Old Aug 04, 2012, 06:59 AM
anlucas is online now
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
Originally Posted by Extreme_RC View Post
I have bags of current model (4 set screw) 3.17 and 4mm adapter sets with screws, nut etc to clear out, must be 20-30 of them, 5 bucks each, if there is enough interest I will stick them up on the clearance page of the website.
Mark,
I am interested for 5-6.
Andrew
anlucas is online now Find More Posts by anlucas
Old Aug 04, 2012, 07:01 AM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
Ok will stick them on the clearance page tomorrow, its 10pm and I have had enough of this computer!
Extreme_RC is offline Find More Posts by Extreme_RC
Old Aug 04, 2012, 11:43 AM
St. Martin is online now
Find More Posts by St. Martin
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
St. Martin: It is only natural to loss thrust when you remove areal form the rotor regardless of the shape of the blades, but I must emit there is a limit to how much you can remove from a scimitar shape... After cutting the fan I ended up with a pitch of just over 45 degrees at the tip, so it is not to bad.
I understand your point completely. Removing area reduces static thrust. I was noting the difference between cutting back a conventional blade vs a scimitar shape.
When I cut down a minifan to 66mm I can up the Kv and still draw the same amps. e.g. HET 3w (3000Kv)minifan on 4s 33A/430W 66mm(505), ARC 28-37-2(3750Kv) 32A/430W.
Static thrust was lost. But dynamic thrust was gained with higher efflux. Taking both fans, and just swapping the rotor,the 8 blade scimitar had higher watts and amps in the minifan. But far less amps and watts after cutting back to 66mm as compared to the cut mini rotor.
It was just an experience, that a special shaped rotor is designed to function in it's original planform, or lose efficiency(hence the cavitating sound that was not present in the 8 blade uncut version).
But, I'm all for experimenting. That's why I wished you the best with the trial. You never know when you will stubble upon something that works good.
Fuzz
St. Martin is online now Find More Posts by St. Martin
Old Aug 04, 2012, 06:23 PM
Extreme_RC's Avatar
Australia
Joined Mar 2006
Guys I will post up in here soon as I get a chance to snap a pic and list up all the odd parts, please hold on the PM's until I have notified you all in here, I have a real busy day today (sunday) but will get it done tonight.
Old Aug 05, 2012, 07:29 PM
PikeStaff is online now
Find More Posts by PikeStaff
Gorilla Glue Expert
PikeStaff's Avatar
United States, PA, Doylestown
Joined Sep 2010
Hangin' on.....
Shout when ready, Mark. Lot of us with card in trembling fingers
PikeStaff is online now Find More Posts by PikeStaff
Old Aug 05, 2012, 08:40 PM
Extreme_RC's Avatar
Australia
Joined Mar 2006
Up on the site now, link for clearance page HERE.
Old Aug 05, 2012, 09:22 PM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
pm'd on the lander intakes
erh7771 is online now Find More Posts by erh7771
Old Aug 05, 2012, 10:42 PM
Extreme_RC's Avatar
Australia
Joined Mar 2006
All I can tell you is the Lander intakes suit Lander fans from 2009, if the thread is still the same they will fit, no way for me to know though sorry.
Old Aug 06, 2012, 12:32 AM
RawmadeCF is offline
Find More Posts by RawmadeCF
Perpetually covered in resin
RawmadeCF's Avatar
United States, NV, Las Vegas
Joined Dec 2011
Anyone know if there is any dealer in the US that makes alum spinners for these? We all know how much of a pain the stocks are to get balanced and I refuse to run no spinner =P
RawmadeCF is offline Find More Posts by RawmadeCF
Old Aug 06, 2012, 12:49 AM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
http://www.tamjets.com/original/prod...1f57bae1eabc0a
jcdfrd is offline Find More Posts by jcdfrd
Old Aug 06, 2012, 01:35 AM
RawmadeCF's Avatar
Joined Dec 2011
Yikes...that is a lot of money for what it is...with that being said, if Tam is the only one making em Ill spend the $70 for the spinner/washer/adaptor pair as much as it would kill me inside.
Really wish shipping from Aussyland wasnt a million dollars...I really want Extreme's metal CS units.
Old Aug 06, 2012, 01:39 AM
anlucas's Avatar
Joined May 2011
It's not a million dollars really..
Not dirt cheap like shipping from Hong Kong or China but reasonable if you need the alloy treatment.
Old Aug 06, 2012, 01:48 AM
RawmadeCF's Avatar
Joined Dec 2011
Think it was $80ish for two 70mm units. Would bring me to $230...$150 increase over just the T spinners/adaptors, so its still a consideration. Will have to think on it.
Old Aug 06, 2012, 01:52 AM
anlucas's Avatar
Joined May 2011
That's perplexing. I got 1 70mm fan + several other bits and pieces for around $23 shipping.
Old Aug 06, 2012, 01:55 AM
RawmadeCF's Avatar
Joined Dec 2011
Where are you located?
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7232 Jun 06, 2016 02:40 AM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
