Old Aug 10, 2012, 10:57 PM
Ming is offline
Find More Posts by Ming
Ming's Avatar
Hong Kong
Joined Jun 2002
Thank you very much for your order, Windrider will ship the CS fan on Monday.
Ming Lou
Ming is offline Find More Posts by Ming
Site Sponsor
Old Aug 11, 2012, 07:46 AM
xfatdannx is offline
Find More Posts by xfatdannx
advanced n00b
xfatdannx's Avatar
United States, NE, Omaha
Joined Feb 2012
Originally Posted by St. Martin View Post
I got the alloy shroud from Garry at Efflux. He's right in CA. 45bux and got it within a week. The fit of the Eflite BL32 motor was not real snug. But I just wrapped one layer of alum duct tape and it was tight. Some conductive paste and I'm good.
Fuzz
have you throw that on a watt meter yet? would really be interested to see your numbers.
Thanks everyone for your suggestions.
xfatdannx is offline Find More Posts by xfatdannx
Old Aug 11, 2012, 07:49 AM
bentech is offline
Find More Posts by bentech
bentech's Avatar
Joined Jun 2006
Originally Posted by PeterVRC View Post
Bentech, I have that F-18. But mine was PNF and came set up for 3S. Too low power and flew like a "perpetually landing jet"... LOL... nose a bit up...
I upgraded it to 4S and whilst it was a fair bit faster, and acceptable then, it was still not 'fast'. The inlet ducting is too narrow.... restrictive. And that would surely bother a CS10, as well as the exhaust side restrictions too.
So it is a nice enough (bit budgetty) F-18, but needs a bit of work - especially for a CS10.
Ok, thanks for the infos
Do you think i can handlaunch and fly it without making modifications to the
inlet and exhaust duct ??
bentech is offline Find More Posts by bentech
Old Aug 11, 2012, 06:20 PM
St. Martin is offline
Find More Posts by St. Martin
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
I only did a balance run with 3s ans 4s packs. Tam runs this set-up, only with His CF shroud, on 6s. IIRC it is 80A@1800W. I'm only interested in achieving 1000-1200W on 5s and smaller packs. It will go in another RBC Panther. A great flyer on 70mm vs 90mm. Weight goes from 6-6.5# to 4-4.25#.
Fuzz
St. Martin is offline Find More Posts by St. Martin
Old Aug 12, 2012, 02:06 AM
advanced n00b
xfatdannx's Avatar
Joined Feb 2012
Fuzz
Cool man. Again thanks for the info...i am gonna maiden my bird in the next week or so but i have the CS in the works for down the road. Got that e-flight 4s set up out of a habu for now...4s lets me stay with 2s (in series) and not spend more on another charger for now. only my second edf so im gonna take it in steps.
Old Aug 12, 2012, 03:31 PM
tofast4u is offline
Find More Posts by tofast4u
speeddemon
United States, TX, Whitesboro
Joined Jun 2011
Got the cs 10 blade fan two days ago, put a 2200kv motor in it went to fly it in my meteor, after 20 seconds motor burned out! What happened?
tofast4u is offline Find More Posts by tofast4u
Old Aug 12, 2012, 03:44 PM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
Which motor?
The longer the motor the better in regards to longevity, on the other side don't waste weight and get a motor that can do 4000 watts and only put 1000 through it....jus my humble preference
erh7771 is online now Find More Posts by erh7771
Old Aug 12, 2012, 08:10 PM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
Bentech, yes even at 3S 'pathetic power' the F-18 hand-launched fine.
tofast 4u - you didn't mention what motor.
KV just means the approx RPM it will do under NO load. Once used for any given load, it is like throwing some X amount heavy trailer onto your car..... and the motor then needs to be able to COPE with that task.
There are various possibilities that you might have done 'wrong'... but the first likely one is that is was too small a motor for the task.
At 2200kv it will draw a lot of current (or want to) and you need something more towards a CyclonePower ($45) or HET ($75) level of ability to do that adequately. eg Not some "$10 motor".
So the clue of "Lasted 20sec and burnt out" is a big clue that it was well under the ability truly required.
PeterVRC is offline Find More Posts by PeterVRC
Old Aug 13, 2012, 10:47 AM
tofast4u is offline
speeddemon
Joined Jun 2011
it was a motor out of a banana hobby f18.. 2200kv motor designed for a 14.8v battery.I guess now mabey it was just designed for a 4s battery and not a 5s.. Cyclone power motors i have and like, guess i should get one for the fan!
Old Aug 13, 2012, 11:14 AM
c131frdave is offline
Find More Posts by c131frdave
Too many numbers
United States, IL, Lake in the Hills
Joined Oct 2010
I used that motor with my F18 and 10 blade fan all the time. It works perfect- on 4S. It's a crap motor, but it works with 4S just fine. I was going to try it with 5S, but I guess not now... lol
c131frdave is offline Find More Posts by c131frdave
Old Aug 13, 2012, 12:50 PM
Knife Liddle is online now
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
Yeah. If you start with a marginal motor ; you can't increase the voltage and put it in a heavier loaded fan then expect it to last.
Maybe one or the other, but not both.
Knife Liddle is online now Find More Posts by Knife Liddle
Old Aug 13, 2012, 03:26 PM
RGS2010 is offline
Find More Posts by RGS2010
Always Fly 2 Mistakes High!
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
Cyclone Power CS480-3300-3.17 EDF Motor
I'm waiting on my 10 blade from HK..I have my new Cyclone Power 4S motor but I've never seen one that has a rubber ring to put around motor before...how do I use it? It seems to have two places that it could go on front of motor???
It's a real head scratcher...
Russ
RGS2010 is offline Find More Posts by RGS2010
Old Aug 13, 2012, 03:40 PM
Flip Flop is offline
Find More Posts by Flip Flop
Flip Flop's Avatar
United States, UT, Syracuse
Joined Oct 2009
Russ
That rubber ring is like a gasket used to give the motor more support in the tube. The two different slots are for different sized motor tubes, one will make the rubber ring sit lower in the slot for smaller motor tubes and the other will make it sit farther out for bigger tubes. You can try putting the ring around each setting and then sliding it into the tube on the shroud to see which is the tighter fit.
Flip Flop is offline Find More Posts by Flip Flop
Old Aug 13, 2012, 03:41 PM
RGS2010 is offline
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
Thank you Mr. Flop!
Old Aug 13, 2012, 03:43 PM
Flip Flop's Avatar
Joined Oct 2009
Ur welcome sir.
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7286 Sep 12, 2016 11:32 PM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
