Old Aug 08, 2012, 11:00 PM
jk671 is offline
Find More Posts by jk671
John
jk671's Avatar
United States, NV, Las Vegas
Joined Mar 2011
I don't know about that... I have had quite a bit success running a little bit higher kv's
Here's 4S at 3300kv
T-50 70mm edf jet remaiden (4 min 2 sec)
Here's 5S at 2500kv
LX F-22 Cyclonepower 2500kv Changesun 70mm edf jet remaiden 02-25-12 (2 min 38 sec)
LX F-22 Changesun 10blade edf #2 02-25-12 (3 min 5 sec)
And here is 6S on 2500kv
Exceed RC F/A-18 70mm EDF Jet Blue Angels Maiden Flight and Crash WTF!!! (4 min 2 sec)
F/A-18 70mm EDF Jet ChangeSun 10 Blade 70mm CyclonePower 2500kv (3 min 53 sec)
Again 6S on 2500kv with RC Lander 68mm dps alloy shroud
Exceed RC F/A-18 edf jet repaired, failed landing! (5 min 0 sec)
My next setup will be 2200kv HET2w-30's on 6S
jk671 is offline Find More Posts by jk671
Old Aug 08, 2012, 11:34 PM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
But they are not 'sweet spot' results... those are all big amp eaters.... and need 'big' motors (costly).
Those are all 'high power' combos.
(5S 2500kv cyclone as I had mentioned - prob Amps into the 60's).
6S 2500kv... if it was the Cyclone, it won't last too long. (Well, lifespan is a lucky dip thing then)
That would have to be 6S Amps around the 70 area! More Watts than that motor will like dealing with.
But probably over 2.0Kg bench thrust... 2.2Kg.. more??? And then.... how much of that gets OUT of the plane anyway?
Hmmmm... F-22... fans probably well down the rear... at least more likely to get the best OUT.... if it has enough air IN also.
PeterVRC is offline Find More Posts by PeterVRC
Old Aug 08, 2012, 11:46 PM
PeterVRC is offline
Joined Nov 2006
Hmmm.... I am thinking about getting one of those Cyclone 2550kv's to test out.
At worst they would be "a very good motor" really. For 5S. (and 5S is my most common combo for 70mm - all cases really)
I wouldn't really want to risk the $44 on 6S though.
Old Aug 09, 2012, 01:32 AM
jk671 is offline
John
jk671's Avatar
Joined Mar 2011
ok yeah I see your point... I pretty much go for sound and performance, not so much flight time/efficiency... but when you are running a heavy airframe like the f-18, you need to tap into that power... the f-22 is a much much lighter airframe which is why 5S on the 2500kv seems to have somewhat the same performance. One thing about the lx f-22 airframe though is that it seriously acts like a silencer, especially when using the cs rotor. on my youtube channel, I have a video, where I am running the cs rotor with the dynam 3000kv motor from a downed meteor that I had. I ran it on 5S and while the plane seemed to have loads of power and would just continue to climb if I wanted it to... it was extremely quiet, the only time you heard it is on take off... I would post the video, but there's like 3 and a half minutes of me just talking... before the take off
Old Aug 09, 2012, 02:22 AM
PeterVRC is offline
Joined Nov 2006
5S 3000kv yeeha!!
The Dynam motors are quite good, for their cost. I call that one an 'average' motor - maybe 'a bit above average'. (for its cost and size). Well down on a Cyclone or HET.
But a CS10 on 5S 3000kv would be smoking!! hehe
Highly inefficient, and hot. That would kill the Dynam motor in a short term.
They last quite well on a 5-blade fan doing that 5S, but a CS10 is a lot more load.
Old Aug 09, 2012, 06:55 AM
Ming is offline
Find More Posts by Ming
Ming's Avatar
Hong Kong
Joined Jun 2002
ChangeSun 70mm 10 blades and 90mm 12 blades available again on Windrider website:
http://www.windrider.com.hk/product.asp?id=141
Ming Lou
Ming is offline Find More Posts by Ming
Site Sponsor
Old Aug 09, 2012, 07:23 AM
Goody63 is offline
Find More Posts by Goody63
How close are those trees?
Goody63's Avatar
Perth, Western Australia
Joined Apr 2008
Ming Lou
I can highly recommend Windrider for fast and efficient service.
Thanks for getting them in stock Ming.
Goody63 is offline Find More Posts by Goody63
Old Aug 09, 2012, 08:28 AM
Ming is offline
Ming's Avatar
Hong Kong
Joined Jun 2002
Ming Lou
Thank you!
Ming Lou
Site Sponsor
Old Aug 09, 2012, 09:54 AM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
The CP2500s fly on 6s with this fan, just don't go over 3000 watts of steady out on them...
janthony15 vids tell the tale.... a vid is worth a thousand pics...
erh7771 is offline Find More Posts by erh7771
Old Aug 09, 2012, 01:29 PM
RGS2010 is offline
Find More Posts by RGS2010
Always Fly 2 Mistakes High!
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
I have this motor:
http://www.pw-rc.com/product_info.ph...oducts_id/2028
I have this ESC:
http://hobbyking.com/hobbyking/store...ESC_Opto_.html
w/ this BEC:
http://hobbyking.com/hobbyking/store...dproduct=16663
With this battery:
http://hobbyking.com/hobbyking/store...dproduct=18640
Will it all work work well together with 10-Blade?
Plane it will be installed in is a Venom 70mm F-86 that currently has E-Flite Delta V15 with BL 15 motor.
RGS2010 is offline Find More Posts by RGS2010
Old Aug 09, 2012, 01:45 PM
erh7771 is offline
Joined Nov 2005
Originally Posted by RGS2010 View Post
I have this motor:
I have this ESC:
w/ this BEC:
With this battery:
ESC is a little low on the amps...see if you can find a 90 - 100 amp esc to give you some head room
Old Aug 09, 2012, 02:10 PM
jk671 is offline
John
jk671's Avatar
Joined Mar 2011
I agree
Old Aug 09, 2012, 02:31 PM
RGS2010 is offline
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
Just ordered HK Red Brick 100 amp Opto ESC w/ 5 amp BEC.
Thanks!
Old Aug 09, 2012, 02:36 PM
anlucas is online now
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
Thanks!
Good move. I use the same setup but with an HK SS 90-100 Amp ESC.
Expect to see 85-90amps with that battery.
That Zippy is a very good value for money. Only minus is 1C charge rate and the balance wires which are hard and you have to take care bending them around or they will snap off the battery.
I fly this setup in the same size Mig-15.
anlucas is online now Find More Posts by anlucas
Old Aug 09, 2012, 07:28 PM
bentech is offline
Find More Posts by bentech
bentech's Avatar
Canada, QC, Brossard
Joined Jun 2006
here my set-up:
http://www.ejf.com/index.php?main_pa...roducts_id=206
http://www.hobbyking.com/hobbyking/s..._for_70mm.html
http://www.hobbyking.com/hobbyking/s...SC_w_UBEC.html
http://www.hobbyking.com/hobbyking/s...dProduct=14058
i didn't try it yet because i'm still waiting for the 10 blade fan and esc from hobbyking. i hope it will work well !!!
bentech is offline Find More Posts by bentech
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7224 Apr 21, 2016 02:53 AM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
