Old Sep 10, 2012, 07:52 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
Originally Posted by M3ATpl0w View Post
I know sarcasm is easy to miss on forums...
This has been an awesome thread for me. Been flying a while, and love jets, but hated the shrill noise made by the old edfs. This fan is the reason I now have a jet. I have followed since day 1, and I am constantly amazed by the knowledge and cleverness a lot of you guys have. And your willingness to share is awesome in my eyes.
Sorry, wasnt directed at you.
The 6 I have work fine with cheap motors where I dont worry about high power. I have a Velocity T45 that I want to put a 5s version in for the same reasons you like the CS70...
I might have to get the parts from Tamjets to get this one going.
Eric B.
AirX is offline Find More Posts by AirX
Old Sep 10, 2012, 07:58 PM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
rfodor.... you said "flys for about 4 minutes (mostly at 1/2 throttle)"....
There is your answer.
"Jet sound" comes from white noise... which comes from airflow 'difficulty'. Passing over odd surfaces, angles, edges, being restricted etc.
So to have that occur it needs 'airflow'. So imagine you BLOW air down the ducting yourself... that will be a pretty weak amount and speed!! LOL NO white noise.... (very minor, if any).
This is what your "1/2 throttle" does.....
The more RPM/thrust... the higher the airflow... the more white noise, due to the "duress" that higher airflow has then.
If you have little white noise, "jet" sound.... you have airflow that is too 'clean'. A Habu has a very 'clean' ducting system. The only way to get white noise from that situation is to have a LOT of airflow that "over-drives" its 'cleaness".
You have to choose between performance optimals, and sound optimals.
You also mentioned the take-off 38k RPM, and good sound...... again there is your answer.
More airflow duress... thus more white noise then.
So to get the sound, just as the plane is... fly WOT all the time! LOL
PeterVRC is offline Find More Posts by PeterVRC
Old Sep 11, 2012, 08:41 AM
RGS2010 is offline
Find More Posts by RGS2010
Always Fly 2 Mistakes High!
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
Off topic..sort of
Did you guys see this bad boy?
http://hobbyking.com/hobbyking/store...dproduct=27559
Looks sweet...anyone try it yet?
RGS2010 is offline Find More Posts by RGS2010
Old Sep 11, 2012, 05:21 PM
rfodor is offline
Find More Posts by rfodor
United States, GA, Alpharetta
Joined Feb 2009
I do understand all of that and a 2800KV motor turning the same fan is equivalent to NEU 3500KV at 1/2 throttle...... so what is the difference? My point is that the NEU 1112/1Y gives me a lot of head room to do the high speed/high thrust that you can't do with a 2800KV motor on 4S.
I heard in the background a newbie ask if that is a real jet on my last takeoff...... think about that, I could hear him ask and he was quite a ways from me with a EDF on takeoff power. No EDF is ever going to sound like a turbine (in loudness) unless we can waste a lot of power making noise.
rfodor is offline Find More Posts by rfodor
Old Sep 11, 2012, 05:50 PM
PeterVRC is offline
Joined Nov 2006
rfodor... you said "it sounds like a turbine but very quiet". That is what I commented on.
It is quiet because you don't have enough restrictive/complex airflow.
Nothing to do with what motor..... just what the ariflow is doing.
I have a few CS10's that sound "loud" even from a longish range.... if there is enough white noise, you will hear it from quite a long way. I guess it depends on what you call a 'long' way, because of you fly 500m circuits, displaced away from you, of course notably further away dimishes sound.
And one of those is a Meteor, which is a Habu clone, and it too is loud enough to hear from quite a long way away - and the white noise of it still. (White noise travels well... seeing it has so many freqs in it, they can't all blend away into the ambient sound)
Old Sep 14, 2012, 01:31 AM
xfatdannx is offline
Find More Posts by xfatdannx
advanced n00b
xfatdannx's Avatar
United States, NE, Omaha
Joined Feb 2012
what would you guys suggest for an alloy shroud for this impeller? looking at getting a 2w30 for the motor, currently have a Turnigy L2855 2100kv but i don't think it will last long.
xfatdannx is offline Find More Posts by xfatdannx
Old Sep 14, 2012, 01:41 AM
clive45 is offline
Find More Posts by clive45
It should fly at least once
clive45's Avatar
Australia, NSW, Grenfell
Joined Mar 2006
Have a look here http://www.extremerc.com.au/estore/i...24257337cc3ae5
clive45 is offline Find More Posts by clive45
Old Sep 14, 2012, 01:55 AM
advanced n00b
xfatdannx's Avatar
Joined Feb 2012
i've been overlooking this site for a few days was just curious if there was any other comparable
wish they would tell you which HET motor comes with the combos too.
Old Sep 14, 2012, 02:13 AM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
try Gary at Efluxrc.com I think he carry's some 70mm skyworld alloy housing and then get a bl32 motor from eflight to go with your cs70/10 rotor....its an awesome setup for 6s!
jcdfrd is offline Find More Posts by jcdfrd
Old Sep 14, 2012, 02:42 AM
anlucas is offline
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
Some time ago it did say somewhere there. I believe it's a 2w30 for the 6S and 2w25 for the 4S.
I got a fan only and paired it with my motor and it's excellent!.
anlucas is offline Find More Posts by anlucas
Old Sep 14, 2012, 03:04 AM
advanced n00b
xfatdannx's Avatar
Joined Feb 2012
I already have a whole cs unit with a L2855 2100kv but i have not installed or bench tested it. There is an 2w-30 in the classifieds i was considering.
Old Sep 14, 2012, 03:44 AM
anlucas is offline
anlucas's Avatar
Joined May 2011
I meant, an ExtremeAlloy 70mm 10blade
I also have several standard CS10 fans.
Old Sep 14, 2012, 10:32 AM
mopetista is online now
Find More Posts by mopetista
Vienna, Austria
Joined Apr 2007
CS70 on the FMS Alpha Jet anyone?
The rather big FMS Alpha Jet 70mm is on sale at HK, so I am wondering if
someone has already tried the CS70 in this airframe, I like the looks and the
price, but not the sound of the stock fan...
cheers
Clemens
mopetista is online now Find More Posts by mopetista
Old Sep 14, 2012, 11:27 AM
nighthawk0077 is offline
Find More Posts by nighthawk0077
Canada, ON, Vaughan
Joined Oct 2009
Well I've been running the 2W-30 in a CS10 for a few months now. Awesome motor, tons of power (you can look back a few pages for a video).
I also just assembled an L2855 2100kv for a HET F20 which I am building. Did a quick run-up so far. Sounds pretty quiet already without any balancing. Got 1200+ watts on 5S, but I am planning to run both 5 and 6S.
Anyone have some long-term experience with this motor?
nighthawk0077 is offline Find More Posts by nighthawk0077
Old Sep 14, 2012, 12:42 PM
anlucas is offline
anlucas's Avatar
Joined May 2011
To get 1200w+ on 5S means that you are running high timing. On 6S the temps get really high and it won't last very long.
I 've been running one on and off since March. Pretty good on low timing. A touch better than the 2300kv on 5S. Still gets hot so need to manage throttle. In general, it needs to be kept under 65Amps, preferable 60 or less.
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7243 Jul 18, 2016 07:09 PM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
