Old Aug 28, 2012, 01:54 PM
RGS2010 is offline
Find More Posts by RGS2010
Always Fly 2 Mistakes High!
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
Thanks for the input. I plan on running at an avg of 92 amps so I think I'm good with the EC5's. I just got a package (my first one) and man, they are huge connectors. I like 'em already. Will be much easier to solder in the UBEC with these.
RGS2010 is offline Find More Posts by RGS2010
Old Aug 28, 2012, 02:08 PM
v8truckin is offline
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
Another reason why I love em, easy to solder and with 6s lipo wires u need that extra room for your separate bec.
v8truckin is offline Find More Posts by v8truckin
Old Aug 28, 2012, 02:37 PM
anlucas is online now
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
Originally Posted by Ispintechno View Post
Popped in a hobby king 2800kv motor from my F-4 into a vanilla CS10 last night. Going to bench test it in the next few days using plush 60amp esc (with 80 amp burst) on medium and high timing off 4S 30C. I'll report the numbers if nobody has tried this set-up.
That looks like the 2839 Hercules (freewing) motor. It's really a 3000kv motor.
Expect to see more than 70amps. Try on Low timing first.
I 've got this setup but haven't installed it in a plane yet.
anlucas is online now Find More Posts by anlucas
Old Aug 28, 2012, 10:57 PM
Ispintechno is offline
Find More Posts by Ispintechno
Defender of the park sky
Ispintechno's Avatar
London, ON Canada
Joined Nov 2009
I think you are right on the money there, I bought it over a year ago as the HK2839 rated at 2800kv but several comments on the HK website suggest this motor is really 3000kv. It propelled my FMS F-4 to a pretty good top speed with a 6 blade HK rotor. I'd say on par with the Habu anyway.
Thanks for the heads up, first run up will be on low timing.
Ispintechno is offline Find More Posts by Ispintechno
Old Aug 29, 2012, 02:45 AM
alanjets is offline
Find More Posts by alanjets
alanjets's Avatar
Ripoff britain
Joined Jan 2011
I have a 2w 20 motor and when i run it up it gets hot should it do that i havnt put any load on it at the min
alanjets is offline Find More Posts by alanjets
Old Aug 29, 2012, 06:22 AM
PeterVRC is online now
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
You ran it just as it came?
You should not do that. Certainly not to full RPM. And also not to run very long at all that way - somewhat OK up to some lowish speed.
PeterVRC is online now Find More Posts by PeterVRC
Old Aug 29, 2012, 07:59 AM
alanjets is offline
alanjets's Avatar
Ripoff britain
Joined Jan 2011
no it was at low speed just got warm just wandering if this was normal
Old Aug 29, 2012, 09:57 AM
scunna is offline
Find More Posts by scunna
scunna
scunna's Avatar
United Kingdom, England, South Shields
Joined May 2007
bought 5x 5mm shaft adapter from mark at extreme rc for 70mm cs10 fans and using bl32 motors from e-flite i am getting some good results. on 5s it pulls 1200 watts on 6s it pulls 1800 watts all fans so far have not needed balancing. My mate put one in his small t-45 sound's awesome
hk t-45 64mm edf fitted with changesun 10 blade fan bl32 motor on 6s 3300 (3 min 34 sec)
scunna is offline Find More Posts by scunna
Old Aug 29, 2012, 10:24 AM
sikky is offline
Find More Posts by sikky
speedin n da weeds :)
sikky's Avatar
USA, AZ, Glendale
Joined Feb 2008
anyone know if the blades are like the haoye 7 blade rotors??
sikky is offline Find More Posts by sikky
Old Aug 29, 2012, 10:31 AM
anlucas's Avatar
Joined May 2011
Don't know which aspect of the 7bladers you refer to but these seem to be a different concept.
Old Aug 29, 2012, 02:28 PM
sikky is offline
sikky's Avatar
USA, AZ, Glendale
Joined Feb 2008
blade twist /pitch, about the same just another blade added??
Old Aug 29, 2012, 05:49 PM
anlucas's Avatar
Joined May 2011
Not in that respect. Similar to other multiblade 90mm fans but cut down.
Old Aug 29, 2012, 06:02 PM
St. Martin is offline
Find More Posts by St. Martin
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
http://www.youtube.com/watch?v=szqOefK78eY&feature=plcp
Thats good to know. I have the same set-up, with the Efflux alloy shroud and Tams adapter/spinner washer assembly. I knew his was doing 80A@ 1800W on 6s, But I was estimating 1100-1200W on 5s. How was your amp draw on 5s, around 55A?
I flew an RBC Panther with a Minifan for 3yrs @ 1200W and 4.2#. Great flyer. I need another only with the above CS10 combo on 5s.
Fuzz
St. Martin is offline Find More Posts by St. Martin
Old Aug 29, 2012, 10:01 PM
London, ON Canada
Joined Nov 2009
I tried it on the bench today. My transmitter battery for the timing card however was dead so I decided to run it up on high timing anyway... lol
First run up had the power meter on AMPs, got up to 45.4 amps. Not very alarming, so I switched it over to watts and ran it up again. Got up to about 671watts. Then watched the watts slowly drop to 660, 650, 640... everything went dead. Motor was really hot, ESC was still pretty cool. unpluugged everything, let the motor cool, plugged it in again, no dice, no beeps from esc nothing.
Either killed the motor or the ESC. Thank gawd it was on the bench and not in the plane. In hindsight low timing might have saved it but I don't think this is the right motor for this fan. Motor was damn loud too. Didn't sound very good.
Old Aug 29, 2012, 10:04 PM
T-BONEZ is offline
Find More Posts by T-BONEZ
Joined Jun 2007
I bought the fans from hk/hc... The molding of the blades and duct seems very rough, is it normal? There a lot of jaggered edges and stuff... Do I sand them down?
T-BONEZ is offline Find More Posts by T-BONEZ
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7224 Apr 21, 2016 02:53 AM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
