Old Sep 03, 2012, 10:56 PM
nighthawk0077 is offline
Find More Posts by nighthawk0077
Canada, ON, Vaughan
Joined Oct 2009
Originally Posted by scunna View Post
Good job, yeah for some reason those Hobbyking T45s sound fantastic. I had one last year with a generic 5-blade unit that sounded much better than it was supposed to. Only problem is the plane is just too tame and easy to fly
nighthawk0077 is offline Find More Posts by nighthawk0077
Old Sep 04, 2012, 01:45 AM
scunna is offline
Find More Posts by scunna
scunna
scunna's Avatar
United Kingdom, England, South Shields
Joined May 2007
pulls 60 on 5s 80 on 6s
scunna is offline Find More Posts by scunna
Old Sep 04, 2012, 03:46 PM
tracknoob is offline
Find More Posts by tracknoob
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Yup, HK T-45 = perfect EDF trainer. Very docile. So, I know it's not too much of a challenge once you get going, but something about it's shape and color scheme that makes me still love seeing it in the air.
tracknoob is offline Find More Posts by tracknoob
Old Sep 04, 2012, 04:14 PM
DerekB is offline
Find More Posts by DerekB
DerekB's Avatar
Cape Coral, FL
Joined Nov 2001
I also have the HK BAE Hawk 70mm sitting in a box for about 2 months now. Is that the same one you have?
Time to dust mine off and build it , with a CS10 fan of course. Do you have any photos of the "carving" of the fuselage to fit the fan?
Regarding all up weight, the "standard" configuration (which we know is lame) uses 1600 3S LiPo. So a 3000 6S is probably max'ed out on weight. It looks by your casual hand launch that it handles the weight just fine.
Exactly which 6S 3000 packs are you running and what C rating?
At 80 amps continuous, I presume you want a pack that can deliver 100 amps. So a 35C rating should be enough.
I have the HK L2850 2100 kv motor still in the box, so I don't know if it draws 80 amps like the BL32.
Derek
DerekB is offline Find More Posts by DerekB
Old Sep 04, 2012, 05:02 PM
clive45 is offline
Find More Posts by clive45
It should fly at least once
clive45's Avatar
Australia, NSW, Grenfell
Joined Mar 2006
Just remember that this is a draggy airframe and excess power is wasted on it, sure it needs more than standard but don't go overboard.
Its like a Ferrari you don't need to drive it fast , it looks the goods.
clive45 is offline Find More Posts by clive45
Old Sep 04, 2012, 05:09 PM
M3ATpl0w is offline
Find More Posts by M3ATpl0w
Progress with the process...
M3ATpl0w's Avatar
NE Alabama
Joined Feb 2011
Is the Hawk in the video the 64mm or the 70mm version?
If it were the 70mm flavor, why would he need to gut it for the fan?
It Does sound fantastic.
M3ATpl0w is offline Find More Posts by M3ATpl0w
Old Sep 04, 2012, 07:25 PM
ysolomon is offline
Find More Posts by ysolomon
Another one on the way...
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
Originally Posted by Knife Liddle View Post
That`s right, STUPID fast, stupid powerful, probably just plain stupid too, but we`ll see how it holds up.
It`s powered by a Turnigy 3126 that has been rewound to 2.5 turns for aprox 2900kv (need to measure it). I added a 4" long shaft and an extra front bearing to support the longer shaft. The motor has an OD of about 37mm so it`s in the standoff position. I`m using a collet style adapter, but I`ll have to check to see which one it is. No mods to the shroud except what was needed to fit the standoff block. The rotor is bare bones stock.
Note: This is competely insane to run this $15 fan like this. Don`t do it, don`t even think about doing it. (That way I can be the only guy who has one).
Just the Facts.............
6s, 22v ( ran a 6s2p10ah battery to hold voltage)
145a......sustained
3.2 kw....""
97oz thrust.....6lbs 1oz
261 mph efflux speed (measured with Eagletree V3)
Esc used is a Suppo 7s 200a (the type with adjustable timming (30 degrees) and pwm 16k)
I`ll post some pics later. I may have found the powerplant for my Squal.
Cost about $80 for motor/wire/fan/esc. Then add lipos.
Lee,
What is your impression of that Suppo 200A ESC?
Yoram.
ysolomon is offline Find More Posts by ysolomon
Old Sep 04, 2012, 07:46 PM
PeterVRC is online now
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
Derek, it looks like it is the 'other' T-45 that HobbyKing also have. But that doesn't matter.... your one would work totally fine anyway!
The T-45 is just a fantastic model aircraft subject and all forms of it fly fantastically.
And a Tracknoob mentioned, there is just something about its shape (lines) and colours, that make it highly attractive - more so in the air!! Like a Ferrari !!
The L2855-2100 is certainly no BL32!!! lol
It will run very well on 5S - in any aircraft of this size range - but it will dislike 6S!! And pretty certainly will fry in a short time frame. But for its cost, and result, it is perfect for 5S.... though the 2300kv version is even better.
If you do want to run 6S, go for the CyclonePower (I think they have something 2100kv area), or otherwise a HET (2w30) 2200kv.
On 5S.... L2855-2300, or 2100kv for just 'good' power..... or for big power, CyclonePower 2550kv - and not sure which exact HET.
Seeing you have the L2855-2100v..... just do that on 5S and I am sure it will be a great flyer!
And if you feel you need, or want, more power/speed..... plan for the HET2W30 6s path one day - a very easy thing to change to then.
I have too many aircraft already now... but this 70mm T-45 has been a high desire target for ages now! Just luckily HK Aust doesn't have stock, and haven't in a long long time!!
I would almost intentionally smash/destroy (from flight!!) one other aircraft to have room for this!! (Either an F-15 or F-18 in 70mm's that I have). LOL
Hmmm, a "Dogfight to the death" would be a good way to do that...... good idea!
PeterVRC is online now Find More Posts by PeterVRC
Old Sep 04, 2012, 10:52 PM
DerekB is offline
DerekB's Avatar
Cape Coral, FL
Joined Nov 2001
I kinda have a unique situation, so I should back-track a little and explain my goals for this BAE Hawk and maybe this will help home in on a motor / battery combo. I'm open to buy anything, but I happen to actually have all 3 kv ratings of the BL2855 - the 2100, 2300 and 2800. But I don't experiment much with them. I definitely only want to use the stock CS10 plastic shroud.
My goals: I have a very small tight field I want to fly this Hawk (where I fly my little 3D foamies) so I want it to fly light and slow, but still do a loop. So I need:
1) Slower speed with good thrust is key. Hand launch, no landing gear.
2) Lightest weight possible and good thrust at lower speeds.
3) Short flight time is OK, say 2.5 to 3 minutes.
Kinda just the opposite of what most people are trying to do. I am open to any cell count / combo with any of the L2855's. Or any other motor. Actually the L2855's are probably kinda heavy with the big heat sink cone.
This Hawk is one of the lighter airframes I have seen for it's size:
Fuselage 221 grams
Wing 110 grams
Stab + Rudder 20 grams
Nose cone 5 grams
Misc hardware 11 grams
TOTAL AIRFRAME 367 grams (12.93 ounces)
Then add servos, Rx, ESC, fan, motor, battery. I think sub 2 lbs is possible.
Derek
Old Sep 04, 2012, 11:00 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
4s on the 2800kv is your only choice based on your goal set
jcdfrd is offline Find More Posts by jcdfrd
Old Sep 04, 2012, 11:01 PM
Joined Nov 2006
1) The L2855 tail cone is a very thin and light item.
Old Sep 04, 2012, 11:05 PM
Knife Liddle is online now
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
Originally Posted by ysolomon View Post
Lee,
Yoram.
Great for the money. The type that has adjustable timing and pwm is worth the extra money. They cost in the $40 range.
Knife Liddle is online now Find More Posts by Knife Liddle
Old Sep 04, 2012, 11:10 PM
DerekB is offline
DerekB's Avatar
Cape Coral, FL
Joined Nov 2001
HK BAE Hawk - is it really a 70mm duct?
I don't know the history of this particular model, but maybe it started as a 64mm fan and then they "converted" the mold to fit a 70mm by simply enlarging the recess for the fan, but left the duct the same size. The inside diameter of foam is only 65mm, but the recess is fits a 70mm fan. What a joke, or should I say Choke!
No wonder scunna (or is it his buddy's plane ??) had to hollow out the interior.
Looks like I will be doing the same. Time to get out the big sharp knife .
Old Sep 04, 2012, 11:12 PM
anlucas is online now
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
Derek,
had the HK BAE Hawk 70mm airframe. Because of battery placement issues, I think that you will not be able to go 5 or 6S. So, stick to either the 2300kv or 2800kv L2855. The 2300kv will fly it fine on 4S but I don't know how easy the hand launches will be. If you have smallish(<350gr) 5S packs you should be OK though. Otherwise, the 2800kv on 4S is the safe.
anlucas is online now Find More Posts by anlucas
Old Sep 04, 2012, 11:27 PM
DerekB is offline
DerekB's Avatar
Cape Coral, FL
Joined Nov 2001
Originally Posted by anlucas View Post
Derek,
Hey guys, sorry I have not been on the ducted fan threads much lately - I got distracted with a multi-rotor project . It's like learning a foreign language.
For the Hawk, I'll go with the 2800 kv on 4S. My Gens Ace 4S 2500 weighs 297 grams.
I like that answer - I don't have to buy anything .
Derek
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7243 Jul 18, 2016 07:09 PM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
