Old Aug 02, 2012, 08:00 PM
c131frdave is offline
Find More Posts by c131frdave
Too many numbers
United States, IL, Lake in the Hills
Joined Oct 2010
Flew mine again tonight. Love it. I'm about 10000 rpm lower than you guys, but still peforms really well. Putting in an order for a 3000kv motor to "pump up the volume".
c131frdave is offline Find More Posts by c131frdave
Old Aug 02, 2012, 08:15 PM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
Originally Posted by clive45 View Post
Since when have the CS70 fans been $30, never paid more than $16?????
16 is about the cost for most of us small importers, add shipping and 30 is not unreasonable.
I have bags of current model (4 set screw) 3.17 and 4mm adapter sets with screws, nut etc to clear out, must be 20-30 of them, 5 bucks each, if there is enough interest I will stick them up on the clearance page of the website.
Extreme_RC is offline Find More Posts by Extreme_RC
Old Aug 02, 2012, 08:47 PM
PikeStaff is offline
Find More Posts by PikeStaff
Gorilla Glue Expert
PikeStaff's Avatar
United States, PA, Doylestown
Joined Sep 2010
2 questions - does each bag contain 1 each 3.17 AND 4mm? And got any idea what shipping, say, 3 bags to the good ole USA would run?
PikeStaff is offline Find More Posts by PikeStaff
Old Aug 02, 2012, 09:14 PM
Too many numbers
Joined Oct 2010
Mine came with two adapters, but I don't know their size. If you want to find out shipping, put one in your cart and check out. When you get to the part where you chose shipping, you can exit the browser (or just click on the home page) and you'll get out of the order.
Old Aug 02, 2012, 09:32 PM
Gorilla Glue Expert
PikeStaff's Avatar
Joined Sep 2010
Great plan! Thanks, hadn't thought of that.
Old Aug 03, 2012, 12:54 PM
frank40 is offline
Find More Posts by frank40
frank40's Avatar
Denmark
Joined Sep 2005
I modified a CS 90 to a 70mm version, I started by cutting the motor mount and the stators out, it was sanded to fit a 70 fan-house that I made of fibreglass. Then I cut the rotor to fit, whit about 0.8 mm spacing to the fan-house wall. I borrowed a 1850KV out runner spec. to max 1600W. ( Still trying to find the right motor). First try with 7 cells gave me 2.1Kg at 2KW... I noted that the air was hot at high power, so I guess the efficiency of the motor is low at this point. The scale was not moving all that well, so after fixing this and with full charged batteries I got 2,6 Kg peak at 2,3KW ( for a very short time)
frank40 is offline Find More Posts by frank40
Old Aug 03, 2012, 02:41 PM
Maxthrottle is offline
Find More Posts by Maxthrottle
You are a "go" for reentry
Maxthrottle's Avatar
High Orbit.....
Joined Jun 2009
Videoooo
Maxthrottle is offline Find More Posts by Maxthrottle
Old Aug 03, 2012, 03:20 PM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
Pray tell, how were you able to cut the blades down and balance them?
Regards
erh7771 is offline Find More Posts by erh7771
Old Aug 03, 2012, 03:32 PM
High Orbit.....
Joined Jun 2009
Edit dumb me can't count.
Old Aug 03, 2012, 04:07 PM
St. Martin is online now
Find More Posts by St. Martin
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
Good luck with this mod, Frank. I thought of doing this with the 8 blade rotor that Gary sells at Efflux. While it seams to work well on strait type blades, like the WeMo or HET, etc., trimming a scimitar shaped blade lost a lot of thrust. As compared to the WeMo or HET types. That little foot, at the end of the blade adds a lot of load. I had the same findings with trimming APC-E props, also.
Just always seams to be cavitating(sound).
Fuzz
St. Martin is online now Find More Posts by St. Martin
Old Aug 03, 2012, 06:08 PM
Extreme_RC's Avatar
Australia
Joined Mar 2006
Yup one of each, with all the associated screws and nut etc.
Airmail for flat items is AUD$13.00 for up to 150g, should be able to send 4-6 in one pack I reckon.
Old Aug 03, 2012, 06:11 PM
Extreme_RC's Avatar
Australia
Joined Mar 2006
Why would you bother cutting a 90 down? Its heavy, slow to accelerate, motor is heavy, and it obviously sucks power, the 70mm does 2.1kg on 6s at 1400 watts.
If it was to run with a 7 stator housing I got that covered in my new design 7 stator housings are in my new order of housings due in about 10 days. In fact I have 150 mixed housings due in
Old Aug 04, 2012, 04:52 AM
limodune is online now
Find More Posts by limodune
limodune's Avatar
Australia, QLD, Toowoomba
Joined Oct 2011
Here's a quick vid of my a320 airliner taxi testing with the cs 10 blades added and 2300kv out runners motors, will fly it tomorrow weather permitting, I like the sound, not perfect but still nice, the weight is just over 2kl (retracts added)
A320 taxi test after upgrades (0 min 36 sec)
limodune is online now Find More Posts by limodune
Old Aug 04, 2012, 05:58 AM
frank40 is offline
frank40's Avatar
Denmark
Joined Sep 2005
Erh7771: I had a old 90mm FlyFly fan that I modified to cut the fan by removing one half of the fan house, and I Fan was in balance after it was cut.
St. Martin: It is only natural to loss thrust when you remove areal form the rotor regardless of the shape of the blades, but I must emit there is a limit to how much you can remove from a scimitar shape... After cutting the fan I ended up with a pitch of just over 45 degrees at the tip, so it is not to bad.
Extreme_RC: The reason for me is to try to gain airspeed not just thrust, for that I needed more power giving me a need for a bigger motor and a more power full rotor. Sense the CS 90 rotor is build more vigorous it is the first choice for me. And when cutting it down the centrifugal force work with my witch allow me to up the rpm's.
Old Aug 04, 2012, 06:54 AM
Extreme_RC's Avatar
Australia
Joined Mar 2006
Yes but thrust equates to velocity, and you are introducing more weight in both the fan and the rotor, plus you are removing a lot of the blade design by cutting 10mm off it. Need to see it in a model, video!
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7232 Jun 06, 2016 02:40 AM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
