Old Aug 20, 2012, 08:55 AM
Always Fly 2 Mistakes High!
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
My 10 blade should be here today...what is the consensus, put on the "nose cone" or leave it off because it is unbalanced?
Thx,
Russ
RGS2010 is offline Find More Posts by RGS2010
Old Aug 20, 2012, 09:12 AM
Not enough hours in the day
Slaanesh's Avatar
Melbourne
Joined Feb 2009
Check Schubeler fans especially their HDT High Dynamic Thrust range. Low blade count, light weight carbon rotors.
Slaanesh is offline Find More Posts by Slaanesh
Old Aug 20, 2012, 09:27 AM
Greece, Attica, Athens
Joined May 2011
Thx,
Russ
Try it on rotating at various positions and if necessary add weight inside. I Use the cone to dynamically balance the whole system.
anlucas is online now Find More Posts by anlucas
Old Aug 20, 2012, 10:08 AM
Joined Nov 2005
I've been looking for these fans and haven't found one place that sells them...
I understand they sell without the motor
erh7771 is online now Find More Posts by erh7771
Old Aug 20, 2012, 10:34 AM
Gorilla Glue Expert
PikeStaff's Avatar
United States, PA, Doylestown
Joined Sep 2010
http://shop.rc-electric-jets.com/Sch...30-DIA-HDT.htm
PikeStaff is offline Find More Posts by PikeStaff
Old Aug 20, 2012, 03:44 PM
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
Thx,
Russ
Both my CS10's balanced very well. First static balance the rotor on a good magnetic balancer. Then I placed a 1/8" sq piece of tape(unded up with paper masking tape), on the inside of the spinner near the flange. Rotate the spinner in 1/4 turn increments. I had to re-position the tape once. One fan uses the Tams adapter(5mm), washer spinner, Efflux alloy shroud. This one is smoother. Possibly because of the 5mm shaft on the BL32. But I still used the tape sq under the alum spinner.
Fuzz
St. Martin is offline Find More Posts by St. Martin
Old Aug 20, 2012, 05:34 PM
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Joined Mar 2006
Originally Posted by rfodor View Post
I bent the shaft on my 4mm 2858-1 and thought oh well I'll just replace it. When I opened up the motor and pulled the rotor I found a solid piece of machined steel with the magnets glued on (I asume) and wrapped with fiber glass.
I will have to look at an old rotor again, never took much notice of the carrier. They are wrapped in kevlar supposedly, and then coated in some sort of silicon, if you nick this in any way it unravels and siezes the motor, very difficult motors to work on.
Extreme_RC is offline Find More Posts by Extreme_RC
Old Aug 20, 2012, 05:53 PM
Perpetually covered in resin
RawmadeCF's Avatar
United States, NV, Las Vegas
Joined Dec 2011
Yeah it's kevlar. Easily mistaken for fiberglass. These motors are why I hate buying inrunners =)
RawmadeCF is offline Find More Posts by RawmadeCF
Old Aug 20, 2012, 06:47 PM
Atlanta, GA
Joined Feb 2009
Mine started to unravel but I put some very thin CA on it and it sealed right up. It doesn't look like kevlar, but it may be. I trimed the loose hairs with surgical sissors and then thin CAed it. Seems to be working fine.
What I'm not sure about is how the rear bearing carrier stays in place. On the ARC motors it is a press fit. I tapped it back in place but I am concerned about it staying there. On the bench it seems OK.
rfodor is online now Find More Posts by rfodor
Old Aug 20, 2012, 06:53 PM
Atlanta, GA
Joined Feb 2009
P. S. This is why this forum is so valuable...... here we are, half way around the world from each other and sharing valuable info on a $90.00 motor. Awesome.
Old Aug 20, 2012, 07:09 PM
Extreme_RC's Avatar
Joined Mar 2006
The end caps should be glued on, not sure what they use but I have used a quality CA before and been ok, just clean out the old gunk and sand the edges where it joins. There is a locktite glue available that supposedly works very well in this situation, black colour? Not sure on what it is.
Old Aug 20, 2012, 07:38 PM
Gorilla Glue Expert
PikeStaff's Avatar
Joined Sep 2010
LockTite Stud and Bearing Mount, green in color.
Old Aug 20, 2012, 09:14 PM
Atlanta, GA
Joined Feb 2009
Thanks guys, I appreciate the guidance.
Old Aug 20, 2012, 09:40 PM
Extreme_RC's Avatar
Joined Mar 2006
I have the green locktite retaining compound for installing bearings etc, but didnt think it was strong enough for this sort of application. There is a black locktite product guys are using to glue magnets into bells and cases together, but no idea what its called.
Old Aug 20, 2012, 09:49 PM
Atlanta, GA
Joined Feb 2009
I found this on google, Locktite Black Max CA. Shear Strength 3770 PSI, Tensile Strength 2700 PSI.
Loctite® 380™ Black Max Low viscosity, black, rubber toughened, one part, room temperature cure, instant adhesive designed for bonding metal, rubber and selected plastics. Excellent peel, impact and sheer strength.
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 6509 Yesterday 07:39 PM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
