Old Sep 17, 2012, 07:37 AM
Tartago is offline
Find More Posts by Tartago
Back to EDF
Tartago's Avatar
Joined Apr 2006
Today I flew my old and trusty F-4j with the CS10 and the LX 2855 2100kv on 5s 40c.
The ESC was a HK 90A.
All went ok. very fast and a bit noisy.
Tartago is offline Find More Posts by Tartago
Old Sep 17, 2012, 07:38 AM
Tartago is offline
Back to EDF
Tartago's Avatar
Joined Apr 2006
Originally Posted by erh7771 View Post
What were your packs c ratings?
Thx in advance for any input
Also, I don't think I got more than 60 amps on the 2300kv motor on 5s....anyone else get more amps than that?
If it's a negative for others check your esc
40c and a 75A HET ESC.
Old Sep 17, 2012, 02:06 PM
anlucas is online now
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
Originally Posted by disho View Post
Heres a video of my hk t45 with a cheat hole cut out, it has a different sound now
Sounds great! A small hole at the right place does wonders!!!
Is that the 64mm T-45? or is it the 70mm?
anlucas is online now Find More Posts by anlucas
Old Sep 18, 2012, 12:05 PM
mcgoughman is offline
Find More Posts by mcgoughman
Mil-Spec
mcgoughman's Avatar
United States, CA, Los Alamitos
Joined Mar 2008
4s setup?
I'm sure it's in here somewhere.... Can anyone recommend a motor for a 4s setup? Thanks
mcgoughman is offline Find More Posts by mcgoughman
Old Sep 18, 2012, 12:09 PM
mopetista is offline
Find More Posts by mopetista
Vienna, Austria
Joined Apr 2007
CS 70 test data thread
http://www.rcgroups.com/forums/showthread.php?t=1601868
mopetista is offline Find More Posts by mopetista
Old Sep 18, 2012, 04:05 PM
RGS2010 is online now
Find More Posts by RGS2010
Always Fly 2 Mistakes High!
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
My 4S Setup
This motor:
http://www.pw-rc.com/product_info.ph...oducts_id/2028
This ESC:
http://hobbyking.com/hobbyking/store...dproduct=18013
This UBEC:
http://hobbyking.com/hobbyking/store...dproduct=16663
This Battery:
http://hobbyking.com/hobbyking/store...dproduct=18640
I have this setup in a Venom F-86 Sabre jet and it lasts 3.5 minutes with maybe one go around at most. The battery comes down warm to the touch, not hot. The ESC is cool to the touch. It outputs 900 to 1000 watts of power easily. It bursts to 1500 watts on startup.
I am going to go to a Nano-Tech 4S-35C-4500 to try to get 4 minutes next.
Russ
RGS2010 is online now Find More Posts by RGS2010
Old Sep 18, 2012, 07:29 PM
Tartago is offline
Back to EDF
Tartago's Avatar
Joined Apr 2006
RGS, I tried that motor and it's not as silent as expected. How's the sound in yours?
Old Sep 18, 2012, 10:20 PM
Goody63 is online now
Find More Posts by Goody63
How close are those trees?
Goody63's Avatar
Perth, Western Australia
Joined Apr 2008
Originally Posted by RGS2010 View Post
This motor:
This ESC:
This UBEC:
This Battery:
Russ
Got that same Motor/fan combo in my FW F-16, (see 2nd part of below video).
Certainly does put out some power but at high amps (around 85amps peak from memory) which can be pretty hard on the lipos.
Also I find those CP motors aren't very well balanced and need dynamically balancing if you want to get the setup really smooth.
Still, not bad for the bucks but a HET or similar will be alot better IMO (balance and efficiency).
Changesun 70MM EDF 10 Blade Powered J-11B and F-16 (3 min 31 sec)
Goody63 is online now Find More Posts by Goody63
Old Sep 19, 2012, 08:38 AM
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
Not silent at all really. I was a bit disappointed in that aspect. But I was pleased with the power and speed.
Nice flight Goody
Old Sep 19, 2012, 10:11 AM
Tartago is offline
Back to EDF
Tartago's Avatar
Joined Apr 2006
I'm still chasing the whooosssshh without burning my wallet...
Old Sep 19, 2012, 09:55 PM
Goody63's Avatar
Joined Apr 2008
Nice flight Goody
I think those CP motors aren't as balanced as the advertising makes them out to be.
I ended up adding quite abit of weight to mine and it still wasn't perfect.
That's what I love about HET inrunners. You mount them (without the rotor) in the dynamic balancer and they barely register.
Makes a great starting point for getting a nice smooth (and quiet) EDF.
Cheers for the flight comment! too
Old Sep 20, 2012, 12:57 AM
anlucas's Avatar
Joined May 2011
+1 on that Dave.
Even the Turnigy L2855s are better.
Old Sep 20, 2012, 07:46 PM
disho is offline
Find More Posts by disho
disho's Avatar
United Kingdom, England, Durham
Joined Apr 2011
its the 64m hk t45
disho is offline Find More Posts by disho
Old Sep 21, 2012, 01:32 AM
anlucas's Avatar
Joined May 2011
its the 64m hk t45
Thanks!
Old Sep 22, 2012, 11:01 PM
nighthawk0077 is offline
Find More Posts by nighthawk0077
Canada, ON, Vaughan
Joined Oct 2009
For best thrust, what timing are you guys using on the L2855 2100kv? Medium or high? Also 8 or 16khz?
nighthawk0077 is offline Find More Posts by nighthawk0077
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7194 Dec 14, 2015 04:03 PM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 08:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 07:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 02:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 10:36 AM
