Old Aug 13, 2012, 06:03 PM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
New housing batch has been finished and is being packed right now, will start shipping out in the next day or so. Plenty of 70mm, 90mm, and I adjusted the design on the 64mm housing, now 65mm ID with straight inlet and some small changes to make it easier to install, the outside diameter is close to most plastic 64mm fans we just gain a mm in rotor size.
Extreme_RC is offline Find More Posts by Extreme_RC
Old Aug 16, 2012, 10:20 AM
T-BONEZ is offline
Find More Posts by T-BONEZ
Joined Jun 2007
hello all,
jut askingn is 4s + l2855-2300kv+ cs 70mm 10 blade a good combo?
I'm not looking for any extreme high speed performance , but rather power my f-14 good and easy with 2kg thrust,
T-BONEZ is offline Find More Posts by T-BONEZ
Old Aug 16, 2012, 10:39 AM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
Originally Posted by T-BONEZ View Post
hello all,
Yeap...
Which version of the F14 60mm or 70mm?
Regards
erh7771 is online now Find More Posts by erh7771
Old Aug 16, 2012, 10:42 AM
T-BONEZ is offline
Joined Jun 2007
mine is the old epf/airpower f-14, 70mm non-swing wing...
i;m looking to try and get 1.2kg++ thrust on the bench each before i mount the on... my plan is going to weigh about 1.8-2kg
also, are the hobbyking 70mm 10blade edf changesun orginals? or imitations?
Old Aug 16, 2012, 10:45 AM
Joined Nov 2005
originals...will sound really nice, have the SM f14...sound like small turbine
Old Aug 16, 2012, 10:48 AM
T-BONEZ is offline
Joined Jun 2007
just to ask, will the changesun run fine on my current freewing 70mm 3000kv?
or am i looking at a potential over heat issue?
Old Aug 16, 2012, 11:23 AM
pardus is offline
Find More Posts by pardus
Graham Dyer
pardus's Avatar
Johannesburg, South Africa
Joined Jul 2003
FWIW, I found this paper while doing some research on duct length: http://southamptonmac.org.uk/doc/EDFpart1.pdf.
It may be of some interest to those using these EDF's. It is quite technical (read brain-bending), fairly old (before brushless and LiPo!) but very relevant and has some interesting calculations, advice and conclusions.
pardus is offline Find More Posts by pardus
Old Aug 16, 2012, 11:56 AM
Joined Nov 2005
post pic
Old Aug 16, 2012, 12:09 PM
T-BONEZ is offline
Joined Jun 2007
http://www.tporder.com/list.asp?ProdId=0107
here!
Old Aug 16, 2012, 12:10 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
hello all,
The L2855-2300 works great on 4s, the thrust is ~1.2Kg, the amps run ~40amps and the battery is able to hold voltage quite well so rpms are fairly stable.
The fan is a bit high for most 3000kv motors and there can be overheat problems from the high amp draw (~ +-90amps IIRC).
After looking at your picture I see the motor weight is 85 grams and it will reside in the motor tube so there will be less airflow over it to remove heat. If it had the offset It might last a little while but I think you would still damage that motor in this fan.
Eric B.
AirX is offline Find More Posts by AirX
Old Aug 16, 2012, 12:29 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
Pardus
thats good stuff do you have a link to part 2? if there is a part 2?
jcdfrd is offline Find More Posts by jcdfrd
Old Aug 16, 2012, 12:31 PM
T-BONEZ is offline
Joined Jun 2007
Eric B.
thanks bro, i'll just stick to the free wing 6 bladers till it needs replacing then... cheers!
Old Aug 16, 2012, 12:40 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Originally Posted by jcdfrd View Post
Pardus
KRS Edf 3
http://www.rcgroups.com/forums/showa...mentid=1192118
KRS Edf 1
http://www.rcgroups.com/forums/showa...mentid=1192117
KRS Edf pt2 construction
http://www.rcgroups.com/forums/showa...hmentid=885564
Eric B.
Old Aug 16, 2012, 12:55 PM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
hey thanks Eric
it looks like KRS edf 1 and KRS edf 1-1 are the same document
Old Aug 16, 2012, 12:59 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
hey thanks Eric
Yup your right, i went in and removed it...
Your welcome.
I use a lot of the calculations in my spreadsheets. Klaus is/was the man and I am very greatful to him for taking the time to give us some of his knowlege here on the forum.
Eric B.
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7232 Jun 06, 2016 02:40 AM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
