning, seems to come out better that way Fact is I am involved in CNC machining with all my housings and other parts, and to me the CS adapters often look like they were hand machined, but reality is they are running the machines too fast. The 3mm spinner hole is a perfect example of CNC being run too fast, 50% of them were off centre, now my guess is the machine is not off centre, just the speed at which it runs causes the bit to go off centre most of the time. If I slam the tailstock in too quickly on my own lathe I can get an off centre hole. Same with the cheap alloy housings, look at the cut marks and finish and dimensions and its obvious the machines are being run fast in order to make as much product per hour as possible. Go look at the finish on one of my housings and the differences are very apparent. We run the machines much slower especially for the finishing passes, part cost is directly related to time used to make it.
Greece, Attica, Athens
Joined May 2011
thanks for clearing that up.! Washus, the 4S figures were wrongly posted by me. Here are the latest correct ones I got on record. 14.4Vm 33.32Ap 330Wp 1.1 Kg |
Watts are not really that important unless you know all the parameters, he is running one of my Alloy 4 cell combos with a 2W25, it runs at 850-900w on average and produces 1.46-1.55kg thrust, this of course will always vary depending on the battery used, he is using a big high quality 45c pack, not an HK pack so his power levels will be at the upper end of the scale. Your single 2200 packs are not enough for this sort of setup, but two of them together would be more than enough. He has video of it but its only onboard vid, let me look for it....
Ok here it is:
You are clear and concise in your testing. I appreciate your work as you give good feedback on what you are trying to do. I have been told in the past, you cannot lead if there are no followers... ![]() Cheers, Eric B. |
| Thread Tools | |
| New Product Change Sun 12 blade 90mm | Flip Flop | Electric Ducted Fan Jet Talk | 6509 | Today 07:39 PM |
| New Product Change Sun 120mm and new 10 blade 70mm fans | Flip Flop | Electric Ducted Fan Jet Talk | 131 | Apr 27, 2012 07:07 PM |
| Sold Change Sun electric retracts | Flip Flop | Aircraft - Electric - Jets (FS/W) | 3 | May 23, 2011 06:20 AM |
| Sold Change Sun Electronic retracts w/Lander struts | hole digger | Aircraft - Electric - Jets (FS/W) | 2 | May 06, 2011 01:27 PM |
| Sold Change Sun Electric retracts NIB 75.00 | jzuniga | Aircraft - Electric - Jets (FS/W) | 2 | Sep 03, 2010 09:36 AM |
